Tonneau and bed mat weight?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jetspeed, Jun 20, 2021.
  1. Jun 20, 2021 at 3:40 AM
    jetspeed
    jetspeed [OP] Well-Known Member
    MD
    19 TRD Sport DCSB 4x4 Manual Taco
    I know one of you psychos actually weighted the factory tonneau and bed mat. What numbers did you come up with?
    it's petty, but the truck feels more lively w/o those two installed and I like that feeling, except under heavy braking in which, it I like them there.
    Thanks all, Happy Father's Day.
  2. Jun 20, 2021 at 3:46 AM
    tcjacado
    tcjacado Well-Known Member
  3. Jun 20, 2021 at 4:11 AM
    jetspeed
    MD
  4. Jun 20, 2021 at 4:21 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I think this is between your ears. Can you tell a difference in performance when a passenger is riding with you vs when you're in the truck alone? Not exactly sure how much the cover and mat weigh, but it would be about the same difference. I have a cap, that weighs about 180 lbs. There is no difference with or without it.
    jasmits1, JustJon and RedWings44 like this.
  5. Jun 20, 2021 at 4:37 AM
    WRREGL
    WRREGL Well-Known Member
    North Alabama
    2018 TRD sport
    Work in progress
    This!! Not enough weight difference to make a difference.
    RedWings44 likes this.
  6. Jun 20, 2021 at 4:50 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    My Bakflip G2 weighs 73 lbs. Between the Bedrug bed mat and my oval step rails, maybe another 45 lbs max. If I could feel a performance difference after these were installed I'd be concerned that the truck would react negatively to such a small weight addition. I don't feel a thing. You shouldn't either. All that said, a very happy Father's Day to you as well :thumbsup:
    Barsoom likes this.
  7. Jun 20, 2021 at 5:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All i know theres gotta be at least the weight of a grown adult between the factory tonneau cover and mat. The cover itself really needs 2 persons to remove and install it.
  8. Jun 20, 2021 at 5:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    100# + /- 10%
    Prove me wrong.
    PS. 10# of wt loss = about 1hp gain. So taking off 100# is similar to adding 10HP.
    Think about that when considering a 'build'. Or when heading into a burger joint.
  9. Jun 24, 2021 at 9:08 AM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    The OEM bedcover is around 60LBS. The Rubber mat is around 10lbs. So, 70lbs just sitting in the back does make it ride a tad different. My guess is you are feeling the suspension having a tad more bounce bak without the 60 - 70 pounds of weight. I notice the same thing.
  10. Jun 24, 2021 at 4:47 PM
    zoo truck
    None
    I don't think so...between both its much heavier. My mat alone had to be at least 30 lbs.
  11. Jun 24, 2021 at 6:08 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Bed mat is around 40 lbs and the tonneau cover from factory is a little more I think.
  12. Jun 25, 2021 at 7:45 AM
    zoo truck
    None
    I'll agree with the bed mat weight, but the factory tonneau cover on my truck is one heavy sob.
  13. Jun 25, 2021 at 8:00 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Would you show web links for your formula?
    http://hpwizard.com/rotational-inertia.html
    10lbs of rotational weight (wheels) roughly equates to 100lbs of chassis weight.
  14. Jun 25, 2021 at 8:29 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    I remove the factory tonneau by myself all the time. I would bet it weighs maybe 50 lbs max.
  15. Jun 25, 2021 at 8:40 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
  16. Jun 25, 2021 at 8:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's just a weight to HP ratio calculation. The reason I said 'about' is because it can vary sightly depending on what was started with.
    Obviously wt reduction doesn't create HP, it just 'feels like' there is more HP. And it's a real feeling, because the wt/hp ratio has improved.
    The 1 HP number I used was based on my SCCA days running stock a stock powered Miata. Even Mazda engineers were always looking to 'add lightness', in search of grams.
  17. Jun 25, 2021 at 11:09 AM
    Westsideott
    Westsideott Well-Known Member
    Ottawa, ON
    2020 DCSB OR
    My back estimates the factory cover to be 55-60lbs.
