To buy or not to buy
Discussion in 'New Members' started by nevans2010, Jun 27, 2014.
  1. Jun 27, 2014 at 2:47 PM
    nevans2010
    nevans2010 [OP] Member
    Plainfield, IL
    10 4RUNNER Limited
    Hey Everyone, Hope you don't mind me medling in your forum. Here's the deal. I currently own a 2010 4Runner and am looking to trade it in for a 2010 Taco. The Taco is priced at around $21k with 84k on the odo and is a TRD Off Road. First I feel like I can get at least 200k out of this truck as I maintain the hell out of my vehicles, and I will be buying this to be more of a winter/fun truck. Will be buying a project car for summer time in the years to come.
    My question is, when looking at this truck with 84k on it, what are some typical issues you guys have come across by this age? What should I be looking for specifically to make sure I'm not replacing anything expensive as I drive off the lot? And does this seem like a fair price for this Taco? It's in the Chicagoland area, Naperville to be exact.
    Any help you can give would be appreciated.
    Nick
  2. Jun 27, 2014 at 2:55 PM
    Large
    Large Red
    Frame rust
    Any codes
    3 or 4 leaf pack in the rear
    Does it drive straight
    Any vibes from take off to 70 mph
    Any vibes in 2H that go away in 4H (4wd only)
    I would assume mostly highway miles with it being a 2010, look for leaks in the rear diff, front diff, t-case, tranny, look at the radiator for leaks, it probably needs a new battery. See If there is any maintenance history
  3. Jun 27, 2014 at 2:55 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    You truck will just barely be broken in at the 200k mark.I have crossed 300k on two toyota pickups, working on it on my first Tacoma. Not sure about the price. What does KKB and Edmunds TMV list the truck for?
  4. Jun 27, 2014 at 3:06 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Check for wear that would leave you to believe more miles are on it. Odo takes a minute to unhook on these trucks.
    Frame will rust out quick so check it as others have said.
    Wheel bearings will go soon if not already changed and same with the lower control arm cam bolts and bushings.
  5. Jun 27, 2014 at 9:38 PM
    Mttsgtr99
    Mttsgtr99 New Member
    I am a Technician for a Toyota dealer here in PA. I've seen a lot of differnt style toyotas "car SUV trucks. With 200k - 600k.
    Still running strong on original engine and trans. Of coarse you still got your regular maintence. Keep up on that and it will last. Don't forget about frame sprays. Wouldn't hurt on any of them. It helps. Ecspecially trucks an SUV
    I own a 2007 Tacoma love it
  6. Jun 29, 2014 at 7:44 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Definitely do a carfax. Frame inspection, maintenance history.
  7. Jun 30, 2014 at 9:56 AM
    nevans2010
    Plainfield, IL
    10 4RUNNER Limited
    Thanks for all the feedback guys. I'll take all this into consideration.
