To front locker or to not to '19 6mt trdOR w/ 35 and 5.29 gears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imaiami, Mar 2, 2022.
  1. Mar 5, 2022 at 10:49 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Use the hand brake or the clutch start cancel.
    JDSmith[QUOTED] likes this.
  2. Mar 5, 2022 at 12:14 PM
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    Thought about the hand brake, I’ve been wanting to disconnect the switch for it so it doesn’t realize it’s on. It’s locked up on me before doing that.
    Clutch start cancel works great if you’re starting it, doesn’t do anything if it’s already running.
  3. Mar 5, 2022 at 1:06 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Make a handle throttle lever set up like what I used in all of my old jeep rock crawlers
    What you need ...
    Bicycle hand brake lever
    Brake cable ( long enough to reach from shifter to Throttle body)
    Assortment of zip ties
    Package of Blue soldered electrical ring terminals (14-18 awg)
    Installation instructions ...
    1) Mount hand brake lever at top of shifter handle so when your hand is on the shifter knob you can easily grab the brake handle easily
    2 ) using large zip ties secure brake handle to the shift stick
    3) run brake cable from hand brake to Throttle body linkage and cut to length
    4) attach / terminate blue soldered ring terminal to brake cable and attach to Throttle linkage
    5) test hand Throttle for proper operation and secure cable ever foot or so with zip ties
    It's that easy !!!
    Now you can use this hand Throttle for technical sections of a trail to control the Throttle and use your feet to operate the clutch and brake
    JDSmith likes this.
  4. Mar 5, 2022 at 1:07 PM
    gudujarlson
    Minnesota
    Ya. I guess you are supposed to stop the engine prior to using it? I’ve never gotten into a habit of using it. I use the hand brake it situations where rolling backwards is dangerous.
  5. Mar 5, 2022 at 1:14 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    JDSmith likes this.
  6. Mar 5, 2022 at 1:22 PM
    markturbo
    markturbo Well-Known Member
    Mark
    Saint John, NB Canada
    09 Tacoma
    I'd love to have front and rear lockers someday, so much easier to crawl along a trail and not have to worry about carrying momentum in some areas.
    imaiami[OP] and JDSmith like this.
  7. Mar 7, 2022 at 7:24 AM
    imaiami
    imaiami [OP] Active Member
    Dustin
    AZ
    2019 Cement TRD OR 6MT Taco Ol Girl
    Suspension FR-ADS 2.5 coilovers w/ remote comp adj resi, MCM upper arms RR-ADS Tripple bypass shocks, air bumps, U-bolt flip kit, Deaver U-402 leafs Custom Sliders Coastal Offroad skiddies BFG 33's Black Rhino Realm 16s X Trek Grill TRD Pro Headlamps
    I’m skeptical using the clutch start cancel while loaded on a steep hill etc. I feel like it’ll kill the starter or roast the fly wheel spline or something?? I definitely use my parking brake all the time. I have been in sticky situations while being stopped where just holding the rears with the parking brake after letting off the foot brake barely holds the truck enough. This is where having a line lock or a hand brake that holds all 4 wheels would be beneficial.
    The hand throttle on these drive by wire trucks would be a bit trickier I reckon!
    JDSmith likes this.
