Told I need a new rear end
Discussion in '1st Gen. Tacomas (1995-2004)' started by BowlTurninHiker, Jun 22, 2021.
  1. Jul 7, 2021 at 2:36 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Did you ever change your gear oil. Just asking because I changed mine, and hoping mine stays good.
    Black97v6MT likes this.
  2. Jul 7, 2021 at 3:28 PM
    BowlTurninHiker
    BowlTurninHiker [OP] Member
    Middle TN
    2002 White Tacoma Double Cab TRD
    OME suspension kit
    750ml thanks for the info. I will definitely give them a call.
    Potomus Pete I did change the gear oil, but not as often as I should have
  3. Jul 7, 2021 at 7:15 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    East Coast Gear Supply would be a great source to get new diff from. I regeared my truck last year, and chose send mine to them, then receive them back. But you can also order a new set, then send yours in as a core. Turn around time then was 2 weeks, and total all in cost was $1500 IIRC. So, if staying with the same ratio, just the rear should be sub $1k, plus the cost of new wheel bearings and seals are about 200ish (for OEM). That being said, the cost of parts would be extremely less than what you’ve previously been quoted.
  4. Jul 7, 2021 at 7:45 PM
    750ml
    750ml Active Member
    A.
    2001 Tacoma
    235/85r16 Toyo Open Country AT3's, 4.88 Yukon gears, Eaton Trutrac front and rear, 2" lift
    Hudlow Axle went through both of my axle housings, replaced bearings and seals, did a regear with Yukon parts and added Eaton Trutrac differentials front and rear while they were in there. They also replaced the ball joints, and some other worn out front end parts, as well as the flywheel and a new clutch. The truck felt like a new one when they finished. It's a been a year and their work has held up. Their reputation seems to be stellar.
  5. Jul 7, 2021 at 8:51 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Right after mechanic quoted those prices, he probably said "I'll give you peanuts for your truck", being the nice guy and all.
    Black97v6MT and nagorb like this.
  6. Jul 7, 2021 at 9:04 PM
    beignet
    beignet Well-Known Member
    Ben
    1996 3.4L 4x4 Tacoma
    I just had a rear end rebuilt on my '96. Cost was just a hair above $900 for just a replacement of all the bearings in differential with the Timken kit. Kept the ring & pinion as they weren't in bad shape. This was in NYC, the land of inflated pricing. Paid a little extra for all the axle work (bearings, seals, etc) to be freshened up as well.
    Even though I was at a dedicated driveline shop they still griped about what a pain it was to work on a Toyota differential. As @jbrandt mentioned, your mechanic might have given you the "I don't want to do this" price.
    Nevertheless, as others have mentioned, you can buy a complete third member for not a lot.
  7. Jul 7, 2021 at 9:50 PM
    Five
    Five Well-Known Member
    My current milage is 420,700. Just did an oil change yesterday.
  8. Jul 8, 2021 at 12:42 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I was thinking exactly this.
  9. Aug 11, 2024 at 8:13 PM
    Bcramer
    Bcramer New Member
    Brian
    2012 black Tacoma trd off road
    ???? my mechanic gave me a quote of 2.7k to inspect and re gear
  10. Aug 11, 2024 at 8:26 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    For one or two differentials - ie are you 4x4 with two or 2wd with one.
    That’s crazy. You could get two brand new fully assembled diffs with any gearing you want from East Coast Gear Supply with a 5 year warranty - shoot you could almost get an ARB in one and an open diff in the other for that price. Then you just install them or have a qualified (probably not the shop you took your truck to) do it. Here’s the diffs for your 2012.
    https://eastcoastgearsupply.com/c-1065072-assembled-3rds-clamshells-05-15-tacoma.html
  11. Aug 11, 2024 at 8:32 PM
    Bcramer
    Bcramer New Member
    Brian
    Ya I’m 4x4 with a rear locker. 3k just for the rear diff and thanks for the link. I appreciate it. Ya I thought 3k was way too much for that. I wouldn’t want to spend 3k on a truck with 260k miles lol because who knows if the trans or engine may happen to go out. If engine goes out ls swap time lol
