To replace gear oil or not to replace gear oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danielsthomas57, May 4, 2018.
  1. May 8, 2018 at 7:10 AM
    danielsthomas57
    danielsthomas57 [OP] Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    What do you mean my neither?
  2. May 8, 2018 at 10:52 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    You asked if you should do now (55k) or at 69k. I would change every 30k and just do it at 60k so its on schedule. Chances are the oil is OK in there. A few thousand miles won’t make a difference. Not unless you tow/haul often or off road a lot.
    I didn’t change mine until 60k (also got mine used). The oil was not in bad shape and I had very little metal shavings in the drain hole.
    BillsSR5 likes this.
  3. May 8, 2018 at 1:42 PM
    danielsthomas57
    Thomas
    Virginia
    I’m at 65k right now
  4. May 8, 2018 at 7:21 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Change them now. It's good peace of mind and you'll feel like you accomplished something. It will improve your self esteem and you'll do better at work. You'll get more sex and generally be in a better mood.
    Yes, I'd say it's money well spent.
    Then......make a sandwich, but I recommend strawberry preserves.
  5. May 16, 2018 at 12:30 PM
    danielsthomas57
    Thomas
    Virginia
    do i need to add a LSD additive ?
  6. May 16, 2018 at 12:34 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    No lsd additive. If you want something affordable, go to Walmart and buy Super Tech 75W90 gear oil, it's like $3.79 a Qt.
    3-4 qts is what you need, not sure on your 2nd gen though, others will tell you.
  7. May 16, 2018 at 12:36 PM
    danielsthomas57
    Thomas
    Virginia
    i believe someone mentioned it would take 8 qts to do all three. front, rear, and transfer.
  8. May 16, 2018 at 12:38 PM
    Grossomotto
    2017 4WDV6LB6MT
  9. May 16, 2018 at 12:40 PM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    I needed 7. Coulda done 6 if i was more careful with my wastage.
  10. May 16, 2018 at 12:41 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  11. May 16, 2018 at 12:46 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I've only ever owned used vehicles and doing a complete baseline is the first thing I do. Maybe maintenance has been done, maybe it hasn't. However if you do a complete fluidectomy, new belts, grease anything with a zerk then there's no question.
    Dennisi01 likes this.
  12. May 16, 2018 at 12:56 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Im going to start working fluidectomy into as many conversations as possible. Thank you.
  13. May 16, 2018 at 1:04 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    If you have the dealer do the procedure it generally results in an extensive, exploratory cashectomy, though. :)
    Dennisi01[QUOTED] likes this.
  14. May 16, 2018 at 1:09 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    190k and still on OEM plugs, diff and tranny oils.
  15. May 16, 2018 at 1:16 PM
    #35
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Maybe I shouldnt have changed mine.. 2 days after changing all fluids and spark plugs, ac takes a crap!
  16. May 16, 2018 at 1:23 PM
    #36
    knottyrope
    Knotty
    Bahstun
    that's how it happens sometimes
    I did rear shocks and front brakes on my 99 taco only to find frame had a huge hole in it a few months later.
    That I4 only had one set of plugs in its 180k miles.
  17. May 16, 2018 at 1:48 PM
    #37
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I had a very wise mentor of all thing old and junk tell me about trucks that as you restore or repair them you need to be looking for the one thing, or perhaps a suite of minor things, that don't irritate you. Your truck is like a significant other in that it wants to have an issue to nag you about. So when you find the broken whatever you can live with just stop, put down the spanner and hoist a beer with your buddies.
    Because when you fix that one last thing then something else will break. So it's balancing act. You have to maintain things, so change spark plugs only after you get a cracked windshield. Wait until you get a door ding to fix that. It goes on and on.
