To Supercharge or Not to Supercharge
Discussion in '1st Gen. Tacomas (1995-2004)' started by strikers, Feb 26, 2017.
  1. Feb 26, 2017 at 4:25 AM
    strikers
    strikers [OP] Well-Known Member
    NY
    2003 tacoma dbc 4x4
    S13WL caliper swap 265 75 16
    What's up all,
    Been lurking around tacomaworld. And have done my share of searches. Many have said that supercharging is the way to go and others have said to just change out gear ratios.
    But its 2017 and gas prices have are higher in the tristate area since 2013/14. I understand it's only .30 - .50 more per gallon... but it adds up quick when your driving 110-120 miles, 5 days a week. And then again... I can't get rid of this urge to upgrade my taco for a fun daily driver! (Wish there was a switch that could turn the supercharger on and off)
    Just wanted an up to date opinion from members who currently have a supercharger yota.
    So what's your .02?
    04yota likes this.
  2. Feb 26, 2017 at 4:52 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I'm gonna supercharge my little 2.7. I did the math the other day and it was literally $10 more a tank. To me it's worth the more smiles per gallon :burnrubber:
  3. Feb 26, 2017 at 4:58 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Quick question; what does it do to the long-term life expectancy of the engine?
  4. Feb 26, 2017 at 5:39 AM
    smmarine
    Melbourne FL
    Do it right, and it's not going to affect engine life at all. As long as it's tuned and not knocking, it won't damage it.
    On a side note though, when supercharged, people like to use the skinny pedal more. Obviously, running high rpm and heavy load will wear any engine out faster.
    BohlaaH and DustStorm4x4 like this.
  5. Feb 26, 2017 at 6:20 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Although you're a second gen it may be different, but there was a first gen on here that was supercharged with 300,000+ miles with no problems.
  6. Feb 26, 2017 at 7:22 AM
    1997tacomav6
    Denver
    My engine v6 3.4 was superchargered for 480,000 miles before the head gasket went out, now have
    520,000 miles on my truck all supercharged, the reliability of the the TRD supercharger is unbeatable just like the 3.4 motor, best bang for the ,buck,
    Just do a complete rebuild it Every 150,000 miles.
    DustStorm4x4 and outlawtacoma like this.
  7. Feb 26, 2017 at 7:28 AM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    I love my supercharger. I will say the gas pump sucks. I am lifted with 285's and a heavy pig. I actually bought the sc so I could move the weight up the trail easier. You don't get a sc to save money.
  8. Feb 26, 2017 at 7:29 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    My truck was supercharged for the first 200k and has been turboed for about 5k. You'll lose about 1 mpg average even if you're not in boost. Blowers are just plain inefficient. You'll have to run premium gas and IMO it's still too low of octane. Unless you have another $500-1000 to spend on fueling and know how or are willing to learn how to tune you will have a less responsive mid range with the SC.
    There aren't any long term effects to be concerned IMO. It makes decent power. There is no spool up time compared to a turbo. The system has less points of failure, I.e. its pretty burly and won't give you issues when 4 wheeling.
    It's a pretty pricey set up all in all and despite being a bolt on and common conception if you want to get the most out of it you need quite a few other bolt ons and a fair amount of time to spend tuning. If you're looking to save money on gas look elsewhere. That said I was getting 16/19 mpg supercharged with 32" KM 2's.
  9. Feb 26, 2017 at 2:57 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    The supercharger maybe easier and cheaper, but if you're looking for a "on-off" switch a turbo might be a good idea. You can drive plenty without going into boost and affecting gas mileage substantially. And on the plus side it goes stutututu :D
  10. Feb 26, 2017 at 3:17 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    The fuel hit you'll take (MPG wise) will depend on your driving and your skinny pedal tendencies. On a road trip in my buddies supercharged 04 w/ 285's, it got ~20mpg as long as you keep your foot out of it. Around town though you may expect 13 or so if you're nice to it. In other words, DO IT! :burnrubber:
    strikers[OP] and Clay_916 like this.
  11. Feb 26, 2017 at 4:20 PM
    strikers
    NY
    2003 tacoma dbc 4x4
    Screw it. Didnt need much convincing... It's done. I found a slamming deal on a setup locally. Supercharger, urd kit, and headers for 1500. Will post it up once done.
  12. Feb 26, 2017 at 4:20 PM
    strikers
    NY
    2003 tacoma dbc 4x4
    Is there such thing for a supercharger?
  13. Feb 26, 2017 at 4:43 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Not really since its belt driven, it will always be pushing air into the system
  14. Feb 26, 2017 at 4:43 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Lol that was fast
  15. Feb 26, 2017 at 4:44 PM
    RedManRocket
    Red
    2002 Double Cab LT
    You could get a larger pulley I guess, that way it won't spin as fast until you get on it
    strikers[OP] likes this.
  16. Feb 26, 2017 at 4:56 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Now I want a supercharger :(
  17. Feb 26, 2017 at 5:04 PM
    smmarine
    Melbourne FL
    Doesn't mean it's always in boost though.
  18. Feb 26, 2017 at 5:11 PM
    Workaholic
    Workaholic Well-Known Member
    Simi Valley CA
    97 Tacoma 4x4
    Where the hell did you find that deal
  19. Feb 26, 2017 at 5:55 PM
    strikers
    NY
    2003 tacoma dbc 4x4
    That actually sounds good. But would it be bad for motor or sc?
  20. Feb 26, 2017 at 5:57 PM
    strikers
    NY
    2003 tacoma dbc 4x4
    I said the same thing. How the hell did I find this. Was buying a set of wheels from some guy and starting bullshitting about cars. And he brought up this setup he had laying in garage. He asked me if i was interested before posting it.
    So friggin lucky.
