To Payload or not to payload... on a 2024
Discussion in '4th Gen. Tacomas (2024+)' started by el_turks, Jul 22, 2024.
  1. Jul 22, 2024 at 9:47 PM
    el_turks
    el_turks [OP] Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    The question often arises in my head, as I ponder how my setup plan for my 320 lbs bed camper on my new Tacoma 2024 Offroad, of how much can I load the truck with.
    This lead me to page 194 of the user manual under Capacity and Distribution, as I search for clarification on how to compute the numbers. Toyota states the following;
    "Cargo capacity depends on the total weight of the occupants.
    (Cargo capacity) = (Total load capacity) — (Total weight of occupants)"
    Steps for Determining Correct Load Limit —
    1. Find your payload capacity
    2. Subtract the total weight of occupants
    3. This will provide the remaining safe weight that the truck can carry.
    The example provided is
    Where XXX is the payload capacity....
    "For example, if the 'XXX' amount equals 1400 lbs. and there will be five 150 lb passen- gers in your vehicle, the amount of available cargo and luggage load capacity is 650 lbs. (1400 − 750 (5 X 150) = 650 lbs.)"
    In my case the total weight of me and my companion is 330 lbs, the trucks payload is 1200 = 870 lbs is the remaining capacity.
    870 lbs - 320 lbs (camper) = 550 lbs
    550 lbs - 250 lbs (Stuff in bed) = 300 lbs remaining
    User Manual page 613 section "Vehicle capacity weight" has the specific "Vehicle capacity weight (Occupants + luggage)" numbers by truck model. In my case it's 1200, but it is best to get the number from the door on your truck as it may have an updated number based on the specific VIN number.
    Hopefully this clarifies to someone else the question I had of how much I can carry on the truck passengers and all. I am glad I did not have to account for a full tank or anything else.
  2. Jul 22, 2024 at 9:52 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Payload (what it says in your door jam) is all the added crap in your truck that did not come from the factory including you and your passengers
    Vitamins and el_turks[OP] like this.
  3. Jul 22, 2024 at 9:54 PM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    It's weird that for payload they don't count the driver, but for the towing capacity, they generally include a 150lbs driver and you subtract cargo and passengers from the towing capacity.
  4. Jul 22, 2024 at 10:03 PM
    el_turks
    Southern California
    The driver weight is indeed included. You have to subtract the total weight of occupants, this includes Driver and Passengers.
    shakerhood likes this.
  5. Jul 23, 2024 at 12:27 PM
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    More weight to put in... That 4 cylinder will make more effort and stress.. just a thought :anonymous:
    el_turks[OP] likes this.
  6. Jul 23, 2024 at 1:06 PM
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    Incorrect. Payload includes: 1. All people in the truck, including the driver; 2. Anything in the bed of the truck; 3. Anything on the bed of the truck, such as a RTT, camper shell, etc.; 4. Any added accessories mounted on the truck, i.e. anything it didn't roll off the assembly line with, including different bumpers, added winch, added roll bar, added lights, the plastic hula doll on the dashboard.
    Talking about payloads if fine until you realize that 1200 pounds gets eaten away rather quickly.
  7. Jul 23, 2024 at 1:11 PM
    el_turks
    Southern California
    This is the main reason I did not add a decked system to my truck. It's 200 lbs. In my calculations I have 300 lbs to work with.. more than likely that will be taken by Skid Plates and Front bumper.... and thats its...... 1200 payload gone in a heart beat.
  8. Jul 23, 2024 at 1:12 PM
    Want-a-taco
    I misworded my post. What I meant by payload excludes the driver, is that the driver is part of the payload. Whereas generally the towing capacity is with a 150lbs driver and a full tank of gas. Whatever more that the driver weighs over 150 plus cargo and passengers is deducted from the towing capacity.
    Bottom line, don’t exceed GVWR and GCVWR.
  9. Jul 23, 2024 at 1:38 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    If I get a 4th gen some mounjaro is going in the emergency kit.
  10. Jul 24, 2024 at 5:06 AM
    Mad German
    2016 TRD Off Road
    I hope my reply didn't come across as snarky; that wasn't my intent. :thumbsup:
  11. Jul 24, 2024 at 5:07 AM
    Want-a-taco
    No worries. If I thought you were snarky, I would have ignored you and not reply.
    Mad German[QUOTED] likes this.
