To warm up or not to warm up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slow TURD I4, Nov 30, 2018.
  1. Nov 30, 2018 at 5:09 PM
    slow TURD I4
    slow TURD I4 [OP] Well-Known Member
    SD
    2018 DCSB 2.7
    Do you guys let your trucks warm up in the morning before you drive off?Or do you slap it in the gear and disappear? I know back in the day engines needed to be warmed up due to different clearances in the engine but now that engines are more precisely made I don't know if letting it warm up is doing it more harm than good because of the fuel injection letting in more fuel to the combustion chamber while the engine is under operating temp and possibly causing the oil on cylinder walls to "clean" off prematurely. Any ideas??
  2. Nov 30, 2018 at 5:12 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    so I think it's more of an oil issue now than a combustion issue (ECU can adjust the combustion mixture).......it typically takes between 30 and 60sec for the oil to fully cycle through the crankcase.
    So I'd say let it warm up for at least a minute to get that oil circulating, summer or winter, and then you're god to go. That's what I do with my truck
  3. Nov 30, 2018 at 5:13 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    I let mine warm up for a few minutes enough to make sure the oil is circulated and coating all the parts. 0w20 is pretty runny even in cold temps.
    Now I also drive slowly until it heats up to operating temp (no hard acceleration etc.)
  4. Nov 30, 2018 at 5:16 PM
    Mechazawa
    Mechazawa Active Member
    2019 Tacoma TRD Sport 4x4 short bed
    I let mine warm up every morning just because my ass gets cold easily and I have to work at 6am.
    SuperBad, Bridge4, FastEddy59 and 6 others like this.
  5. Nov 30, 2018 at 5:17 PM
    slow TURD I4
    SD
    2018 DCSB 2.7
    yea i do the same. I cringe when people dont warm their vehicles up haha
    FastEddy59 and BSFord[QUOTED] like this.
  6. Nov 30, 2018 at 5:17 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I usually let mine warm up until I hear the evap-system hiss sound. Usually takes about a minute.
    Jckdnls likes this.
  7. Nov 30, 2018 at 5:18 PM
    phsycle
    phsycle Well-Known Member
    CA
    No. Not necessary. Start and go. Drive conservative until temps are normal operating range.
    People forget other parts also need to warm up. Driving conservative let’s the WHOLE truck warm up.
  8. Nov 30, 2018 at 5:23 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I just start mine up, buckle up, look around back up, put in drive and drive moderately for a few miles or until fully warm before I put the hammer down
    And don't forget that all other vehicles components need to warm up like shocks, springs, rear end and such so you'll want to drive moderately.
    Cheers!
    Herniator, Jckdnls and SilverBulletII like this.
  9. Nov 30, 2018 at 5:24 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    I let it warm till I hear the engine idol out .
  10. Nov 30, 2018 at 5:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It all depends on how cold it is. Anything above +20° really doesn’t need more than a minute or two max.
    skierd likes this.
  11. Nov 30, 2018 at 5:25 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    I like to crank mine and floor it. The engine gets up to operating temperature much quicker when it’s bouncing off the rev limiter.
  12. Nov 30, 2018 at 5:29 PM
    The hammer
  13. Nov 30, 2018 at 5:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Yeah for sure, you get a little more launch speed with the starter motor still engaged as you peel out of the driveway.
    CaptainBart45 and BlakeM[QUOTED] like this.
  14. Nov 30, 2018 at 5:39 PM
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    This^^. Letting the cats warm up and letting the O2 sensors get to operating temperature is a safe bet. Also gets the oil flowing.
    CusterFan likes this.
  15. Nov 30, 2018 at 5:43 PM
    The hammer
    If in doubt, just read the manual
    thewarriordinghy and shakerhood like this.
  16. Nov 30, 2018 at 5:45 PM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Mine gets 10-15 minutes when it gets below freezing.
    I like to see the temp gauge move some before driving.
    FastEddy59 and cshrum like this.
  17. Nov 30, 2018 at 5:48 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I let mine warm up until it comes off high idle and goes to a normal mixture of air and fuel. Not because of oil as it's viscosity is fine, and, my ass likes a warm cabin. Boom.
    su.b.rat likes this.
  18. Nov 30, 2018 at 5:49 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Start it, give it 30 seconds while you buckle up and find a good song on the radio, then drive gently until it's at operating temp.
    Doesn't matter if it's -30 or 140 degrees
    Slick Taco, ian2016, LTG4087 and 2 others like this.
  19. Nov 30, 2018 at 5:53 PM
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    Work with a guy who literall gets in his Tundra, starts it and then just goes. Doesn't even bother to wait. I just hear my dad in my head, "WTF ARE YOU DOING?!?!"
    motodude95 likes this.
  20. Nov 30, 2018 at 6:01 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    My routine goes like this.....clear enough snow to open door.....turn truck on....heat on to HI fan to top speed....seat heaters ON.... close door and clear the rest of the 24" of snow off of rest of truck....unfreeze the wipers....
    Done.... put her in drive and go slowly...…… In the old days the nylon tires would be square....I'd be going down the road with the truck bouncing.
    I still have to go 3-4 Kms to get any heat, but mu Butt is warm.....:thumbsup:
