Toilet thoughts about incremental oil changes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by risethewake, Dec 1, 2024.
  1. Dec 5, 2024 at 8:28 AM
    #41
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    All my VWs had incremental oil changes. About a quart every couple months.
  2. Dec 5, 2024 at 10:45 AM
    #42
    TacoTuesday1
    SD CA
    some people to reduce wear put an accumulator to provide good oil pressure at initial cold start. And heaters.
  3. Dec 5, 2024 at 6:09 PM
    #43
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Looked into this extensively and so far have decided against it as the accumulator itself + extra connections are extra points of failure. If they blow under pressure & leak all the oil out, that's bad™.
  4. Dec 5, 2024 at 7:00 PM
    #44
    TacoTuesday1
    SD CA
    haven’t heard of one fail but then again it’s typically on race cars not daily driven. And they have one or more fire suppression systems, driver wearing fire retardant suit, etc.
    I wonder if dry sump helps at all even if only 50% of the effect. For example many Porsches that still do track days I believe don’t have accumulator but are dry sump.
    Potentially allows for more oil, thinner oil pan and lower engine for balance, separate reservoir, etc
  5. Dec 5, 2024 at 7:05 PM
    #45
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    I’ve had many old Volkswagens and Audis over the years, they never died, they just got lower. They never leaked, they just marked their spot.
  6. Dec 5, 2024 at 7:21 PM
    #46
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    O
    Would this amount to perpetually running with 80% dirty oil?
