to much bass?
Discussion in 'Audio & Video' started by williams63, Nov 17, 2015.
  1. Nov 17, 2015 at 7:29 PM
    williams63
    williams63 [OP] Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I have the stock h/u with a 5ch alpine amp with bass knob, 10" jl sub and jl speakers in front and rear doors. had it installed a few years ago. sounded good but when I had it done but recently it just started to sound like to much bass. I turned down the bass knob on the amp all the way down and the bass on the radio to 0 and still sounds like to much bass. did I blow my speakers, amp, radio? not sure what to look for.
  2. Nov 21, 2015 at 5:10 AM
    bwhitaker
    bwhitaker Well-Known Member
    Oahu
    2013 Tacoma Double Cab TRD OR 4X4
    If it sounded good before and not now I'm not sure why.
    When I bought my truck I got a brand new 12 in. Sub put in. It sounded like crap with too much bass. Adjusted the low pass frequency on the amp from about 60 to 80 and it sounded much better sending more frequency to catch the different low sounds rather than just the lowest. Also adjusted the gain directly on the amp.
    Some things to try. By no means am I an audio expert though...good luck!
  3. Nov 21, 2015 at 6:00 AM
    williams63
    chili
    nh
    2011 dblcb
    thanks. I will try to take a good look at the amp today if I can. its under the drivers seat. don't know what im really looking at but it cant sound worse right.
  4. Nov 29, 2015 at 5:39 AM
    Bayboy
    Bayboy Well-Known Member
    2005 Access cab Prerunner 4cyl 5spd
    Vision 375 Warrior 16x8 265/70r16 Michelin LTX M/S 2 Pioneer 80PRS Helix DSP KAXBLTWT Tweeters SI TM65 mids Dayton HO 10" sealed
    The initial improvement over stock is what may have impressed you, but after more time in the seat and getting used to how the system really sounds may had you realize that it still needs frequency response manipulation. Quite common, not to mention if any speakers have loosened up over time. Basically it sounds like you need a simple retune.
    The bass knob on the amp is a bad thing to use from my experience. It can only boost, not cut. Better manipulation would be achieved through crossover and level adjustments while leaving all tone controls flat. If that doesn't suffice, the next step would be to incorporate a headunit with a good EQ and maybe even even time alignment to tighten up the sound.
  5. Nov 30, 2015 at 7:04 PM
    williams63
    chili
    nh
    2011 dblcb
    I don't think it was something I noticed over time. going to work one morning I noticed it right away. had to turn the bass on the h/u all the way down and then the bass knob on the amp all the way down. I would try to adjust the amp to see if it makes a difference but I don't really know what im looking at so I will have to wait to take it to shop.
  6. Dec 26, 2015 at 10:00 PM
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    Check your rca's you could be getting dirty signal
  7. Dec 27, 2015 at 7:26 AM
    williams63
    chili
    nh
    2011 dblcb
    I haven't had a chance to do anything with it yet but when I did look under the seat at the amp I didn't see any rca cords just a lot of wires.
