To sway or not???
Discussion in 'Suspension' started by extremachn1, Sep 23, 2011.
  1. Sep 23, 2011 at 3:44 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Every incident besides getting in an accident would result in avoiding points..why would you want to do that?
  2. Sep 23, 2011 at 3:49 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Is this the type of swaybar disconnect system you saw? It doesn't work for 4x4 Tacos because the sway bar will hit the CV boot when flexing.
    You need something that works on the shaft portion of the sway bar:
    I would not recommend removing the sway bar. Try this maneuver with- and without the sway bar. The difference is dramatic:
    http://www.youtube.com/watch?v=aZF8N9NItHI
  3. Sep 23, 2011 at 4:00 PM
    09DC4X4
    09DC4X4 Night In The Ruts!
    Brian
    Southern Maryland
    09 Double Cab 4X4 V6 Auto
    Too much, thanks TW.
    The guy I found on here would only disconnect it while wheelin offroad.
    Yes he carried zip ties with him or you could make some kind of removable chainlink hanger to get it up and out of the way. Myself, I have to leave mine on because of all the defensive driving you have to do around the DC metro area. Idiots and deer in very populated areas. :rolleyes:
  4. Sep 23, 2011 at 4:02 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    its only 6 bolts, if its too bad just put it on and take it off when going off road
  5. Sep 23, 2011 at 4:03 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    If you have stock suspension I would see the point of leaving it on. Stock suspension has a very plush ride. With aftermarket coilovers you are going to have a stiffer ride. I doubt you will feel a difference from stock with the sway bar VS aftermarket without the sway bar
    Also I think if you have to emergency swerve for almost ANY situation you were not paying attention. Animal runs out? You should have been going slower in a place where animals are (IE mountain or forest roads). Kid runs out? Why the F* are you speeding in a residential area? Trying to avoid an accident? You were following the vehicle in front of you too close. Bottom line, drive your truck like a truck and stop thinking its a sports car. Always expect an emergency (sway bar or not) when you are behind the wheel
  6. Sep 23, 2011 at 4:05 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    And that's why you don't swerve for a animal run the little basted over.
    LOL I and honestly say i have never done a maneuver in any car I've ever drove. I watch the road ;)
    i agree with stock suspension taking off the say bar is not a good idea but with upgraded suspension with coils with a higher spring rate you won't even notice it.
  7. Sep 23, 2011 at 4:07 PM
    JLee
    Jerry
    Grass valley CA
    X1,000,000,000
  8. Sep 23, 2011 at 4:16 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    I drive up and down windy mountain roads every day with out mine. Take it off you won't miss it
  9. Sep 23, 2011 at 4:19 PM
    KenLyns
    Belly of the Beast
    When I installed my Icons with 650 lb springs, I busted a ball joint on the sway bar link, so I ran without the sway bar for a while. Steady-state cornering is fine. Then I tried the moose test at 25 mph (about the speed limit in many school zones). The amount of body roll was scary. Put the sway bar back on, the difference was night and day.
    This is like saying you don't need to carry a weapon because you can always avoid trouble. There are enough stupid drivers and pedestrians on the road nowadays, talking on the phone, merging into your lane without looking, etc. Unless you drive only in rural areas where there's no one else on the road for half a mile in each direction, to get anywhere in a reasonable time, slowing down in every area with a possibility of someone jumping in front of you is just not practical.
  10. Sep 23, 2011 at 4:27 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Ok then you keep speeding around and keep thinking your sway bar will save you from accidents. What I do is leave earlier and SLOW DOWN. Your method will fail before mine.
  11. Sep 23, 2011 at 4:33 PM
    KenLyns
    Belly of the Beast
    Actually the sway bar and the truck's torque saved my ass a few times already the last year alone. Slowing down won't help you when a tandem-trailer dump truck decides to merge into your lane after only the first trailer has cleared...
  12. Sep 23, 2011 at 4:36 PM
    09DC4X4
    Brian
    Southern Maryland
    Let's take speeding out of the topic. If it is a daily driver. Leave it on. If it is a weekend wheeler and you drive it slow and steady. Take it off.
    If I can avoid an accident or hitting someone's pet, I will push the trucks limits to the fullest with out rolling it over. The sway bar helps.
  13. Sep 23, 2011 at 5:10 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You'll notice a difference, there's no denying it! I recently had to swerve to avoid an accident and scared the shit out of everyone in the truck……but I knew what to expect and it was fine! You'll get used to it. Not sure how to explain but it's a feeling of over correcting....basically the wheel gets very sensitive and the smallest adjustment will get the body rolling. I don’t drive ridiculously fast anymore and am always aware how the truck reacts. Now when my wife drives that's a different story!
    The new stiffer shocks will help it!
  14. Sep 23, 2011 at 5:12 PM
    97yota4wd
    Eric
    Mesa, AZ
    if you come on the night run saturday take it off and if you dont like it put it back on on sunday. my sway bar is in the trash can
  15. Sep 23, 2011 at 5:29 PM
    #35
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Mine has been off for over a year now. Only time I put it back on is if im driving up to Washington state or something like that. For driving around town, you'll be fine.
  16. Sep 23, 2011 at 5:45 PM
    #36
    97yota4wd
    Eric
    Mesa, AZ
    you suck:(
  17. Sep 23, 2011 at 5:48 PM
    #37
    97yota4wd
    Eric
    Mesa, AZ
    Oh trust me i know. some people in this state deserve a nice avid bumper all up in their trunk/casket
  18. Sep 23, 2011 at 7:15 PM
    #38
    KenLyns
    Belly of the Beast
    On most production cars and pickup trucks sold in the US today, that shouldn't happen unless you hit a curb. The tires should slide before rollover happens.
  19. Sep 23, 2011 at 7:19 PM
    #39
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    that^^^
    i have no sway bar, and am quite top heavy with crap on my roof and above the bed, and my tires just slide before my body starts rolling too far, even with quick turns. where it gets nice and dangerous is when you turn one way and then the other, like in the moose test.
  20. Sep 23, 2011 at 7:21 PM
    #40
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    So your saying if you lived in a world without roads you would take it off??
