To the moon, back, and back again?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tpole, Oct 19, 2018.
  1. Jun 28, 2022 at 6:30 AM
    #81
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Any 4 cylinders get this close to the moon?
    Black97v6MT and 1997tacomav6 like this.
  2. Jul 18, 2022 at 9:39 AM
    #82
    tpole
    tpole [OP] Active Member
    Denver John: Apologies for not responding sooner. You're clock is closer to mine than you think.
    At 706k we encountered a space rock. Said rock ran a red light and t-boned our worthy ship. To our astonishment, rock's insurance company did not total the Taco!
    Now with new fender, door, uca, knuckle, wheel bearing, tie rod, nerf bar, etc. we've resumed our space journey. Will chime in again at 725k.
    BTW, Houston, unsure what a 2002 Taco w/700k is worth, but the damage was nearly $7,000. Amazed it wasn't totaled.
    Out!
  3. Jul 18, 2022 at 10:03 AM
    #83
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Any of you keep track of how much you've spent in gas to drive that far? 700,000 miles at a generous 20 mpg is about 35,000 gallons of gas burned. At today's prices, you're looking at $164,000+ in just fuel expense.
    I've tracked my fuel since day one and I'm at 195k on the ODO and just over $28k in fuel. Crazy to think I'm just $4k away from spending as much on gas as I did on the truck.
  4. Jul 18, 2022 at 10:18 AM
    #84
    mbeers6
    mbeers6 Well-Known Member
    East bay, ca
    03 tacoma double cab 4wd
    Air filter
    I'm at 225,000 and given prices of used newer truck I'll be keeping it for a while. Such a good truck that has never broken down.
    1997tacomav6 likes this.
  5. Jul 18, 2022 at 8:52 PM
    #85
    1997tacomav6
    Denver
    Wow, that’s amazing it wasn’t totaled, so glad you got it put back together and your ok more importantly.
    We should be hitting 725k around the same time I’m guessing now
    ab_1280 and Black97v6MT like this.
  6. Dec 30, 2022 at 6:54 PM
    #86
    1997tacomav6
    Denver
    @tpole
    Just passed 725k,
    Had a front wheel bearing making some noise and replaced,
    Had a few days with temps down at -20 below,
    Everything is still good ,
    Hopefully your right around the corner and back up to speed
    See you at 750k
  7. Jan 1, 2023 at 5:41 PM
    #87
    calhoun34
    calhoun34 Well-Known Member
    The Great Plains
    1999 Taco/1978Chinook mod
    So apparently my '99 with 238,000 is just getting broken in. :bananadance:
  8. Mar 29, 2023 at 12:07 PM
    #88
    tpole
    Denver John:
    You passed me! I just hit 725k yesterday.
    All well with the Taco, I did manage an in-flight TPS replacement in December.
    Keep the Tacos flying!
  9. Sep 22, 2023 at 6:01 AM
    #89
    1997tacomav6
    Denver
    Glad she's up and running again,
    We upgraded the old supercharger for the new Tvs1320 supercharger last month and running strong,
    Had a axle pinion bearing go south so we tossed in an elocker
    See you at 775k
    Over and out! :)
    Keep flying
  10. Feb 13, 2024 at 4:53 AM
    #90
    tpole
    Houston:
    Delighted to report we've safely entered our second lunar orbit.
    Conducted a mid-flight timing belt/water pump change, and we wonder if that will be the last one for this spacecraft?
    Supercharged Denver John's taillights are just ahead.
    We'll again break radio silence when we hit 775,000 on your side of the moon.
    Hope everyone back on earth had a great deer season.
    Keep the Tacos flying; over--
    Black97v6MT, Tuluk, ztwatson and 6 others like this.
  11. Feb 13, 2024 at 5:20 AM
    #91
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m not worthy at 176k but I’m trying!
    ab_1280, Black97v6MT and 1997tacomav6 like this.
  12. Mar 26, 2024 at 7:40 PM
    #92
    1997tacomav6
    Denver
    Glad you’re back up to speed! We are cruising in 5th with no events to post. Everything is running on point.
    Timing belt service and related parts will be on my list soon too.
    Just crossed 775,000 in 5th.
    Kinda hard to imagine that I’m saying that 800k is my next check in !
    Stay safe!
    ab_1280, Black97v6MT, 01x4 and 2 others like this.
  13. Mar 28, 2024 at 2:43 PM
    #93
    TRoss1
    TRoss1 Member
    Wow that's amazing!
  14. Mar 29, 2024 at 5:26 AM
    #94
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    Impressive! I'm in my 40s and I don't have enough years left in my life to get my 176k '03 to 700k !! Nice work folks - I could hit 650k by the time I'm 80 -- Guess I need to drive more...
  15. Mar 29, 2024 at 9:40 AM
    #95
    tpole
    Which one of you orbiting goobers failed to tell us about these?! My spacecraft thinks they're kinda nifty:
  16. Mar 29, 2024 at 5:35 PM
    #96
    1997tacomav6
    Denver
    haha, yup,
    I got mine at 700,000 now will be getting a 800,000 soon
    Black97v6MT likes this.
  17. Mar 29, 2024 at 5:40 PM
    #97
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    I'll shamelessly echo others here and say I love seeing it.
    (About to crack 100K)
    1997tacomav6[QUOTED] likes this.
  18. Jan 3, 2025 at 10:50 AM
    #98
    1997tacomav6
    Denver
    @tpole tpole
    800k milestone hit! Hit at 80mph!
    Time for full timing belt service and going to replace heads because of a tiny head gasket leaking a few ounces every oil change.
    Will check back in at 825k!
  19. Jan 3, 2025 at 10:57 AM
    #99
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    I love this thread, congrats on the HUGE milestone
  20. Jan 3, 2025 at 2:02 PM
    #100
    ab_1280
    ab_1280 Well-Known Member
    Alan
    2000 Silver Tacoma TRD 4x4 3.4L V6 X-Cab Manual 413K
    I agree, love seeing this. I'm 3/4 home from my trip back...at 411,000 on mine. (v6 manual 2000 Xtracab 4x4 TRD off road)
