To block or not to block, that is my dilemna...
Discussion in 'Suspension' started by TacoBS, May 12, 2011.
  1. May 12, 2011 at 6:42 AM
    TacoBS
    TacoBS [OP] Well-Known Member
    Billyson
    Central Coast, CA
    2011 Pyrite 4x4 DCLB
    2"/1" spacer/block (for now) Tailgate hoseclamp bedmat mod Marathon covers Weathertech mats
    Morning folks,
    I'm tossing over this one...
    I recently traded an '07 access cab 4x4 for an '11 double cab 4x4 for family accommodation reasons. I was heartbroken when got rid of the access cab (great truck), but was quickly relieved by the drive quality and ability to now go to and fro with the family.
    My problem is that I have a favorite surf spot that requires a bit of negotiation to access. With the access cab I never had any issues scraping or bottoming out when going there, but with the longer wheel base on the double cab I scrape on the middle of the frame when going over the final rise.
    I can't afford an elaborate lift for about a year or so. I am thinking of just putting in a 2" block up front with an AAL in back to suffice until I can muster the funds for a Toytec ULK or something of that nature. Pretty sure that the blocks will give the distance I need because it only scrapes for about a foot or so along the frame.
    Ultimately all I want for the truck is 3".
    I know blocking is not the way to go, but I don't mind shelling out the few hundred now to be able to access my favorite spot without bottoming out. My worry however is that the block may ultimately damage something over the year or so while I save for something real deal, which I really don't want to happen.
    The block system I'm looking at is solid, laser-cut steel and warrantied for life, so I'm not worried about the parts failing but rather what it will do to my truck.
    What are your thoughts? Any insight is appreciated.
    And I realize there are million threads about the negativity of blocks, but in searching I couldn't find anything that really conceptualized my dilemma...so I apologize for the redundancy of the block issue.
    A sincere thank you!
  2. May 12, 2011 at 7:55 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    ran my 3" over the strut spacer since 2005 without any damage or issues. Had 3.5" blocks out back as well for a few years and now using AAL.
    Never had any problems. It sounds as if what you are doing with them isn't going to break anything either.
  3. May 12, 2011 at 7:55 AM
    w4lter
    w4lter Well-Known Member
    Omaha
    TRD Sport
    Westin bullguard, Steelcraft 3" Nerfbars, Bilstein 5100s all around -front set at 2.5", toytec 2" AAL, Wickedflow muffler, 265/70/17 Destination ATs.
    I would say blocks are fine, except that I don't think it will fix your problem. If you're scraping, you need to raise the frame relative to the axles for more clearance and blocks don't do that. Someone feel free to jump in and correct me if im wrong. Bilstien shocks and an aal are probably you're cheapest route. You'll get about 2.5" and you likely won't need the ULC if you're satisfies with it.
  4. May 12, 2011 at 8:06 AM
    TacoBS
    Billyson
    Central Coast, CA
  5. May 12, 2011 at 8:09 AM
    TacoBS
    Billyson
    Central Coast, CA
    Thanks guys for the input. It helps for sure.
  6. May 12, 2011 at 8:35 AM
    brelandt
    Terry
    Dublin, CA
    I HATE IT when some one chimes in that spacers preload your coils!!!! Not the OVER the strut type we are talking about! Adjustable 5100 preload coils and so does revtec.
  7. May 12, 2011 at 8:44 AM
    TacoBS
    Billyson
    Central Coast, CA
    Is the "over the coil" spacer inserted between the spring and strut or is that the "within the coil" spacer? I assume it is the over the coil.
  8. May 12, 2011 at 8:45 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Go with 5100s up front instead of spacers, the 5100s are just a little more expensive but are the right way to lift your truck vs spacers.
  9. May 12, 2011 at 8:52 AM
    TacoBS
    Billyson
    Central Coast, CA
    Between 5100's and spacers, which would increase CV angles more? If possible, I would like to keep angles to a minimum until I can do it right (with proper coil-overs and diff drop if needed.)
    Forgive the ignorance, but that is why I am here... to learn from those more experienced :)
  10. May 12, 2011 at 8:57 AM
    kmok
    Kyle
    Columbus, Ohio
    5100s, spacers and coilovers all will increase the cv angles. If the 5100s, spacers, and coilovers give you 3" of lift the cv angles will be the same. The cv angles is increased by the amount of lift the setup gives you, not what setup you choose.
  11. May 12, 2011 at 10:09 AM
    brelandt
    Terry
    Dublin, CA
    Well, the 2 biggest thing for you right now is price and getting over a mound. So, get a over the strut spacer cause it doesn't require you to rent or buy a coil compressor to install and they are really cheap. The rear no matter what you get will require longer brake line and longer shocks plus it's more work lifting the rear no matter whether you use blocks or AAL. Get blocks or AAL either way...though you may want to get the AAL since you may just leave them on when you upgrade later.
    after that save up and read about the different options for you and see what you want. Whether it's OME's, 5100, or coil overs.
  12. May 12, 2011 at 10:28 AM
    TacoBS
    Billyson
    Central Coast, CA
  13. May 12, 2011 at 10:38 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    good info.
    Not so good info.
    You dont need longer brake lines for the rear or longer shocks. My first set up was a basic toytec coil spacer and AAL kit, using factory sr5 rear shocks and factory length brake lines...no issues for 2 years wheeling in southern Idaho.
    You can get an AAL for the rear that will suit your needs just fine and they are priced pretty resonably. For the front I would just get the billy 5100's. LOTS of people on here run them and really like them
  14. May 12, 2011 at 10:41 AM
    TacoBS
    Billyson
    Central Coast, CA
    thx zombie!
  15. May 12, 2011 at 10:49 AM
    brelandt
    Terry
    Dublin, CA
    I don't think stock shocks will reach? I have a 1st gen so that maybe the difference? But my shock mounts with AAL are 20" passenger and 16 on driver and the new KYB shocks I bought that is suppose to be good for a 2" lift is barely long enough. Only 1" of down travel.
  16. May 12, 2011 at 10:53 AM
    tb99trd
    tb99trd Well-Known Member
    Tom
    Petaluma CA
    99 TRD 4x4
    Bilstein 5100s (@ 2.5), Toytec 2" AAL, gray wire mod
    im trying to figure out what surf spot you're talking about...:spy:
  17. May 12, 2011 at 11:07 AM
    TacoBS
    Billyson
    Central Coast, CA
    I'm sure you know it Tom. It's no secret...it's just how I park to get away from everybody that is the fun part.
  18. May 12, 2011 at 11:14 AM
    tb99trd
    Tom
    Petaluma CA
    99 TRD 4x4
  19. May 13, 2011 at 5:25 AM
    timmah
    timmah Member
    Dry Ridge,KY
    10' Prerunner
    ORU 3" front, Brighton Spring 2" rear, AllPro spacers, BDS shocks, Yokahoma Geolanders 265/75/16, K&N, Anzo headlights
    I lifted mine with spacers and blocks. Its OK. I like you, needed just a little more clearance for a couple of my favorite fishing spots and mines just a pre-runner. No serious wheeling. I also was on a budget. ORU spacer kit was only like 90 bucks shipped. BDS 2" blocks and u-bolts for 88 bucks and the stock shocks worked but, put BDS shocks on too for and extra 90 bucks. Hope this helps. I did order EMU driveshaft drop. Haven't put it on yet. Oh yeah I drive 75 miles round trip a day with no issues, except needing an alignment when I was done.
  20. May 13, 2011 at 5:58 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    what is BDS and ORU?
