To leave good enough alone
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Aug 1, 2021.
  1. Aug 1, 2021 at 7:09 AM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    I've been debating on flushing my power steering. At the present time I have 171,000 miles. I have no problems or leaks and I'm wondering if I should leave good enough alone. I didn't check the fluid color so I'm wondering if that would be the determining factor for most in making this decision. I guess I am concerned about creating a problem that doesn't exist at this time. Thanks for any opinions in advance
  2. Aug 1, 2021 at 7:14 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I would change it out. It’s a simple process. I used valvoline max life ATF. I felt it makes the steering more responsive. Also it’s good preventive maintenance that will reduce wear in the pump.
  3. Aug 1, 2021 at 7:33 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Change or refresh the fluid using a turkey baster.
  4. Aug 1, 2021 at 7:42 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Over the course of a week I used a fluid pump (Amazon) to remove fluid from the PS pump, refilled, repeat a couple days later, repeat, until I had used a Qt. of PS fluid......... Couldn't tell any difference......FWIW
  5. Aug 1, 2021 at 8:16 AM
    BlkDakDave
    David
    CC TX
    When I refreshed my PS fluid I pretty much did the same procedure. I didn't notice any difference either except a little peace of mind knowing that the PS had some fresh fluid running through the system. That same feeling I get every time I change the engine oil, rotate my tires or, like yesterday when I drained and flushed the coolant in my truck. Yes, I did the radiator and engine block.
    hemitruk likes this.
  6. Aug 1, 2021 at 8:18 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    This. I did this a few years ago on my 3rd gen 4runner. I couldn't believe the garbage that I was sucking out of the reservoir, I wondered how I had any power assist at all. It made a night and day difference and the pump was much happier, it hasn't made any scary noises since.
  7. Aug 1, 2021 at 8:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just change it. You might not feel a difference in performance but the pump would probably appreciate some fresh fluid
    BlkDakDave and wi_taco like this.
  8. Aug 1, 2021 at 9:02 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I flushed my ps at 200 000 kms. Not problems
  9. Aug 1, 2021 at 9:30 AM
    Beerline123
    Thanks guy's I think I'll do the flush. Have a great day guy's
    Rick's 2012 and BlkDakDave like this.
