To Lift or not to Lift?
Discussion in 'Suspension' started by cjcanuk, May 20, 2010.
  1. May 20, 2010 at 2:56 PM
    cjcanuk
    cjcanuk [OP] New Member
    Cold Lake, Alberta, Canada
    09 Access Cab, TRD sport, Auto
    Hey Guys
    I just got an 09 Taco and have been reading lots of posts on the different lifts you all have tried and what has been working and what not. I thank you for sharing the great info and time it took to post it . I was thinking of going with the OME 3" kit with the AAD and the front diff drop spacer. Has anyone had this type of lift on for a long time (ie >50,000 miles)? How has the handling both on and off road been? How about tire, ball joint control arms and cv jpint wear over time?
    I really like the look of the trucks with the lift but am concerned about sacrificing the way the truck handles and premature wear on other parts.
    Or should I be entertaining the Blisten route
    or just leave it all stock.
    What to do??[​IMG]
  2. May 20, 2010 at 4:51 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    if you want a smaller lift like 2.5 inches or under go with the bilstein 5100s but if you want higher you should get a drop bracket lift.
  3. May 20, 2010 at 4:51 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    oh and welcome to tw.
  4. May 20, 2010 at 5:10 PM
    Bumponapickle
    Bumponapickle Well-Known Member
    Ontario, Canada
    09 TRD + Leather DCLB
    Old Man Emu 3 inch lift + AAL, Satoshi and Pioneer Avic Z130BT
    I just put the entire OME 3" lift (885 coils/10mm spacer/struts/shocks/aal/diff drop)on my 09 DCLB last weekend. I also added in a set of Light Racing UCA's, in all it took about 8 hrs and I took my time. I have not taken it in for alignment yet, but it actually drives better now then before. Will be picking up some 285's in awhile. Also added in a TRD skid plate I picked off of Metalmiller right here on TW. This place is like crack!!!!
  5. May 20, 2010 at 8:16 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
    I just drove a 09 with a 3" Revtek and 33" tires and was very impressed with the ride and handling.... and that is with the crappy stock shocks, leaf springs and front coils.
    The OME suspension is much better quality shocks, leaf springs and front coils.
    ARB makes quality products - should last longer than stock and ride much better.
