Tonneau Cover and Bed Liner Recommendations
Discussion in 'Tonneau Covers, Caps and Shells' started by Rocketrob, Mar 6, 2011.
  1. Mar 6, 2011 at 3:53 AM
    Rocketrob
    Rocketrob [OP] New Member
    Rob
    Cincinnati
    11 SR5
    I just purchased a used 2011, 4x4, SR5 package. It has a factory bed liner but I kind of wanted to upgrade to a sprayed in liner - probably Line-X but would consider others. I called the local Line-X and they said that they don't do Tacoma's unless you special order a steel bed. I tired Rhino but they didn't answer. Any recommendations would be appreciated - I was thinking about just getting a good bed mat to go over the basic liner that came with it???
    I also want a Tonneau cover - willing to spend $500-600. There are so many options - 2-fold, 3-fold, etc. Since I don't have any experience with any of these I would love some advice.
    Many Thanks, Rob
  2. Mar 6, 2011 at 7:02 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    I use the Fold A Cover GS on my 2011 DC. It works great, also with a pop n lock, it secures the Bed.
  3. Mar 6, 2011 at 7:11 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    if you want a hard tonneua i got the undercover one and love it....alot of other members have it too.
  4. Mar 6, 2011 at 7:22 AM
    nyfishhunter
    nyfishhunter Well-Known Member
    Sean
    White Plains, NY
    2010 DC 4x4 OR Pyrite
    Weathertechs, Pop N Lock, Whitetail Sockmonkey, OEM bed mat, Undercover SE, Wet Okoles, OEM iPod interface, Rear Spring TSB, Illuminated 4x4 switch, DTRL, Timbrens, 5100s (front .85), Eibachs, 1.5 AAL, OEM running boards, FJ TRD center caps, diff breather mod, trimmed front flaps, ImMrYo mirror bracket, Grillcraft, painted white Sport grill black
    A bed mat is a must-have and much cheaper than a spray-on liner. With the plastic bed, you really only need to keep things from sliding. The OEM one has done a great job for me.
    I also second the Undercover tonneau suggestion and I believe there may still be a few for sale on the forum. It keeps thing locked-up and can easily be removed when an open bed is needed. My 11 year-old helps me remove and re-install mine. It is not waterproof, but I only get a little water in one of the front corners - even in car washes. I doubt you can find a totally waterproof one.
  5. Mar 6, 2011 at 7:09 PM
    cu52
    cu52 Well-Known Member
    Rocky Mountains - Denver
    2009 Crewmax Tundra Limited
    I am really happy so far with my Access Limited roll up tonneau. I need access to the full bed with what I haul. A hard tonneau would not work for me.
  6. Mar 6, 2011 at 7:28 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    There isn't a bed liner in the truck. The actual bed is made of a fiber composite material. Most people just put a toyota bed mat or deezee bed mat in for some traction/protection.
  7. Mar 25, 2011 at 5:32 PM
    mike sacc
    mike sacc Well-Known Member
    r.i.
    2001 tacoma reg cab, 2009 tacoma dble cab shb
    undercover all the way. installs easy and it comes off in 2 min. you can do it alone and it comes with hangers that screw to the wall. i have two, they lock and dont need paint.
  8. Mar 25, 2011 at 5:35 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    x2 on the oem bedliner. :thumbsup:
  9. Mar 26, 2011 at 5:20 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Bed mats are really nice to keep stuff from sliding around in back; I used 5' wide roll of stall mat for mine... $25 from Tractor Supply and about 1/2 hour to trim it around the wheel wells. There are nice $100 bed mats available from Toyota if you really have to have the Toyota symbol on it.
    I can't see any reason for rhino-lining the composite bed. Would serve no purpose I can see.
    I got a tri-fold soft tonneau: it self-stores to carry tall stuff, and is really easy and light to remove for big loads. Roll-top tonneaus generally get rolled up and never put back out because they are such a pain to work especially in cold weather.
    Hard tonneau's are the most water tight, some more than others, but are hard to take off and store for large/tall loads.
  10. Mar 28, 2011 at 2:05 AM
    Rocketrob
    Rob
    Cincinnati
    11 SR5
    Thanks for the info...
  11. Mar 28, 2011 at 3:43 AM
    Derecho
    Derecho Well-Known Member
    Thomaston, ME
    11 Magnetic Grey Tacoma SR5 V6 4x4
    Access Tonneau Cover Cobra 29 WXNWST Wilson Lil' Wil COMING SOON... Custom Designed Bedrack
    I've had luck with the Access roll-up tonneau. Had it on a Tundra since 2002, with only some fading on the vinyl, but the velco is still holding strong. Actually putting a new one on my 11 Taco this afternoon, if you want some pictures of that it could be arranged.
    Good luck w/ your choice.
