To Plastic or Not To Plastic (Seat Backs)
Discussion in 'Audio & Video' started by Snypar, Jan 11, 2011.
  1. Jan 11, 2011 at 3:07 PM
    Snypar
    Snypar [OP] Member
    Fort Worth, TX
    2011 Tacoma DC
    I talked to an engineer yesterday and he recommended REMOVING the plastic on the back of the seats in a Double Cab. Over my head, but he tried explaining that the woofer being that close to the hard surface created 'something dis-pleasurable'. For some odd reason, this sounds reasonable.
    What are your thoughts? Anyone tried this?
  2. Jan 11, 2011 at 3:11 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  3. Jan 11, 2011 at 3:19 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    An engineer told you this? He needs to stick to engineering something else. If your sub is up against your seat well that's what you get, the material of the back of your seat isn't going to make a difference.
  4. Jan 11, 2011 at 3:21 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Our trucks with the JBL sub woofers dont bump that hard anyways so I wouldnt waste my time removing the plastic on the seat back. Now it might be a different story with an aftermarket setup.:cool:
  5. Jan 11, 2011 at 3:25 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    I had to remove mine for my current set-up..
  6. Jan 11, 2011 at 10:04 PM
    Snypar
    Snypar [OP] Member
    Fort Worth, TX
    2011 Tacoma DC
    Clarification:
    This is definitely for 2 ID10's in a custom box. He stated that having that hard of a surface right in front of the sub would reduce its efficiency and sound. Again, I am not an expert, but it kinda sounds like putting a sub right up against a solid wall would do something to its sound, etc. By removing the plastic seat backs, you gain over an inch of clearance and the 'sound' will be hitting the foam and seat material. WTH do I know, if a sub facing a wall of plastic or foam is better.. Thats why I am asking yall's input :)
  7. Jan 12, 2011 at 5:46 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    As long as the subs aren't hitting the plastic (or anything else) you'll be fine. Leave the backs on.
  8. Jan 12, 2011 at 6:07 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Well, why not try it both ways and see what you think? My last sub was an 8" L7 and it sounded better with the plastic in place. My current sub, a 10" ArcAudio, sounds better with it off.
    Nuttin better than real results :)
  9. Jan 13, 2011 at 4:41 PM
    DevL
    DevL Well-Known Member
    If you want it to play with the seat folded, it has to come off. If you want to be able to fold your seats, it will be way easier if it comes off.
