To replace 5VZ-FE valve cover gaskets - or leave them original? Gotta decide ASAP.
Discussion in '1st Gen. Tacomas (1995-2004)' started by timsch, Aug 17, 2024.
  1. Aug 17, 2024 at 8:25 AM
    timsch
    timsch [OP] Member
    I'm in the middle of fuel injector cleaning & rebuilding right now, and I remembered the leaking valve cover issue I've read about. I'm right at the valve covers now, but I don't have any of the gaskets to do them.
    Inspecting the area, there's plenty of black grime all around, but nothing I wouldn't expect from a '98 engine. There are no obvious messy leaks, and I never have oil on the ground below it. I know that now would be the time to do them, but know equally well that if it ain't broke, don't fix it. I really want to get it back together today, both to know how much better it runs (1st time cleaning & rebuilding the injectors, and I seriously neglected the fuel filter for many years), but also because I hate leaving an engine in this condition in my driveway for very long. I could have the gaskets within a week.
    How many years and how many miles are some of you getting before having to replace OEM valve cover gaskets? ~170K on mine.
  2. Aug 17, 2024 at 8:28 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Dude just do it.
    Superdave1.0 and TACOTU3 like this.
  3. Aug 17, 2024 at 8:29 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    the original gaskets on my 5VZFE started weeping at 115k
    replaced...
    they are now starting to be weepy again at 358k
    so almost got 1/4 million miles out of that where i need to get them redone
    yota indy shop quoted me recently it is 900$ :eek: to do them this time around
  4. Aug 17, 2024 at 8:30 AM
    eon_blue
    Azusa, CA
    170k is well beyond when they usually start leaking. You’re already in there, just do them
    Wulf likes this.
  5. Aug 17, 2024 at 8:36 AM
    aaqr18
    aaqr18 Member
    2000 Tacoma 2WD 2.4L Manual Reg Cab
    Replace them. I had to at 297,061 mi.
  6. Aug 17, 2024 at 8:44 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    I’d do em. Parts are cheap and easy while you’re there. I just did them on my 4Runner. But that thing has many more leaks with 320k miles lol.
  7. Aug 17, 2024 at 8:56 AM
    Black97v6MT
    iMA0
    tacoLand USA
    the 4cylinder gasket lasted that many miles :eek:
    impressive!
    aaqr18[QUOTED] likes this.
  8. Aug 17, 2024 at 9:15 AM
    timsch
    timsch [OP] Member
    Alright, I'll do them.
    I know there are cheap options, but I'm not going with the $20 sets off Amazon. OEM sets were ~$250. I found a set online for ~$70 made by Stone, which is claimed to be made in Japan.
    Any experience with this company? Ain't no Japanese sounding name....
  9. Aug 17, 2024 at 9:19 AM
    Black97v6MT
    iMA0
    tacoLand USA
    what Oem set was $250 ?
    what did that include besides just the gaskets
  10. Aug 17, 2024 at 9:27 AM
    timsch
    timsch [OP] Member
    IIRC, that set included the throttle body and intake manifold gaskets. Basically everything that gets removed to get down to the valve covers, including spark plug tubes, gaskets for all of the VC bolts, PCV seal (, etc. The Stone kit was didn't have the intake or throttle body gaskets, but did all the other stuff, so not quite apples-apples, but still....
    JustADriver and Black97v6MT like this.
  11. Aug 17, 2024 at 9:32 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Does the set include the round cam plugs too? Mandatory replacement when opened. Mine were leaking.
    Sterling_vH111 and Superdave1.0 like this.
  12. Aug 17, 2024 at 9:38 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    OP, go yo YouTube and find Timmy the Toolman's video on how to do the valve covers. It has a part list with all the parts/part #'s needed for the valve cover gasket job (gaskets, plug tube seals, PVC valve, throttle body gasket, intake plenum gaskets). Then go to Ourisman Toyota's website and add all those parts to a cart. Take that info to your local Toyota Dealer Parts counter and ask them to price match Ourisman. This strategy works for many and your dealer oughta be able to source the parts by Monday or Tuesday at the latest.
    Cloud99, Black97v6MT and JustADriver like this.
  13. Aug 17, 2024 at 9:45 AM
    JustADriver
    Timmy's video is primarily what I relied on. He explains the job more thoroughly than anyone.
  14. Aug 17, 2024 at 9:46 AM
    Red_03Taco
    Jerad
    Yea his videos are great and sometimes I refer back to them just for parts lists and part #'s
  15. Aug 17, 2024 at 10:42 AM
    timsch
    timsch [OP] Member
    Thanks all for the recommendations and pointers.
  16. Aug 17, 2024 at 10:46 AM
    timsch
    timsch [OP] Member
    yes. Kit includes:
    • 1 PCV Grommet
    • 16 Valve Cover Bolt Seals
    • 2 Cam Plugs
    • 6 Spark Plug Seals
    • 2 Valve Cover Gaskets
  17. Aug 17, 2024 at 10:51 AM
    Red_03Taco
    Jerad
    Buying those parts individually from your local dealer or a dealer that sells/ships online will cost way less than the $250 that kit costs. I'd bet you save at least $100. Make sure to get a tube of Toyota FIPG (black) too
  18. Aug 17, 2024 at 10:57 AM
    timsch
    timsch [OP] Member
    No, that was the $70 kit mentioned above. I got some of that FIPG on order. thanks.
  19. Aug 17, 2024 at 11:21 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Definitely do them. Buy the felpro or mahle kit that includes the spark plug tube seals. Remove, clean and apply RTV to the half moons. Also the cam plugs on the back should really be replaced. They will leak if you don't replace, or at minimum clean and rtv them.
  20. Aug 17, 2024 at 12:13 PM
    Sterling_vH111
    Sterling
    socal
    I did the seals for the spark plugs too, mine were so dry and leaking that the plug shafts were pooling oil.
