??? to the LED guys here???
Discussion in 'Lighting' started by nharkey85, Dec 3, 2009.
  1. Dec 3, 2009 at 11:34 PM
    nharkey85
    nharkey85 [OP] 2yr Old Co-Pilot
    Neil
    Alabama
    08 D-Cab TRD OffRoad
    3" Rev-Tek Lift, N-Fab steps, Aux. Rev. lights, DTRL, Fog light mod
    I know LEDs usually need resistors on them, or at least in the circuit to prevent too high of voltage. would it be safe to assume that if on a curcuit board, incandescent bulbs are replaced by LEDs (component not PLCC or such), that resistors would be needed. this is NOT on a tacoma let alone a toyota. only info i could find for this vehicle was a completely custom setup instead of using factory locations for bulbs. essentially this vehicle uses what looks like the mini twist sockets in our fog light switch and A/C panel (2005+), but they are soldered to the surface of the PCB where the lead of the bulb wraps around the socket. using or not using the socket looks like would make no difference
    Im not asking you guys how to do what i want to do. i already know how to do it. just would like to know bout the resistors
    oh and no i do not have multimeter to test. found my old one stuffed away with batteries all corroded.
    Thanks
  2. Dec 4, 2009 at 9:24 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    yes you will need resistors. Heres how to figure it out. First in the specs of the LED you will see Vf (forward voltage) and IF (forward current).
    Example PLCC2 White LED. Vf = 3.2V IF = 20mA
    First you need to know how much voltage to drop across the resistor.
    V = Voltage at the bulb 12-14V for a car.
    V - Vf = drop across resistor.
    14V - 3.2V = 10.8V (the voltage needed to drop across the resistor)
    Now you need the resistance of the resistor needed to drop that voltage at 20mA (the rating of the LED)
    R = E (V) / I (If of the led)
    R = 10.8V / 0.020A (mA converted to A) = 540 Ohms
    You will need a 540Ohm resistor to get 20mA on the LED at max voltage of 14V.
    Now you need to know what power rating resistor you need.
    P = E (voltage across resistor) x I (Current through resistor)
    P = 10.8V x 0.020A = .216W or 216mW you will need a 1/4 (.250)W resistor.
    Now If you want to put 2 LEDs in series. just add two Vfs together and use that value as Vf in the first equation.
    3.2V + 3.2V = 6.4V Now use 6.4V as the Vf in the first equation.
    Note: always use the high end of your voltage range for this calculation. If you use the low end then at higher voltage you will overcurrent the LED.
  3. Dec 4, 2009 at 10:25 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Holy shit.
  4. Dec 4, 2009 at 12:16 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    x2:eek:
  5. Dec 4, 2009 at 12:29 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    :bowdown:
  6. Dec 4, 2009 at 12:43 PM
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    JEEEEEEZUS CHRIIIIIIIIIIIIIIIST :help:
  7. Dec 4, 2009 at 12:52 PM
    Artiz
    Artiz This space is in BLANK mode.
    I kinda said the same thing...
    EDIT: Oh he's an electronics engineer. :D
  8. Dec 4, 2009 at 1:05 PM
    JM76
    JM76 Ride On
    Jon
    SC
    06 silver double cab 4x4
    seconday air filter removal, tw sticker afe pro dry s filter , black rims , cb radio with four foot firestik antenna,black nasta nerf bars,5100's in the rear,mp3 player hookup,led overhead light,5100's up front @ 1.75, rear AAL,custom dent package,blacked out rear bumper, blacking out front grille,camo gt seat covers , 6k HIDs, 6k fogs coming, devil horns grille mod,elite offroad aluminum bumper,Canadoshi grille mod.light bar behind the grille with bright lights coming sooner or later
    and that tw, is why I do what I do, I just wasn't that good at physics.
  9. Dec 4, 2009 at 3:58 PM
    Artiz
    ^^Dude I love your name.
  10. Dec 4, 2009 at 6:43 PM
    JM76
    JM76 Ride On
    Jon
    SC
    thank you, it's actually in honour of a buddy of mine over in Iraq, that's what he used to call me. Even when he gets back, I don't think I'm gonna change it. :)
  11. Dec 5, 2009 at 5:54 AM
    nharkey85
    Neil
    Alabama
    wow. umm....question answered. thanks that was what i was looking to find out
  12. Dec 5, 2009 at 11:26 AM
    nharkey85
    Neil
    Alabama
    Project complete
    Fruits of my labor. "pink" LED cluster illumination in 2006 Cobalt SS (the GF's, not mine)
    dont mind the date on the pic. camera is an 'antique', stays dead more than not.
    Thank you prerunnerseth. problem free job
  13. Dec 5, 2009 at 9:57 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    basic electronics guys;)
    ....prerunnerseth your a showoff!!
  14. Dec 5, 2009 at 9:58 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    rrriiiiiight.....:D
  15. Dec 5, 2009 at 10:05 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    What's that supposed to mean? :rolleyes:
    I have pink needles and some idiot lights are pink in my truck. :D
  16. Dec 5, 2009 at 10:06 PM
    Untamed_SS
    Adam
    Haughton, Louisiana
  17. Dec 6, 2009 at 8:56 PM
    normbal
    normbal Well-Known Member
    Norm
    socialist occupied Maryland
    White SR5 long bed
    minor mods. Hood moustache, truckchamp SS oval step-bars, Go Rhino Hitch step, popnlock plus tailgate hoseclamp, Weathertech digitalfit floor mats. Wheel and spare tire locks.
    Questions remain:
    - how to take out instrument panel/cluster
    - warranty voided?
    - Anyone do this in Maryland DC-BMO route?
    I would LOVE having blue all around and putting a set under the dash for the cup holders.
    Thanks.
    Norm
  18. Dec 6, 2009 at 9:13 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    1 - here, here and here
    2 - of course (for the cluster only)
    3 - ? couldnt help you there....but i know i have had a guy from vegas and SC mail their clusters to me and i did them. prerunnerseth also does a mail service for gauges as well.
    remember, you cannot change the climate controls area, those have to stay orange per the sandwiched plastic.
  19. Dec 6, 2009 at 9:43 PM
    nharkey85
    Neil
    Alabama
    scouts honor;) this was actually not pain to do, except for removing the painted color filter crap on back of the face. (compared to my damn HU LED swap)
    now for something to ponder....installed LED dome light (in the cobalt), now when in "door" position with door closed it still emits very dim light. swapped with bulb in my truck, same deal????
  20. Dec 7, 2009 at 7:30 AM
    PreRunnerSeth
    Apex, NC
    This means you have some current leakage. Normally not enough to light a bulb. but, with leds its just enough to make it light up a little. My wifes car is the same with with the two map lights for the rear. only way to solve this would be to redesign the circuit with relay.
