To supercharge or to not?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Aug 19, 2011.
  1. Aug 19, 2011 at 10:49 PM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    Hi,
    I've been lurking around for a while and just decided to join. I have a 2001 3.4L v6 Prerunner sr5, and for a while i've been wanting to supercharge it. I have a air induction on it right now, which sounds great from the interior. My only concern super charging it is the noise in the interior, alot of people say it can make a whiny sound, or screeching.
    Also what can you realistically expect from supercharging it? I'm sitting at 200hp or so.
  2. Aug 19, 2011 at 10:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!!! Never heard of "Air Induction" as a mod before....care to elaborate?
  3. Aug 19, 2011 at 11:00 PM
    Oat
    Florida
    2001 Prerunner
    Intake* sorry.
  4. Aug 19, 2011 at 11:01 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  5. Aug 19, 2011 at 11:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alright...BIG difference between an Air induction unit, and a "Cold" air intake. If your running a K&N on your 3.4, odds are, you lost power...
  6. Aug 19, 2011 at 11:03 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    How the hell would you lose power? Unless you have to run a by-pass to trick the MAF or you get oil on the MAF sensor... I fail see how a larger surface area of air intake can make you actually run slower? That makes zero sense... at all.
  7. Aug 19, 2011 at 11:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the dyno runs Ive seen on the 3.4 with a K&N intake have had less HP than the OEM air box. Intake surface area :)confused:) Are you talking about the air filter?
  8. Aug 19, 2011 at 11:06 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Search :p. CAI does nothing for first gens. Only a deckplate.
  9. Aug 19, 2011 at 11:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^^
  10. Aug 19, 2011 at 11:09 PM
    Oat
    Florida
    2001 Prerunner
    That's the whine.
  11. Aug 19, 2011 at 11:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AS for the SC sound, its not that obtrusive. Yes, you can hear it. Stock HP is around 150 to the tires (about 155 in your area), and you can expect the SC to bump that to between 190 to 220 depending on the fuel mods, and exhaust/headers combo you run.
  12. Aug 19, 2011 at 11:17 PM
    ludeaddict
    ludeaddict Member
    NorCal
    1996 Tacoma 4X4
    N/A
    I almost bought a K&N CIA from craigslist for $150, but i did some research on this site and decided against it. The deckplate costed me $17 and i will be happy with it I guess.
    As far as supercharging your Tacoma OP i would do it if i had the money. The whine of a supercharger is music to my ears. I guess your MPG would go down and the engine would wear down sooner. Anyone correct me if am wrong on this.
  13. Aug 19, 2011 at 11:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Uh, yea surface area... I've never seen a stock drop in with a larger surface area than a cone type installed on CAI's are...
    There's only two ways I can see a CAI having a power decrease...
    1) The A/F tune is way out of wack
    2) It's not a real "CAI" and is pulling in hot air, thus less dense and nullifying what should be a gain from a larger surface area and easier to breath filter.
    I suppose I can see that being the case on the 3.4... the only experience I've had is with Alex's SC one so... dunno what else to say. All the deckplate mod is allow more air flow to the stock air filter location... which a true CAI setup should be doing the same anyway. Granted, there's the obvious advantage of being able to close the deckplate for water crossings but that's not part of this discussion :)
  14. Aug 19, 2011 at 11:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You shouldnt have any more wear than normal, unless your running much over 8 psi boost. Even then, lots of folks running 10 psi on stock parts. the engine is built pretty strong. MPG hit will depend on how often youre in the boost. I lost about 1.5 mpg (average) when I was SC'd on my first gen, and after about 90k miles, there was no measurable wear on the top end.
  15. Aug 19, 2011 at 11:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The K&N intake pulls the air from under the hood, and is much hotter than when pulled from the OEM set up, thus the loss. The Deck plate allows for air to come in from the front of the truck (high pressure area), and is ambient temp., so you do get a gain. I havent seen a decent intake for the first gens that give any gains, other than the deck plate. FWIW, The larger surface area of the air filter is irelevant. The cu/in of media is more than enough to be virtually invisible to the engine. Dyno runs with the air filter in place, and completely removed, have only shown a gain of about 1 hp (within the margin of error on the dyno). The "restriction" in the intake tract is the air box, and throttlebody.
  16. Aug 20, 2011 at 9:09 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    ^You still have the dyno sheets?
  17. Aug 20, 2011 at 10:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No...My Wife thru most of my shit out a year ago.
