Tocama manual on iPhone
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 45longcolt, Apr 4, 2010.
  1. Apr 4, 2010 at 11:53 AM
    45longcolt
    45longcolt [OP] Well-Known Member
    DFW Area
    08, Double cab, 4WD, Off Road, Tow,
    I had downloaded the Tacoma manual in the zipped form. Had it stored on my computer for use as needed. I found an App called Pocket Scanner for the iPhone. It allows wireless transfer of files to and from your computer. You can make folders and store them in there or transfer them at will. I decided to upload my entire Tacoma folder I have on my computer. It was 1.3 GB in size. The App handled it just fine and uploaded it to my Tacoma folder on my iPhone. Then the program does zip and unzip and the program also displays HTML pages, the same format the manual is in. I now have my complete Tacoma repair and wiring manual on my iPhone for reference at any time. It doesn't get much handier than that. :)
    Screen shots to follow later.
  2. Apr 4, 2010 at 11:55 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Hmm not a bad idea... where did you find get the zip from though, through Toyota or other.. 'means'. I wouldn't mind throwing that on my Droid, along with the full tech service manual :D
  3. Apr 4, 2010 at 11:58 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I'd love to get a copy of that manual.
    Cheers.
  4. Apr 4, 2010 at 12:37 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    x3, I would love to get a copy! I have an 09. I imagine it would be about the same.
  5. Apr 4, 2010 at 12:48 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    The app is $0.99 on iTunes.
  6. Apr 4, 2010 at 2:24 PM
    747 function > form
    1st Gen.
    That's awesome!
  7. Apr 4, 2010 at 4:55 PM
    45longcolt
    DFW Area
    Get the App from the iTunes store, Pocket Scanner, the Document one as there are two named close to the same. One is for business cards. Learn to use it, it will connect to a browser window wirelessly on the same network. Make a folder in the Pocket App program called Tacoma Manual and once you have the file transferred to the .pdf document section just copy the zipped file to the folder named Tacoma Manual. Press edit and highlight the file and press "Zip" and it asks if you want to unzip it, answer yes. Takes a few minutes but then you have the files/folders unzipped and clicking on the "Index" file starts the manual. :) PS. Youcan also start the manual by pressing on LOCAL FILES and then pressing REPAIR or WIRING. When you go back it does not go all the way back out.
  8. Jun 11, 2010 at 11:18 AM
    mugenrios2k
    mugenrios2k Active Member
    :annoyed: I need the 2010 ECU pinouts:rant::rant::rant:
