To build a complete strut w/o reusing any parts...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bamacrazy, Feb 21, 2018.
  1. Feb 21, 2018 at 1:44 PM
    bamacrazy
    bamacrazy [OP] Active Member
  2. Feb 21, 2018 at 1:57 PM
    Pigpen
    Dan
    Northwest Montana
    Yes
    That stock photo from Carid is wonky though.
  3. Feb 21, 2018 at 2:25 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    personally I hate carid, ordered mine from summitracing. I Have the same KYB shock mount set up.
    bamacrazy[OP] likes this.
  4. Feb 21, 2018 at 2:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You need everything that is in the second photo on the carid link you posted
    Bushings, washers, top hat, coil isolator, springs, and shocks
  5. Feb 21, 2018 at 2:29 PM
    BassAckwards
  6. Feb 21, 2018 at 4:24 PM
    bamacrazy
    Not using them. Just link to photos.
  7. Feb 21, 2018 at 4:27 PM
    bamacrazy
    BassAckwards[QUOTED] likes this.
  8. Feb 21, 2018 at 4:30 PM
    bamacrazy
    Ordered! Thanks!!!
  9. Feb 21, 2018 at 4:30 PM
    Pigpen
    Dan
    Northwest Montana
  10. Feb 21, 2018 at 4:43 PM
    BassAckwards
    Yes sir!:thumbsup:
    bamacrazy[QUOTED][OP] likes this.
