toilet flapper
Discussion in 'Garage / Workshop' started by coffeesnob, Jul 4, 2013.
  1. Jul 4, 2013 at 11:29 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    replaced my toilet flapper with a new one but the darn tank still loses it's water. The chain isn't kinked, filler hose, valve, float all seem to be where they are supposed to. The lip the flapper seats on is smooth and free of any knicks etc..whats next?
  2. Jul 4, 2013 at 2:28 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Is the water still running? It could appear seated, but still not, make sure the flapper is chained to the right "link" on the "flusher arm" thing. I've encountered this before and just had to give a little more slack in the chain..
  3. Jul 4, 2013 at 2:39 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    05 double cab SR5 4x4
    TRD air filter, exhaust tip, tinted windows, upgraded grill, OEM LED tail lights, LED DTRL'S, Matts 123 skid plate, 4Runner Mirrors, 17 inch OEM 4runner wheels
    If it's a old toilet it could have a crack in the overflow pipe or seat where the flapper seals but you don't see that a lot, if it's a newer 1.6 gallon model make sure you have the right flapper some of them are lager than the old type. I would try a different brand flapper and see if that helps and keep about 1/2 inch of slack on the chain.
  4. Jul 4, 2013 at 3:50 PM
    coffeesnob
    VA
    yest it is a 1.6 gallon flush. I put some stop cock grease on the flapper and it appears that it is sealed correctly. I will take your advice and try a differe3nt flapper tomorrow when I get out.
  5. Jul 29, 2013 at 8:58 AM
    zilla68
    zilla68 www.okledlightbars.com
    Moore,Oklahoma
    I'm going thru this also right now, can you tell me what it is your talking about with this grease?
    I replaced the whole unit, pulled the tank and all, and am still getting a slight amount of seepage.
  6. Jul 29, 2013 at 5:51 PM
    toyotaman29
    Darrell
    North Carolina
    Hey, if you replaced the whole flush vale it could be the fill valve leaking through, i like the fluid master pro valves, you can test the flapper by putting some type of dye or cake food coloring in the tank and let it set for a few minutes and if turns the bowl that color, you know it's the flapper or your chain is to tight lifting it up some. If it didn't turn colors in the bowl, then replace the fill valve and check the small over flow tube to be sure its not too far down in the over flow pipe, that can let some water trickle down that pipe, hope this helps.
  7. Jul 30, 2013 at 6:20 AM
    zilla68
    Moore,Oklahoma
    I replaced the flapper and the fill valve and everything else. I did put cherry kool aid in the tank and it did turn the bowl red, so its got a little leakage, but the kit I bought has everything in it including the handle. Chain is loose and adjusted correctly, that's why I'm at a loss.
    I have the fill valve adjusted to stop about 1/4 inch below the little overflow pipe.
  8. Jul 30, 2013 at 5:04 PM
    toyotaman29
    Darrell
    North Carolina
    That sounds like the flapper is not sealing like you said, sometimes you get one that will not seal good, you could try a different brand flapper some are made of a softer rubber or vinyl and see if that helps.
