Tonneau cover and rail issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brek08, Jul 6, 2021.
  1. Jul 6, 2021 at 7:57 AM
    Brek08
    Brek08 [OP] New Member
    I just got a backflip tonneau cover and I'm sure many of you have discovered that in order to install it you need to lower the rails using the brackets that they send. The problem with this is that lowering the rails nullifies a lot of accessories you can put on like a molle system or bed rack. Has anyone ever tried just installing the rails on the brackets in the same location or found any other solution?
