Today I was disappointed in tacomaworld -- AMR500
Discussion in 'Performance and Tuning' started by soggyBottom, Oct 21, 2023.
  1. Oct 21, 2023 at 1:38 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I'm really disappointed and surprised that no one has tried to put dual AMR500 superchargers on a Tacoma. Many of you if not all of you are going to say it's dumb and blah blah blah. I would argue, there are far worse things on here.
    Each one can easily flow 150hp. Getting one shipped for under $200 is why I'm thinking this isn't the dumbest idea. Is it as good as a Magnuson? No, of course not, but it's $400/pair.
  2. Oct 23, 2023 at 1:53 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Be the first. :D
    SUMOTNK likes this.
  3. Oct 23, 2023 at 1:57 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Ok, de-stroke a 2.4 or 2.7 to be in its efficiency range and let us know how it goes.
    Torspd and soggyBottom[OP] like this.
