To tie or not to tie, that is the question
Discussion in 'Boating & Fishing' started by 5nahalf, May 5, 2021.
  1. May 5, 2021 at 5:19 PM
    5nahalf
    5nahalf [OP] I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I am going to start using some flouro leader and am curious what you guys do for attaching it.
    Ive always used wire leaders, and they always come with a swivel on one end and a clip on the other end, but I picked up a spool of 60lb flouro leader and want to make something for myself.
    So, should I tie the leader to my braid, then tie it to the bait? or should I match how my wire leaders have always been with the clip and swivel. I was thinking of making up a few 12 inch leaders and just tossing them in my bag.
    The water I normally fish is crystal clear, so thats why I am switching to flouro.
  2. May 6, 2021 at 5:43 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I use a 8-10 lb seaguar flourocarbon leaders with a small ball bearing swivel rigged to my regular stren line...never used braided except for ice fishing tip-ups. I guess it depends what your fishing for. Less the fish can see the better especially in a crystal clear lake as here. I never use wire leaders unless fishing for large pike, or walleye.
    5nahalf[OP] likes this.
  3. May 6, 2021 at 5:46 AM
    zoo truck
    None
    Forgot to say all my fluorocarbon leaders are at least 18''-36' long...some even more depending whats rigged to them.
  4. May 6, 2021 at 5:50 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I always use swivels.
    mtip, zoo truck and 5nahalf[OP] like this.
  5. May 6, 2021 at 7:14 AM
    5nahalf
    Erik
    Minnesota
    So I tied a leader last night, heated the tags to make a mushroom, it seems pretty strong, but my god do the knots look like they will come undone real fast (I have been pulling on them hard and they seem solid)
    Im going to try to make a few more tonight and test them to see what knot I can tie the best. Maybe I should of gotten the 30lb flouro instead of the 60lb. I might order a crimper so I can just make crimp connections instead of tying.
  6. May 6, 2021 at 10:12 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    my spinning rod has braid. I used a flouro leader. a long ass leader so it needs to go thru the rod-guides smoothly. I use the Alberto Knot. easy to tie and strong. I have had one knot come loose but that was my error, and I felt like a turd. tying in wind, and in a hurry = no good knot.
    I use a LONG leader because it make sense to me. I might clip off my drop shot and switch to a wacky worm, and then clip that off and try a Ned, back to drop shot. you lose length as the day progresses. especially with a dropshot rig. I rather not retie that Alberto (I have many times successfully) while bobbing around on a kayak, being blown into the treeline...
  7. May 6, 2021 at 10:14 AM
    aficianado
    back to bone stock.
    60LB leader?! what are you fishing for? what is the mainline strength?
    my braid is 15lb and I am running 8lb leader.
    Gunshot-6A and zoo truck like this.
  8. May 6, 2021 at 10:16 AM
    5nahalf
    Erik
    Minnesota
    Northern pike with the leader. I have 20lb braid on most of my rods. I chose 60lb flouro because I have no clue what I am doing with flouro leaders :) I should of gotten smaller, but figured 60lb should handle the teeth pretty good.
    Most of the things I read said 50-80lb for pike.
  9. May 6, 2021 at 1:19 PM
    zoo truck
    None
    Nothing can piss one off more than lots of line twist...good ball bearing swivels as small as possible are best.
  10. May 6, 2021 at 1:24 PM
    zoo truck
    None
    I've caught 20 lb + pike in northern quebec on 10 lb monofilament line with a wire leader no problem. I'm not a big believer in these braided lines unless fishing places where your likely to get hung up often.
  11. May 6, 2021 at 1:25 PM
    5nahalf
    Erik
    Minnesota
    Last year I broke off so many times on mono that I ended up switching a few of my reels over to braid. Sofar no breaks on it, but it sure does tangle up worse.
    tcjacado likes this.
  12. May 6, 2021 at 1:38 PM
    aficianado
    back to bone stock.
    I love the hook setting power of braid. its why it is only on my spinning where on a good day, I can cast far. my baitcasting distances are very vanilla. flouro works fine
  13. May 6, 2021 at 1:41 PM
    5nahalf
    Erik
    Minnesota
    That is something that I like with the braid, when I get a bite, I feel it right away.
  14. May 6, 2021 at 1:47 PM
    Fohu
    Fohu Well-Known Member
    Glade park Colorado
    2019 trd or access cab
    I fish strictly braid with no leader. Mostly for trout in Utah.
    Me and my buddy usually fish identical set ups. Mostly long lining a rapala or shad rap in rainbow trout colors behind our kayaks. Only difference is he uses strictly 10-12# fluoro and I use a 6# moss green braid
    We usually have the same amount of hook ups. so I’ve basically givin up on the whole fish can see my line bs.
    I’ll stick to strictly braided line and not lose any lures lol.
    edit. I know that doesn’t really answer the question but I tried doing leaders and couldn’t tell a difference so I gave up on em
    knayrb and 5nahalf[OP] like this.
  15. May 6, 2021 at 1:54 PM
    the_great_white
    the_great_white Well-Known Member
    I use uni-to-uni to tie braid to fluorocarbon and the Palomar for fluorocarbon to hook/lure, etc.
    Sudsman44 likes this.
  16. May 6, 2021 at 2:27 PM
    aficianado
    back to bone stock.
    super interesting!! I would have imagine trout were the most line shy.
  17. May 6, 2021 at 2:33 PM
    5nahalf
    Erik
    Minnesota
    Trout by me are dumb and aggressive. They are all stocked trout, I was catching them last fall on bass jigs (skirted jig with a craw trailer)
  18. May 6, 2021 at 2:39 PM
    aficianado
    back to bone stock.
    oh..no, I backpack for native CA trout. we did a 10 day, 9 night backback trip to a lake. well, we took a mule train up and backpacked out. there is a lake up there, I swear the trout never seen a kastmaster spoon. I was using some fancy 3-lb line my friend gave me. the fish wouldn't totally commit to my cheap 4'lb, I respooled with 2lb I had packed with me. I got trout, but I couldn't hork them up onto land, so he tied on a top shot of his 3-lb fancy stuff and it was like trout-appalozza. I don't even see 3'lb line.
  19. May 6, 2021 at 2:46 PM
    Fohu
    Glade park Colorado
    I can also say I ventured deep into the seirra Nevada’s backpacking for 10 or so days chasing the elusive golden trout.
    Me and my girlfriend both hooked into a couple with. You guessed it some moss green braided line no leader. Using a tiny little pink squid maybe 1/64 ounce
  20. May 6, 2021 at 2:49 PM
    Fohu
    Glade park Colorado
