today went out to the truck and the starter wouldnt kick over
Discussion in '1st Gen. Tacomas (1995-2004)' started by swsteven, Sep 10, 2010.
  1. Sep 10, 2010 at 4:43 PM
    swsteven
    swsteven [OP] Well-Known Member
    houston tx
    2001 tacoma trd
    3 inch lift bilsteins and aal 16 inch pro comp wheels, m/t tires
    well today i was getting in my 01 tacoma v6 pre, starter took a dump ,well I had to go to work so i took out my L bar and beat it ,it started so i went to work and bought the rebuild kit for it at toyota , i took it apart and rebuild it and put it back in the truck , now its good as new ,wooohooo ,
  2. Sep 10, 2010 at 4:48 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Cool story bro!
    But seriously, mine did that when it was cold. Replaced the plunger and it was perfect.
  3. Sep 10, 2010 at 4:48 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Lots of people don't realize you can rebuild these starters for cheap. Good job!
  4. Sep 10, 2010 at 4:48 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    How hard was it to remove? It looks like a Pain in the ass to get out. How long it take to rebuild the solenoid.
  5. Sep 10, 2010 at 6:19 PM
    swsteven
    houston tx
    2001 tacoma trd
    parts cost me 40 bucks baby !!, pretty easy to do , dont need car lift , first take off negative battery cable , go to right side fender wel and loosen 12 mm nut on side of starter , and then unclip the plug under starter ,crawl underneath truck by trans and u will see 2 14mm bolt and loosen and your done , when u rebuild ur starter you pretty much just change the copper contacts inside , take ur plunger you will see copper around it and sand it down till you see it shine
  6. Sep 10, 2010 at 6:20 PM
    swsteven
    houston tx
    2001 tacoma trd
    o yea wen u get the starter loose you take it out from under truck not out the engine bay
  7. Sep 10, 2010 at 6:40 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
