Toluene and Xylene
Discussion in 'Technical Chat' started by soggyBottom, Dec 31, 2018.
  1. Jan 9, 2019 at 9:28 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  2. Jan 9, 2019 at 10:00 AM
    Pyrotech
    Pyrotech Well-Known Member
    Sugar works pretty well for the tripoli guys. you did not mention the oxidiser used... so I left that out
    aluminium powder and Pban which also acts a fuel.. in solid fuel motors again just the fuel...
    hydrazine and liquid hydrogen, among others in liquid fuel motors
  3. Jan 9, 2019 at 4:26 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Toyotas 1GR can actually put out slightly more horsepower with just a change in higher octane. The knock sensors are always reading the harmonics of the combustion and together with the ecu it will always try to advance the timing according to the available octane. Toyota actually tuned the motor to run on 91-93 octane. But can safely run on lower octane.
