To tow or not to tow...
Discussion in 'Towing' started by Tacoguy1984, Aug 2, 2019.
Can I tow a trailer that's 5308lbs dry?
  1. Hell ya!
    33.3%
  2. Definitely Not!
    66.7%
  1. Aug 15, 2019 at 9:38 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’ve done a bunch of math and scratching as we plan our purchase. Decided that ~4200 dry is about as high as I’m willing to go. Download one of the towing spreadsheets and look up all the weights. GVWR, CVWR, etc and put them in the spreadsheet. You’ll find you probably run out of cargo capacity before towing capacity. By the time I was done, I had 100lbs of cargo left and 1100 lbs of towing left.
  2. Aug 15, 2019 at 9:39 PM
    RushT
    North Texas
    Long bed probably tows a little better, but also probably has a little reduced capacity.
  3. Aug 16, 2019 at 5:23 PM
    cc-rider
    cc-rider Well-Known Member
    2019 Quicksand TRD OR
  4. Aug 17, 2019 at 9:00 AM
    Mac Attack
    Mac Attack Member
    Andrew
    Texas
    2008 Blue V6 SR5 PreRunner
    None
    Thanks for that
  5. Aug 17, 2019 at 9:23 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    A wise man who (used to happily camp all over the west) told me that dividing the "rated" truck towing capacity by 2 and using that to match the new trailer dry weight - or choose a truck - was a safe start to make a choice. We made a bad choice on one pair of outfits and regreted the result.
    Aquatic Tacoma likes this.
  6. Aug 19, 2019 at 9:20 AM
    Super Guest
    Super Guest Active Member
    Adam
    2019 Tacoma TRD Sport
    Use caution when dealing with the RV salesman, in my experience as a first time camper, they are worse than car salesmen and will try to upsell you every step of the way. The first place we looked at tried talking us into a 28ft trailer with a dry weight of 6200 and gross of like 7500-8000 and said it would work if we traveled light lol.
    In the end we got a Jayco 184bh that has a max weight of 4k. Which my truck, with the manual transmission, pulls very nicely. And gets 10-13mpg towing in New England. But something to consider is how much stuff you actually need for these trailers, its essentially a small house so by the time we had ours all set up with everything, and you put in the cooler, the grill, food, and clothes, i would be my trailer weighs closer to 4300-4500.
  7. Aug 19, 2019 at 2:22 PM
    cc-rider
    SG, totally agree about the salesmen. We went to several RV/Travel Trailer dealerships over a period of time and kept getting pushed into bigger trailers. We bought our 2017 Passport 175BH earlier this year for about 8K less than a new one and it has been fantastic. The taco pulls it easy.
  8. Aug 24, 2019 at 4:56 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I suggest that you read everything you can find on towing weights, payload and tongue weights then do the math for your situation. You’ll quickly realize that the above mentioned Palomino is too much of a trailer for your tow vehicle.
    Leave yourself some wiggle room. Don't try to tow the max. You won’t be happy.
  9. Oct 28, 2019 at 6:16 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    How do you like the 184, I'm currently looking at the 174?
  10. Oct 29, 2019 at 6:58 AM
    Super Guest
    Adam
    For a first/starter TT, I would say it's great. It's only my wife, baby, amd a dog and we fit very comfortably. My only complaint would be there's not enough outside storage room but not the end of the world. If you do purchase either the 174/184, do yourself a favor and immediately buy a mattress pad, what comes on it from the factory is worse than sleeping on the floor.
    We did go on a trip with six adults which resulted in us being very cramped but that was to be expected. We also looked at the 174 and found it to be a little too small for us, the 184 has a slide out for the dinette which really opens it up. After a summer of towing it all over CT, i'm glad i didn't go any bigger the truck pulls it perfectly, save for when you have to back it into a space and it requires 4lo to do it. That would be the only downside of this truck when towing is reverse, its too tall of a gear. I cant speak for anyone else, but i don't expect to go 45mph in reverse anytime soon lol
  11. Oct 29, 2019 at 11:19 AM
    RushT
    North Texas
    2lo mod... probably the best bang for the buck for you.
  12. Nov 4, 2019 at 3:39 AM
    Cnasianfire
    Cnasianfire Well-Known Member
    Charles
    Wilmington, NC
    2015 Tacoma TRD off road DCSB
    BFG KO2 285/75/16 ~2" lift (5100s and block)
    Just got a 195rb jayco and loved the way it towed. What were your transmission temps while towing? Also, why would you have to go into 4lo to back up? Did you take the sway bar off before you backed up?
  13. Nov 4, 2019 at 3:53 AM
    Super Guest
    Adam
    I have the manual transmission so i haven't been monitoring the temp when towing. I dont think the issues with reverse have anything to do with a rear sway bar; reverse is a very high gear ratio so trying to push the trailer in reverse it struggles. But once in 4lo, no issues at all.
    xxTacocaTxx likes this.
  14. Nov 4, 2019 at 3:54 AM
    Cnasianfire
    Charles
    Wilmington, NC
    Missed the manual transmission part! Lol.
  15. Nov 4, 2019 at 3:58 AM
    #35
    Super Guest
    Adam
    The m/t was probably 95% of the reason I bought the truck lol
    Cnasianfire likes this.
  16. Nov 4, 2019 at 1:00 PM
    #36
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    2019 i4 prerunner ......... question is
    what is the difference in mounting a standard OEM receiver hitch to the i4 prerunner ??????
    the dealer was not encouraging
    yet Trucking Thunder has hitch that will fit ..... install
    on a i4 or V6
    im aware of weight etc................1 bmw moto
    no 5th wheel
    nothing more than 1500lbs total
    i like the sanitary OEM look & installation on the V6 prerunners & 4x4s
    please enlighten / explain
    thanks
  17. Nov 7, 2019 at 12:52 PM
    #37
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    19FLB Hideout 3800lbs dry. Tows great, WD hitch and friction sway bar help a lot.
  18. Nov 7, 2019 at 12:55 PM
    #38
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Not to worry, you will likely end up in a ditch a few miles from picking up that trailer so both the truck and the trailer will be in the shop most of vacation.
  19. Dec 27, 2019 at 1:10 PM
    #39
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    If you're just going to the camp ground an hour away... that's fine.
  20. Jan 31, 2020 at 1:41 PM
    #40
    My13isnice
    My13isnice New Member
    2013 white tacoma sr5
    3" lift
    Hey everyone I have a 2013 SR5 tacoma with a little 2.7L 4 cyl with a 3500lb tow cap. I am looking at a camper with a dry weight of 2990. I dont intend on pulling the camper with water weight or much cargo at all. Just the camper. Does anyone have or know someone who has 2.7L tacoma and how hard would it be for my truck to pull this camper
