To Stud or not to Stud
Discussion in 'Wheels & Tires' started by 450rider, Oct 6, 2013.
  1. Oct 6, 2013 at 11:52 AM
    450rider
    450rider [OP] Well-Known Member
    Oregon
    98 4x4 SR5 Maroon
    Leveling Kit, K&N Filter, Rockford Fosgate speakers, mono block amp, 4 channel amp, capacitor, sub and both amp kits and a Pioneer DVD player By-passed
    I just wanted to get your guys opinion on studding tires. I am going to college where it snows and everything freezes a lot. The tires I wanted to know about were the druatracs. I know they have holes for studs but do you think it would be better to have them studded or not. I also wanted to know if you guys think I should get C or E rated tires. I wouldn't be doing a lot of off roading but I would be airing them down to drive out on sand easier. One more thing, I have to drive over a pass to get home. Thanks for the suggestions
  2. Oct 6, 2013 at 11:55 AM
    Nutzo333
    Nutzo333 FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    Studded hands down. Ive had both studded and non studded and they help more then you'd think. But also with winter, remember its not like mudding... once you start to lose traction, BACK OFF the gas pedal, dont stop on it you'll just make things worse.
  3. Oct 6, 2013 at 6:16 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    X2
    Definitely stud them if it's legal to run them. Do all 4 too. When the tread wears down too far for good snow traction, pull out the studs and run them in the summer...
  4. Oct 6, 2013 at 8:38 PM
    450rider
    Oregon
    98 4x4 SR5 Maroon
    Any recommendation about C or E rated tires? I would be airing them down to go across the sand possibly towing a flat bed trailer with 1-3 quads on it.
