To Seafoam or Not to Seafoam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aiello307, Oct 24, 2016.
  1. Oct 24, 2016 at 5:46 PM
    aiello307
    aiello307 [OP] Well-Known Member
    Anthony
    Sheridan
    2012 Tacoma Double Cab Baja
    Stock
    I am curious if many people out there have ran seafoam through their tacos. I used it in my old Dakota, and I still use it in my mower, weed wacker, and chain saw. Turns out my '12 taco is a bit more advanced than my old dakota ever was. I wasn't sure if people have used it then experienced electrical problems' or any such thing. People seem to be totally for it or totally against it. I dig it, but am not sure about running it through an expensive truck.
  2. Oct 24, 2016 at 6:16 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I dont use it as a habit but I did run a bottle through my truck and had no problem.
  3. Oct 24, 2016 at 6:47 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    People who are for it have likely had a good experience, else they would not be for it. People who are against it may have had issues, but in many cases are simply reiterating bad info they've seen on the web. People go on the web and say something is terrible and the next thing you know 1000s are repeating what they've heard with no real knowledge of the issue.
  4. Oct 25, 2016 at 8:17 AM
    tgear.shead
    tgear.shead Well-Known Member
    I really can't see how it would cause ELECTRICAL problems. It goes in the gas tank and/or engine oil.
    Norton likes this.
  5. Oct 25, 2016 at 8:31 AM
    aiello307
    Anthony
    Sheridan
    Stock
    I used to run it through a vacuum line in my Dakota as well. I have a buddy who has a Tundra, and he said on the tundra forums guys were saying it could cause electronic issues. *shrug*. I just wanna dot my ts and cross my i's before I ruin my tacoma lol.
  6. Oct 25, 2016 at 8:39 AM
    Crosis
    Dunedin Fl
    It cant. Thats just urban myth. As you pointed out, something in the gas tank can not cause electrical problems. Maybe fuel gauge or sensor problems but not electrical problems.
  7. Oct 25, 2016 at 8:40 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    I used it in my 2007 Hyundai. I had a heck of a time getting emissions to pass. I ran a bottle of seafoam through the gas tank and then it passed no problem. I'm hesitant to run through the vacuum line unless as a last resort. Otherwise I've had good experiences.
    MTopp likes this.
  8. Oct 25, 2016 at 8:41 AM
    tgear.shead
    The guys on the tundra forum are obviously retarded. Unless you're pouring it over the electrical components, it CAN have NO impact at all.
    Also note that seafoam is pretty simple stuff. Its components are pale oil (diesel), naphtha oil, and isopropyl alcohol. Certainly won't hurt anything at the extremely low concentrations used for mixing with fuel. As far as sucking it straight into the vacuum tube goes, shouldn't hurt anything.
  9. Oct 25, 2016 at 8:47 AM
    Kevmeistah21
    Kevmeistah21 Well-Known Member
    Kevin
    Pasadena, CA
    2015 DCSB TRD SPORT 4x4
    5100/887 LR UCA HS 3-Leaf AAL's SCS Stealth 6's BFG Ko2 285/70/17
    I've fouled an o2 sensor on one of my 240's in the past. Than again, the car had 175k miles on it and was smoking like crazy.
  10. Feb 14, 2017 at 9:01 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I'm working on running a can through my tank right now. had a little smoke at first, but gas needle is falling a little bit slower
  11. Feb 15, 2017 at 12:15 PM
    Toytaco143
    Toytaco143 Member
    Dump it in, it's a great smoke show. :) Freaking the neighbors out is always fun.
    NuckTrutz and Krazie Sj like this.
  12. Feb 15, 2017 at 12:25 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Putting it in the gas tank would be fine, oil okay, but I wouldn't vacuum line it unless its a last resort or you have a justifiable reason to. A 2012 Taco hopefully wouldn't need that. I will probably run some through the tank or another "cleaner" before the next oil change.
  13. Feb 15, 2017 at 12:27 PM
    tgear.shead
    Won't hurt through a vacuum line, just as long as you obviously don't dump it in so fast as to hydrolock the engine.
    Krazie Sj likes this.
  14. Feb 15, 2017 at 1:48 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    When I saw this thread I told myself I was going to keep my "mouth" shut--but you know how that goes...
    Seafoam was developed in the 50s for cleaning out varnish and sludge in marine engines that were run cold (because of cold water) and/or improperly stored during winter (that's the "sea" part in the name). Because it did benefit ill-treated engines it got to be known in conventional wisdom as a "wonder product", and the manufacturer capitalised on that legend.
    It consists (and always has) of high end (more volatile) hydrocarbons (think kerosene, < 95%) and isopropanol (<2 5%)--here is the MSDS--all of which are in contemporary gasoline. It is not needed in any properly maintained engine, nor IMHO is it even desirable. In fact in 70+ years on this planet, 45 in New England and 26 here in Florida, I have never used it (or had any even perceived desire to use it) in any vehicle or other engine I have owned--it is snake oil, admittedly of the finest kind, but snake oil nonetheless.
    The only reason I can think of to subject your engine to it would be if it looks like this inside:
    If used per their current instructions, added to gas or oil, it will likely do not harm; though direct injection via vacuum lines and just dumping it in the intake it has been known to foul O2 sensors and mess with cats.
    You can brew it up yourself for about $1.50/pint--here's how...
    Pray4Mojo, Jimmyh, colinb17 and 2 others like this.
  15. Feb 15, 2017 at 2:07 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I have used it several times without issue in vacuum lines and everywhere else indicated. If you're hesitant to put it in a vacuum line, you could always just install an oil catch can to help keep the top half of the engine clean instead.
  16. Feb 16, 2017 at 7:40 AM
    tgear.shead
    I tend to agree that it likely won't do much good for a regularly operated conventional modern fuel injected engine.
    Probably not a terrible thing to add to fuel in engines that are used infrequently, and especially if the engines have carburetors.
  17. Feb 16, 2017 at 7:46 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Ran it through the vacuum lines on an 07 Tacoma, 04 Tundra and a 2002 Sequoia. Never any issues. Only time was a misfire cause I moved while pouring and one of the cylinders wasn't happy with me. Turned the engine off and back on, CEL never returned.
    Do it and don't look back. There's a fair number of videos that demonstrate it DOES remove carbon from the cylinder walls and piston heads.
  18. Feb 16, 2017 at 7:50 AM
    Geeterman
    Geeterman Dave - THL
    Dave
    2017 Tacoma TRD Off-Road 4x4
    2017 TRD OR 4x4 King Shocks OME Heavy Springs Prinsu Cab and Cap Racks Fuel - ANZA D583 Bronze 17x8.5 -6mm General - Grabber X3 LT265/70R17/10 121/118Q Baja Designs S8 30" Driving/Combo LED Light Bar Baja Designs S2 Pro , Work/Scene LED Southern Style Offroad - Slimline Hybrid w/30" Baja Cutout All-Pro Off-road APEX Sliders Leer 100R Top - WeatherTech Lasercut floormat’s RotoPax - LOX Pack, 2 Gallon Water, 2 Gallon Gasoline GEN2 x2 PowerTrays - Bussmann RTMR REDARC - Dual Input 25A In-vehicle DC Battery Charger
    Anyone else home brew this stuff? Seems too easy, but don't want to make the mistake of going cheap and doing $K of damage to a newer vehicle.
    Maybe I'll try it in my lawnmower first!
  19. Feb 16, 2017 at 7:57 AM
    tgear.shead
    I just looked at that page... gotta love the "2 parts diesel, 1 part gasoline" section. You know, since what that really amounts to, is just "add a bit of diesel to your gas tank". Kinda pointless to add in the gasoline component.
    FYI: the "naptha" oil is commonly available as "coleman camp fuel".
    Geeterman[QUOTED] likes this.
  20. Feb 16, 2017 at 8:09 AM
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    I put a small amount in my lawn equipment and my bikes, for winter storage. Other than that, the only other time I used it was in the head of my Cobalt SS, which was direct-injected and the heads were known for heavy carbon built-up which threw codes etc. I likely wouldn't need to use in my Taco but it won't hurt it, if you do.
    Geeterman likes this.
