Tongue weight
Discussion in 'New Members' started by Rogersstarr, Oct 31, 2024.
  1. Oct 31, 2024 at 11:50 AM
    Rogersstarr
    Rogersstarr [OP] New Member
    Lisa
    23 Tacoma 4wd blue crush
    Remote start
    I’m looking for the tongue weight of my truck. I’m looking to purchase a hauler for my husband’s electric wheelchair that weighs 320 pounds. I’ve looked in the manual and have been unable to find it
    buckhuntin-tacoma and HondaGM like this.
  2. Oct 31, 2024 at 12:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There should be a sticker on the hitch. It may be on the bottom side. I'm pretty sure the hitch is rated for 500 lbs.
  3. Oct 31, 2024 at 12:17 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Oct 31, 2024 at 6:26 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome aboard!
  5. Oct 31, 2024 at 6:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Tongue weight is usually 10% of towing, so 600 lbs max, but stay under 500 lbs for sure.
    With 320lbs + carrier it will squat hard and "float" in the front. It's fine, but with heavy weight hanging its not ideal.
    I would recommend a simple solution called "sumo springs"
    https://superspringsinternational.com/sumosprings/
    They have some videos you can watch, it basically stops the rear from squatting only when loaded. Most truck/trailer accessory shops can supply or install them.
