To tow or not to tow...
Discussion in 'Towing' started by Tacoguy1984, Aug 2, 2019.
Can I tow a trailer that's 5308lbs dry?
  1. Hell ya!
    33.3%
  2. Definitely Not!
    66.7%
  1. Jan 31, 2020 at 2:24 PM
    #41
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    It will tow it fine. The big question is how far.
  2. Jan 31, 2020 at 4:26 PM
    #42
    My13isnice
    My13isnice New Member
    2013 white tacoma sr5
    3" lift
    Hello steadfast. It will most likely be towed withing 20 miles about 4 times a year but may want to tow it up to 500 to 600 miles once a year also because a good friend has a campground near myrtle beach
  3. Jan 31, 2020 at 4:34 PM
    #43
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A 2990 dry weight trailer with a 3500 lb tow capacity is cutting it closer than I like. You will be well over 3000 lbs and maybe over your 3500 lb limit with anything in the trailer. And you still have to account for the weight of passengers and cargo in the truck.
    specter208 likes this.
  4. Jan 31, 2020 at 4:54 PM
    #44
    My13isnice
    3" lift
    Where do I find the actual weight of a 2013 tacoma sr5 access cab. I know the gvw but not the actual weight of the truck
  5. Feb 1, 2020 at 5:17 PM
    #45
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Towing a trailer to the max rating of a Tacoma I think is realistic for trucks being used as work vehicles . (Single driver pulling heavy cargo on trailer). For a family vehicle towing a TT, I think a lighter trailer is more suitable because you will need to leave room for your wife and kids, plus your supplies and fuel.
  6. Feb 1, 2020 at 6:40 PM
    #46
    My13isnice
    3" lift
    Thanks guys I found out today from a toyota dealer that between the weight of the truck(3335) plus an estimate of 500 to 600lbs for driver passenger and luggage, it only leaves room to tow about 2500 to 2600lbs before you reach maximum combination weight so it is not actually plausible to ever pull the 3500 tow capacity without being liable if something was to happen
