To roof rack or not to roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oothefuxdis, Jun 14, 2012.
Should I get a roof rack
Poll closed Jul 14, 2012.
  1. YES you'll be glad I have one
    66 vote(s)
    75.0%
  2. NO you'll never use it
    22 vote(s)
    25.0%
  1. Jun 14, 2012 at 1:43 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    If you want to haul long things i say the thule one, that is extendable. I don't have kayaks but i've hauled them just fine in my AC cab. I do have a bed rack thought.
  2. Jun 14, 2012 at 2:45 PM
    cjcarner
    cjcarner Well-Known Member
    Colin
    Savannah, GA
    2011 TRD Sport 6MT DCSB
    Rhino Rack roof rack with an Inno fairing, Snugtop Rebel cap
    I love my roof rack! I have a rhino rack with an inno fairing. No real gas mileage difference or noise, and it looks and works great. Oem won't do much for you though. 100lbs weight limit kinda limits it's usefulness. That's a kayak and a half...
  3. Jun 14, 2012 at 4:00 PM
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    That is gonna leave a mark!
  4. Jun 14, 2012 at 6:38 PM
    oothefuxdis
    oothefuxdis [OP] Well-Known Member
    sure will
  5. Jun 14, 2012 at 8:48 PM
    badger
    badger Well-Known Member
    07 SR5
    That poor woman must have been busted up pretty bad :(
    These threads just leave me scratching my head. Yea sure a rack is VERY useful,.......IF you have something to put in it! Right? If you don't have the need then not so useful right?? I have a rack because I use it, but if I ever quit needing it, it's coming off. The main reason is that they all create drag and drop fuel mileage. They get hung up offroad too.
    I didn't even answer the poll because it's pointless for anyone to tell anyone else they need a rack,...or don't.
  6. Jun 15, 2012 at 3:33 AM
    oothefuxdis
    Pffft..create drag and drop fuel mileage ,I had a Jeep Wrangler before this and that thing had tons of drag (aerodynamics of a brick LOL:D)But I never thought about it gettin' hung up tho.
    Also I just want opinions
    So your kinda a yes, no on this
    thank for your opinion
    Mike:)
  7. Jun 15, 2012 at 4:26 PM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    When theyre in the stowed position (OEM) I can't see how that would that would make much of a diiference in mpg, minimal at most. Gettin hung up on stuff - that's what they make chainsaws for.
  8. Jun 15, 2012 at 4:35 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    Good timing for this thread - I've been thinking about getting the OEM roof rack as well. Paired with a hitch-mounted 3rd point rack it would work perfect for kayaks or other long loads. Anyone priced the cheapest place to buy/install?
  9. Jun 15, 2012 at 5:24 PM
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    I went with OEM + BajaRack and I really really wish this 2nd generation Bajarack was available at the time.
    I haul either two oversize Kamp-Rite Tent Cots for desert trips or one black IM3220 Storm Case for long road trips.
    If money weren't an issue I would remove my current setup and replace it with the 2nd gen BajaRack in a heart beat. The OEM bars just aren't strong enough for my needs. The bow in my bars have flattened out and the ends of the bars scare me. Only a matter of time until they break and with my luck it would be in the middle of the desert.
    Anyone want to buy a slightly used set of OEM bars and a 1st generation BajaRack? ;)
  10. Jun 15, 2012 at 9:08 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    bridaw, you may want to consider craigslisting your roof rack and bajarack. I'd bet you sell them without too much difficulty... Use the proceeds to reinvest in the 2nd gen bajarack. That im3220 case is mighty expensive (at least from my google searches).
  11. Jun 16, 2012 at 8:27 AM
    LaTorre
    LaTorre Active Member
    Joe
    Philadelphia
    TRD Sport
    Aero Turbine Muffler
    Dose anyone like the 2nd gen Frontier roof rack?
  12. Jun 16, 2012 at 8:48 AM
    BlackT4R
    BlackT4R Active Member
    Brad
    Stock 4runner for now but hopefully a Tacoma soon.
    How much for the oem crossbars? My buddy might be interested.
  13. Jun 23, 2012 at 12:47 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    What kinda rack are we talking about?
  14. Jun 23, 2012 at 12:47 PM
    Gotcha88
    Gotcha88 Well-Known Member
    CA
    2012 DCSB PreRunner TRD Sport
    Bilstein 5100s all around, Toytec Eibach coils, Toytec 1.5" AAL, Light Racing UCAs, 285/70r17 Nitto Terra Grapplers, 17x9 Eagle 185s, 20% tint all around, Magnaflow 11256, Cobra CB with 2' Firestik, De-Badged, BHLM, UltraGauge, K&N Drop-in, OEM Bed Mat, OEM All-Weather Mats.
    And what's the point of that?
  15. Jun 23, 2012 at 12:47 PM
    #35
    jandrews
    '09 FourDubDee TRD OR
    Long shit can sit in the bed, stick out and be lashed to the rack, overhanging the cab. Think canoes, surfboards, your mom's dildo, that kind of thing. (chuckle chuckle, it's a joke).
    The 100lb. limit is so Toyota is off the hook if some moron caves their roof in trying to stow a motorcycle up there. I have no doubt it could take more, but I never plan to test it. Why the hell would you want all that weight that high up? Rolly poly.
    I added one just for looks. I don't plan to use it, but it may be useful for future multi-day overlanding journies. I have a daily drive Corolla for fuel mileage, and I would have no problem scratching this thing up a bit on tree branches.
    They complete the look of the truck in my opinion. OP should get one.
  16. Jun 23, 2012 at 5:07 PM
    #36
    bridaw
    Brian
    CYA may be part of it but the OEM bars really can't handle much weight. 100 pounds isn't much and I have probably exceeded that which is why my bars are flattening out and the ends are tweaked. I want that much weight up there because two oversized tent-cots won't fit in the bed with the rest of the gear. Neither will a IM3220 Storm Case -or two.
  17. Jun 23, 2012 at 6:57 PM
    #37
    jandrews
    That stuff weighs in at 300lbs? How big are those cots?
  18. Jun 23, 2012 at 7:30 PM
    #38
    Gotcha88
    CA
    That's what I initially thought, but doubt it based on how far forward he has it and the tonneau he's got. :yawn:
  19. Jun 23, 2012 at 7:38 PM
    #39
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    You dont have an option for, dont have one, but am jelly of those that have them. Because thats me.
  20. Jun 24, 2012 at 12:37 AM
    #40
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    No, it looks like pipes
