Tom Woods Drive Shaft
Discussion in 'Suspension' started by Dick Proenneke, Sep 20, 2013.
  1. Sep 20, 2013 at 7:43 AM
    Dick Proenneke
    Dick Proenneke [OP] Well-Known Member
    Edmonton, Alberta
    2013 TRD Sport 4X4
    OME 3" Lift with DAKAR'S, LR UCA'S, ECGS Bushing, Leer Cap, 18" Dick Cepek Torque', Duratracs, custom drive shaft, etc!
    Gonna pull the trigger on a Tom Woods double cardon one piece drive shaft to get rid of my take off shudder. I've tried everything: CB drop, StreetTacos bracket, OME drop, shims, etc. I just want to confirm if anyone has had a problem with their TW DS, or if the general consensus is that it's a good fix.
    lynyrd3 likes this.
  2. Sep 21, 2013 at 1:25 AM
    Man Overboard
    Man Overboard Member
    2005 SR5 Prerunner
    Don't do it, rip off
  3. Sep 21, 2013 at 4:42 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    My buddy ran one on his taco and loved it. He had no vibes and had tried all the things you listed as well.
    lynyrd3 likes this.
  4. Sep 22, 2013 at 9:04 AM
    ATHiker
    ATHiker Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    if you get one, give us some feedback.
  5. Sep 22, 2013 at 11:13 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Do you have one?
  6. Sep 22, 2013 at 11:43 PM
    bzzr2
    bzzr2 Well-Known Member
    Try it, if it doesnt resolve your issues they will let you return it.
  7. Sep 22, 2013 at 11:53 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    I have a single piece. I had it made for by a local shop. You may be able to do the same for less money. Mine resolved my vibe issues and the overall loss of ground clearance from removing the cb is minimal.
  8. Sep 23, 2013 at 2:29 PM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    I have ordered the shaft, which should ship today. I'll submit some feedback once it's installed.
    My local shop quoted me $800-$1000, but I'm in Edmonton, Canada, the land of oil, where you pay twice as much, for half the quality, and you have to wait in line.
  9. Sep 23, 2013 at 3:17 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    :thumbsup:Have the exact same one. Took care of vibes
  10. Sep 24, 2013 at 11:31 PM
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    those are crazy prices. Definitely better to order. as long as your measurements are on you shouldn't have any problems.
  11. Sep 30, 2013 at 10:31 PM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    I installed the Tom Woods today. Silky smooth up until 50 mph, and then I start to get vibrations. Ahhhhhhhhhhhhh!
    I think I'm gonna put my two piece back on, unless I can sort out a fix.
    Edit OCT 1:
    OK, I measured my pinion angle relative to my new TW drive shaft. It was 1.8* with 350 lbs in the back. That is what I had in the back when I tested the drive shaft. I took out 180 lbs (Set of LT tries) and the vibrations were cut in half. I measured my drive line angle at 1.5*. I took out all the weight in the back, and the vibrations were reduced another 50%. Drive line angle of 1.2*. TW said the pinion has to be at 0* relative to the DS. I have a 3* shim in, so I'm gonna up the shim to 4* and see what I get. BTW I have DAKARS which are very stiff and don't allow for a lot of pinion movement. Otherwise the TW drive shaft is very nicely finished and fits well on the truck. I absolutely want to keep it if I can.
    lynyrd3 likes this.
  12. Oct 2, 2013 at 7:25 AM
    ATHiker
    Tom
    Tennessee
    I am very interested in the results as i am considering a TW drive shaft.
    lynyrd3 likes this.
  13. Oct 8, 2013 at 12:07 AM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    Well I took off the TW shaft, and put my two piece back on. I could not get it to stop vibrating at 50 mph+. I tried 2*, 3*, & 4* shims. Stripped my u bolts on the last change and had to buy new ones. With 4* shims it was 0.4* off neutral to the shaft. Vibes are even worse under load. Too bad, I was hoping it would fix my problem. Now I have to eat $200 in shipping, back and forth to TW.
  14. Oct 29, 2013 at 7:40 PM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    I took the TW one piece to a local shop and they said that the TW shaft was too heavy for it's length, being all steel. That's why it was constantly vibrating at 50 MPH despite the pinion angle. I sent back the TW and got a full refund. My local shop built me a one piece aluminum shaft, and I am now vibration free!!!!!
    lynyrd3, snox31 and Sicyota04 like this.
  15. Oct 30, 2013 at 4:42 AM
    ATHiker
    Tom
    Tennessee
    Photos and pricing??????
  16. Oct 30, 2013 at 9:38 AM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    Price was $925 (CDN) installed, but I live in Edmonton, Alberta, so prices are higher, than in the US. Pics at a later time.
  17. Oct 30, 2013 at 11:59 AM
    ATHiker
    Tom
    Tennessee
    Are aluminum drive shafts normal or did you have to go to a speciality shop to get it fabricated? Looks like we have the same truck and issues.
  18. Oct 30, 2013 at 12:21 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    i have one.. smooth as glass.. when i called TW they said almost 100% of customers got rid of take off shudders/shakes as well as slow down shudders/shakes but some picked up a minor vib at high speed (70 or more)
    mine is smooth everywhere... seems to be the pattern with everyone i asked before i bought mine. WELL worth the $$
  19. Oct 30, 2013 at 2:01 PM
    Dick Proenneke
    Edmonton, Alberta
    2013 TRD Sport 4X4
    I don't know if they are normal, however my drive shaft shop said they have been building a lot of them for the full size truck crowd. Edmonton is the land of lifted trucks (Oil field), so they have a fair bit of experience up here, I guess. Mine is quite smooth now. Straight one piece with no CV at the TS.
  20. Oct 30, 2013 at 2:25 PM
    gearcruncher
    Canadain bumper technician
    Single piece driveshafts can cause a whip issue but usually happens over 60 inches in length . I havnt crawled under my double cab to measure my two peice but I beleive its under the 60 inch ( 5 foot ) guidleine that driveshaft builders follow . Guessing this is why Toyota used the 2 peice ? are we over 60 inches in total length ?
    When cancelling driveshaft angles , 3 degrees is the max for a single universal joint on either end of a driveshaft to cancel each other out , anything above 3 degrees is far too much for a regular single universal joint . Havnt spent enough time researching what the driveshaft does when we have weight in the back of the box . Does the slip yoke bottom out at the end of its travel with a lot of weight ? that would amplify a minor vibration .
    I would be looking at axle wrap and road force balancing the tires
    lynyrd3 likes this.
