Tom Woods Driveshafts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VibratingTaco, Jan 2, 2020.
  1. Jan 16, 2020 at 1:34 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Yes, have a boat so tow a lot and load equipment in the back but then I have OME Dakars.
    If you have stock springs they can sag down to the stops so that's a good point on TW driveshafts and clearance with stock junk Toyota rear springs.
    Maybe that's why Toyota used the center bearing to begin with as when I first put my TW shaft in and towed the Tacoma dropped to the stops and seems like on hard bumps the driveshaft hit the top of the tunnel at the center bearing mount but not the mounting bracket so I got the Dakars - never sagged or hit again in many years.
    Bottom line is I would replace the rear springs as they are the cause of the axle wrap that causes the vibrations to start with and as the center bearing wears that multiples the effect. 5100 shocks helped me too.
    PHTaco, MTopp and lynyrd3 like this.
  2. Jun 11, 2021 at 9:58 AM
    Setherson
    Setherson Member
    Seth
    UT
    2009 TRD Offroad DCSB
    2 inch lift: old man emu coils, Bilstein 5100s, AAL 17x9 -12 mm XD Machete wheels, 265/70/17 Grabber ATXs Tom Woods one-piece driveshaft ECGS bushings Leer cap
    @muddog321 Been doing some research on the TW one-piece driveshaft to cure the take off vibes. I pulled the trigger and it's arriving tomorrow. I'm wondering if you have had any additional issues with yours? After purchasing, I became a bit more hesitant about hitting the driveshaft's critical speed. With the one-piece I think this will occur around 85 mph. Granted, I'm not driving that often, but I have hit 85-90 mph when passing. It also sounds like axle wrap is the cause. How are the OME Dakars holding up? Did you go with the medium or heavy duty option?
  3. Jun 11, 2021 at 10:27 AM
    muddog321
    FL
    100k on the TW 3.5" shaft with 1350 U-joints and no problems. Have the driveshaft installed with the slip joint on the transfer case end for better rock protection while many mount it the other way around. The Dakars ate the rear spring hanger poly bushings and got a clunking so replaced them with OME yellow same as came with - note rear was in salt water with my boat and bushings did not like that and probably the mud and sand that floated in there too. Funny the lower rear spring hanger and front both have stock Toyota rubber bushings and they are fine. Pulling a 26 foot trailer trailer for awhile too and that didn't help. Dakars only came in heavy duty I believe when I put them in and with towing and a shell plus some tools rides OK. As for the critical speed at 100mph had no issues but normal cruising is at 75mph. Off to Moab in a few weeks from FL for a 2000 mile run each way and no worries at 168k now.
  4. Jun 11, 2021 at 11:01 AM
    Setherson
    Setherson Member
    Seth
    UT
    Thanks for the info. I’ll see how the one piece bolts up and hopefully fixes my vibrations. I think Dakars might be next to hell with the axle wrap. I’ll keep the OEM bushings in mind.
  5. Jun 11, 2021 at 6:13 PM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Just ordered mine-be here next week. You need to get the over all length flange to flange and the dimensions at each end for the bolts (C to C in both directions). Takes 5 minutes under the truck. Their default is the U-joints with zerks. Give them a call once you have the measurements... they are easy to talk too, know their stuff and will answer any questions as well as do your order.
  6. Mar 23, 2022 at 11:36 AM
    BigKahunas15
    BigKahunas15 Well-Known Member
    Dan
    Prince George B.C, Canada
    Black 2015 TRD 4.0l 6MT
    Bilstein 6112 HD Dakar leaf pack CBI sliders and custom bed rack 295/70/17 Geolander MT G003
    Looking into this solution. let me know if this fixes the vibrations fellas :popcorn:
  7. Mar 23, 2022 at 1:40 PM
    drewnali
    drewnali Well-Known Member
    Drew
    Dunnellon Florida
    2013 4X4 SSM TRD OR DCSB
    Definitely fixed my vibrations. Do it!
    BigKahunas15[QUOTED] likes this.
  8. Mar 23, 2022 at 2:53 PM
    muddog321
    FL
    1 piece solution has been around and discussed since the 2 gen first appeared to have a driveline/spring problem so guess you like to wait and be sure (since 2005).
    I'd follow the insane 100s of ways to fix the stock junk for a while more. Could not resist, sorry.
    Chris(NJ) likes this.
  9. Mar 23, 2022 at 4:20 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    Solved all of my original vibration issues. I have since created more fixing other stuff. Seems Taco's want to vibrate...
  10. Mar 24, 2022 at 6:24 AM
    BigKahunas15
    Dan
    nice buddy way to be. I forgot to go back 17 years and research every possible solution....
    I dont lurk the site like some people. Just wondering if other people had a positive outcome. Havnt spent a dime chasing the vibrations and want to know what might be the best option. Not sure why that would trigger somebody else lol :crazy:
  11. Mar 24, 2022 at 7:05 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Many other benefits to it than just potentially eliminating vibes. I like mine. Would recommend. But I still get occasional vibes between 50 and 60.
  12. Mar 24, 2022 at 7:10 AM
    BigKahunas15
    Dan
    What are the other benefits? I guess removing un-needed parts is a bonus. I understand that modifying my truck will cause unseen issues, I just want to get the vibrations to a point where I dont need to think about it anymore. I certainly dont expect it to ride like a caddy haha
  13. Mar 24, 2022 at 7:12 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yup. Get rid of the stupid center support bearing. Drop some rotating weight.
    Musubi3 and BigKahunas15 like this.
  14. Mar 24, 2022 at 7:27 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Gee I wonder why Toyota uses a two piece drive shaft? Because it's more expensive maybe? I can't say for sure if this maybe an issue but there are frame lifts that have a center mount arms they had issues bending single piece drive shafts because the rear had enough drop that the shaft touched the lift. Frankly it maybe be easier to figure out why it has vibrations The 2 piece shaft is used to keep the drive shaft from pulling out on extreme axle movement putting a shim block in on a single shaft could in turn make it possible for the yoke to bottom out in the trans case bad juju just saying.
  15. Mar 24, 2022 at 7:55 AM
    #35
    4wdExplorer
    4wdExplorer Well-Known Member
    Orange County, CA
    Doesn't the one piece driveshaft hang lower than a 2 piece? Thats my only gripe. I would do a cardan two piece. But what do I know? I dont have any vibes with the stock shaft.
  16. Mar 24, 2022 at 8:43 AM
    #36
    pearing
    Wisconsin
    2015 SR5 quadcab
    There are other things to try first: 2-3 degree shims seem to help lots of people. Carrier bearing drop as well. I was going to start and work my way through teh list and just said why spend all the time and money when "I think" a one stop solution "that made sense to me" would work. So I jumped. The price is not high, in my opinion for what you get. I my case-your mileage may vary-it solved every vibration issue I had (40 mph shudder and another at 61mph.) I have since caused some to come back (trans service... never should have bothered and big tires...)
  17. Mar 24, 2022 at 9:38 AM
    #37
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes it has to because the front is flat to the floor basically, but the angle is much less and it's a lot shorter.
  18. Mar 24, 2022 at 10:34 AM
    #38
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Did you end up cutting off the supports for the carrier bearing?
    Anyone ever know if it's an issue with the TW drive shaft hitting the carrier bearing support (if left in place) while off-roading or under full compression? The clearance seems like it would be close to hitting, but that's just my general measurements.
  19. Mar 24, 2022 at 11:09 AM
    #39
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Nope. No need. There was plenty of room
    Musubi3[QUOTED] likes this.
  20. Mar 24, 2022 at 12:04 PM
    #40
    pearing
    Wisconsin
    2015 SR5 quadcab
    I left mine in. It is really close. It will come out this summer because this truck is never going back
    Mine is close at full compression, but doesn't hit. I am taking it out this summer as the truck is never going back...
