Tonneau Cover and MPGs? Which One?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rancho, Jul 29, 2017.
  1. Aug 3, 2017 at 8:33 AM
    ST82K
    ST82K Member
    Spectacular. Thanks for your review.
  2. Aug 3, 2017 at 9:05 PM
    zackst
    zackst Well-Known Member
    I don't have hard data and read a bunch of stuff including the myth buster piece before getting a cover.
    I am pretty sure my gas mileage has improved at least 5% since getting a cover. Probably closer to 10% but at least 5%.
    My typical mpg for my commute home previously was around 20 mpg and now my typical mpg for the commute home is around 22 to 23 mpg.
    I am a pretty mindful driver and I do not ride the engine hard and look ahead to coast when I can.
    Also my wife noticed an immediate smoother ride probably because it adds a little weight to the back.
    hiPSI likes this.
  3. Aug 12, 2017 at 7:54 PM
    ST82K
    ST82K Member
    Did your aluminum cleats slide easily into the bed rails? My aluminum cleats only slide 3-4 inches into the rails and then they're jammed up....yes, the set screws are backed out. The cleats closest to the tailgate are fine because they don't need to slide in that far, but the ones closer to the cab need to slide another 10-12in. Just checking to see if you happened to have the issue before I call Tyger on Monday. Thanks
  4. Aug 12, 2017 at 8:00 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    I had no such issue...
  5. Aug 12, 2017 at 8:02 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    This!
    Have the bakflip revolver for my tundra and no impact on MPG whatsoever...
    HutchJ likes this.
  6. Aug 12, 2017 at 8:07 PM
    M3the01
    M3the01 Active Member
    Lair
    I wish there was a cover that worked with bikes over the tailgate... I'm not talking flipping it up so u can't see out the rear window.
  7. Aug 12, 2017 at 8:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you go through the math (lots of math) you will see you will improve a bit but it's tenths of a MPG, not 10 mpg. The additional weight added just about negates any gains due to aerodynamics. The good part?
    Dry (almost) lockable storage
    Better ride due to the bit of additional weight added
    Looks good
    Keeps the leaves out in fall and easier to clean the snow off in winter.
  8. Aug 12, 2017 at 8:28 PM
    ST82K
    ST82K Member
    Tin phorr. Thanks. I've tried grinding the cleats back just a hair and still weren't working sliding on cleanly so I'll give them a call. Thanks again!
  9. Aug 12, 2017 at 8:28 PM
    theed
    theed "Light Offroader"
    Ed
    SF Bay Area, CA
    '16 Silver AC TRD OR
    I've got a foldacover g4 elite, which I like. Mpg difference is negligible, maybe 1-2 better under ideal conditions. Definitely not enough to pay back the cost of the cover in any reasonable amount of time.
  10. Aug 13, 2017 at 6:15 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    You will notice on a windy day the wind don't catch the insides of your bed and jerk the truck around with a tonneau cover on your bed.
    su.b.rat likes this.
  11. Aug 13, 2017 at 8:54 AM
    su.b.rat
    su.b.rat broken truck
    one of the reasons i got one! i do a lot of highway driving.
    CusterFan[QUOTED] likes this.
  12. Aug 13, 2017 at 8:59 AM
    harrycary
    harrycary Well-Known Member
    Harry
    2016 Tacoma TRD Off Road
    Are there other variables at play.
  13. Aug 13, 2017 at 9:01 AM
    harrycary
    Harry
    Maybe you can have 0.5 mpg highway.
    Garyji[QUOTED] likes this.
  14. Aug 13, 2017 at 9:11 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    To answer the OP's question, I have the undercover Flex trifold and did not experience any positive or negative mpg change. I did not really expect to as it does contribute to added weigh. Maybe the guys with vinyl have different results, but I doubt it.
    As for recommending it, If you're looking for 100% leak proof, this is not the one for you. It's more around 90-95% at best.
    It is very easy to use, practical, strong top can be easily removed for total bed use, lays nicely flat, but you do loose use of the oem rail hooks. No big deal, I have a oem bed mat.
    Hope that helps
    Cheers!
