To lift or not to lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by salm3404, Nov 1, 2017.
  1. Nov 1, 2017 at 11:31 AM
    salm3404
    salm3404 [OP] Member
    2015 Tacoma TRD
    Questions questions,
    ok so I'm a total newbie when it comes to this, i would like to lift my 2015 tacoma, is a trd off -road 4x4, i have no idea about lift kits or any of that, so if i lift it how much should it be lifted? 2inches?, 3 inches?, would i need different size tires than the ones it came with, right now it has the ones it came with BFgoodrich rugged trail, 265 /70r16, can i just put bigger tires? any advise on this will be welcomed.
    Thanks
  2. Nov 1, 2017 at 11:33 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Budget?
    Intended use?
    Seems like you want to lift
    Just dont know what direction to go
  3. Nov 1, 2017 at 11:37 AM
    salm3404
    2015 Tacoma TRD
    not sure on the budget yet, but im not looking to go over board, maybe under 2k, and i do want to lift it, but confused about how to go about it, intended use, off-road and city driving, off-road not as often as i like but will be used for that
    ChadsPride likes this.
  4. Nov 1, 2017 at 11:38 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    If youre wanting to do a suspension lift on your 4x4, it is generally recommended to stay below 3 inches to keep your constant velocity axle angles from getting too extreme or you will end up wearing parts out prematurely(or if you want more you can go with a drop bracket lift). Like @ChadsPride mentioned, your budget and intended use for the truck will play a big role in which route to go. Also, just because you lift the truck, you wont necessarily be able to clear bigger tires without cutting/trimming and a cab mount chop. The largest tire you can fit on stock suspension is 265/75/16 or 265/70/17 without having to worry about rubbing at all. Im running 3.5 inches of lift up front on my truck (2wd prerunner) right now and about an inch out back, and im running 265/70/17, but i want to step up to 285s. Im ready to cut whatever i need to though to get the clearance so thats something to consider when going with bigger tires! Good luck and welcome aboard!:thumbsup:
    TacoTRD78 and ChadsPride like this.
  5. Nov 1, 2017 at 11:38 AM
    ChadsPride
  6. Nov 1, 2017 at 11:40 AM
    BassAckwards
    Also.. im biased.. but my vote is to lift it!:D
  7. Nov 1, 2017 at 11:41 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    You'll probably want 5100 Billies. I mean, that's pretty much the standard. You can definitely go one tire size with no worries at all.
    ChadsPride and BassAckwards like this.
  8. Nov 1, 2017 at 11:53 AM
    salm3404
    2015 Tacoma TRD
    so getting 265 /70r17 tires wont require anything special, i wont need to add anything?
    BassAckwards and ChadsPride like this.
  9. Nov 1, 2017 at 12:02 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    LIFT ALL DAY LONG...coilovers set at 2.5, aal an rear shocks an a set of 255/75/17 will fit no rubbing an upper control arms an sway bar delete you’ll be able to tackle most terrain.
  10. Nov 1, 2017 at 12:06 PM
    BassAckwards
    Correct, if anything you might have a little scrubbing on your mud flaps, but you can always take a file to the area thats rubbing and knock it down a little bit. Thats what i did on my trucks and i was able to keep the flaps on them
  11. Nov 1, 2017 at 12:12 PM
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    I'll probably be in the minority here but I say leave it stock, at least for now.
    The cost, potential problems with handling, premature front end component wear, drive issues, reduced gas mileage and more just doesn't make it worth it.
    Unless you just want it. Then there is nothing anyone can say to talk you out of it.:D
  12. Nov 1, 2017 at 12:17 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    My truck handles better with aftermarket suspension than stock OEM. Lift it but do it right and do it once:thumbsup:
    stickyTaco and geekhouse23 like this.
  13. Nov 1, 2017 at 12:49 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just remember once you do a lift all those nightmare vibration problems start,along with tons of money spent trying too fix them.
  14. Nov 1, 2017 at 12:50 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    5100 Bilsteins.....adjust for the 2" front lift......
    add the 5100's to rear....call it good.....just did it my '14.....total $$ invested was $552
    Paid for the front install.......did rears myself....tires....ditch the Rugged Fails......
    pick out your fav 265-75x16's.....put the saved money somewhere else......
    But I'm an ole fart......I like the looks of lifted Tacos......
    do not want any headaches that may come with it...
    TacoTRD78 likes this.
  15. Nov 1, 2017 at 12:52 PM
    lynlan1819
    Tacoma
    Lifted
    Do yourself a BIG favor and read up on the above statment before you decide anything.Tacomas are not lift friendly as far as being problem free once its done.
    Armed in Utah likes this.
  16. Nov 1, 2017 at 12:58 PM
    lynlan1819
    Tacoma
    Lifted
    What he said exactly
  17. Nov 1, 2017 at 1:02 PM
    lynlan1819
    Tacoma
    Lifted
    Even 2 inchs of lift throws your driveline completly out of wack on these trucks,and the only real fix is a new cust $600 1 piece driveline.
  18. Nov 1, 2017 at 1:07 PM
    salm3404
    2015 Tacoma TRD
    from what i have read, there are some headaches that come from lifting, and of course the money, a place in socal $4500 for a lift kit, that put me off of even thinking about lifting it
  19. Nov 1, 2017 at 1:10 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Was that place 4WD parts?
  20. Nov 1, 2017 at 1:12 PM
    TacoTRD78
    Stuart,fl
    :devil:
