To Cap or not to Cap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by capequahog, Feb 5, 2017.
  1. Feb 5, 2017 at 2:20 PM
    capequahog
    capequahog [OP] Well-Known Member
    Cape Cod MA
    17TacomaDblCabTRDSport
    in the dreaded black
    I'm on my fourth small to Tacoma sized pickup and never had a cap. I'm thinking I need one on my 17 TRD SportDCshortbed, what say ye bretheren
  2. Feb 5, 2017 at 2:29 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Really depends on your needs for the bed. I frequently haul lots of big stuff and a cap would get in the way.
  3. Feb 5, 2017 at 2:29 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    I dunno, do you need a cap?
    If you need a cap then I'd say go ahead and get one. If you don't need a cap then I'd go ahead and hold off
    Kyitty, nDub, LivinOnEdge and 5 others like this.
  4. Feb 5, 2017 at 2:30 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Bought a cap for my dog so the cabin stays cleaner. Love it.
  5. Feb 5, 2017 at 2:32 PM
    Mitch09
    Mitch09 Well-Known Member
    NC
    16' SR5 4x4 DCSB Super White
    Same deal here...mostly got it for my dogs and the rare occasion that I go camping.
    AZInferno and batshitcrazy like this.
  6. Feb 5, 2017 at 2:33 PM
    Notserp
    Notserp Active Member
    Preston
    2015 TRD OR DCSB
    Kinda hard to tell you if you need a cap. Only you know how you use your truck.
    I capped mine. I don't haul big stuff, but I make a fair amount of day trips down logging roads to plink, shoot photos, and explore. Also make road trips with tennis gear. Having the cap to keep things dry when in the forest or going over the mountain passes has been perfect. That's my use.
    George1441 likes this.
  7. Feb 5, 2017 at 2:34 PM
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
  8. Feb 5, 2017 at 2:35 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    And I'd like to add that often times you can't go wrong with purchasing a cap if you need it. However, there are occasions where you may find yourself not needing one in ANY capacity, and it's best at that point to just not get one.
  9. Feb 5, 2017 at 2:35 PM
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    I bought mine to keep our bikes secure when traveling. It's a nice comfortable feeling that they are locked up inside the cap, plus it helps to keep the out of the weather.
  10. Feb 5, 2017 at 2:37 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    Never had one because I like the visibility, and I do not really need that much dry storage. May get the softopper some day because it is easier to move out of the way if I have something oversize to haul.
  11. Feb 5, 2017 at 2:38 PM
    PNW BlueReaper
    PNW BlueReaper Slowly but Surely
    Aaron
    Kent, WA
    05 DCSB Indigo Ink Tacoma
    Exactly that!
  12. Feb 5, 2017 at 2:41 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I've never had a cap either, how easy are they to remove? Possible for one person?
  13. Feb 5, 2017 at 2:41 PM
    SR5 BRI
    SR5 BRI Brian Good Sport
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    Like others said depends on what you do and are looking to do with your truck. I personally have had a cap on every truck I owned and it always is the first thing I do after buying a new truck. If you ever need to use it without the cap grab a friend and it will come off and be back on in an hour.20161209_104408.jpg
  14. Feb 5, 2017 at 2:45 PM
    SR5 BRI
    Brian
    Albany n.y.
    2023 Sport Quadcab
    Alot
    You want to have atleast one guy on both sides its atleast a grand if you drop it. Some guys that are cleaver make a rope and pulley setup in their garage to take it on and off.
  15. Feb 5, 2017 at 2:49 PM
    batshitcrazy
    batshitcrazy Probably drunk
    Ievacado
    Scsb 3x2 Honda fit
    Ours only weighs maybe 150-175lbs? With the rack on it. But it's really big and awkward. I probably wouldn't try to do it yourself unless you want to risk tapping it and shattering your windows. I can't imagine they would be cheap to replace.
    SR5 BRI likes this.
  16. Feb 5, 2017 at 2:52 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Possible for 1 person if you have a setup for it. I have two 1" x 4" boards with hooks in them which are slid under the cap, there are eye bolts in the garage rafters and I run a tie down strap through each of the 4 corners. Then lift everything up corner by corner if I'm by myself. It works.
  17. Feb 5, 2017 at 2:55 PM
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    0210 likes this.
  18. Feb 5, 2017 at 3:05 PM
    DrFunker
    DrFunker Well-Known Member
    Have one on mine. This is my 3rd Toyota pick up, first with a cap.
    It's great having the shell on there (especially in the winter) with my gear in the back.
    tacoburrito, 0210 and TroutBum like this.
  19. Feb 5, 2017 at 3:07 PM
    CodeTaco
    CodeTaco Well-Known Member
    HB, CA
    2008 Tacoma Access Cab 4x4 TRD
    Bilstein 5100s (f @ 1.75); 5100s rear; All Pro Expedition Springs; PowerStop slotted discs; Akebono ceramic pads; Wheeler's braided brake lines; Prodigy trailer-brake system; heavy duty towing set-up (for off-road trailer); WeatherTech mats (awesome); 5% Ceramic Tint; matching Snug Top (mid) with racks; Thule racks; dipped badges; 17" 2014 OEM 5-spoke 4-runner rims; 265/70/17 Bridgestone Desert Duelers (for now); Siriusxm radio; more on the want list...
    You need to really think this out better than I did.
    I calmly explained to the wife that I needed a second truck without a snugtop so that I could occasionally haul tall items.
    She calmly explained to me the effects of living in a community property state....
    I love my snugtop 99% of the time and just rent a U-Haul F150 when necessary. It beats the hell out of giving the old lady 50% of my sh!t!
    DrFunker likes this.
  20. Feb 5, 2017 at 3:11 PM
    CodeTaco
    HB, CA
    Man, yer glad we aren't neighbors. You'd get tired of finding me all the time sitting in a lawn chair in yer driveway just staring at yer rig. I'm trying to be satisfied with my 2nd gen and you, sir, are not helping....:hattip:
