Tonneau cover Bike rack DIY
Discussion in '3rd Gen. Tacomas (2016+)' started by DOSS, Jan 31, 2016.
  1. Jan 31, 2016 at 10:43 AM
    DOSS
    DOSS [OP] Well-Known Member
    Scott
    Utah
    2016 Black Tacoma TRD Sport DBCB
    This all started as I wanted to be able to quickly carry one or two bikes on my truck without the loss of bed-space and without having to put a rack into the hitch every time I just wanted to carry one or two bikes. I also wanted to be able to drive into my garage and not worry about taking a bike out with the garage door or not fitting with the rear hitch mount rack attached.
    So for about $60 I came up with this setup (some parts I already had floating around so I am not 100% sure on cost)
    Supplies
    2 locking fork mounts - these mounts barely allow the trifold to open all the way shorter would be better.
    4 Bolt down anchor mounts from home depot
    12 1.5 inch stainless 1/4 bolts, nuts and fender washers
    1 tube black RTV adhesive sealant
    1 1 inch square 4 foot long Aluminium tube
    2 10 inch velcro straps or bungee cords - These just strap through the anchor mounts over the rear the tire to hold it down.
    Step 1 locate your fork mounts each 12.5 inches from the edge and 5.5 inches from the front of the tonneau (close to the cab) to the trailing edge of the fork mounts. Mark holes and drill the 4 1/4 holes you need. Now match up your aluminum tube to those holes and drill holes in those. To assemble use black RTV on all surfaces that will mate with the cover - the bottoms of the fork mounts and the top of the aluminum tube, as well as the holes that the bolts go through. Now just assemble with the Fork mounts on top and the Aluminum tube under the tonneau and tighten stuff together (my 11 year old was perfect for holding the bolts up top while I snugged up everything inside the bed).
    2016-01-31 11.36.43.jpgNow for the rear wheel tie downs I went with what ended up the simplest solution on each side I mounted 2 anchor mounts 42 inches back from the top of the mount straight back with about 3 inches separating them. drill holes, RTV and tighten bolts.
    Here is your under side view :)
    Been using this for about 4 weeks with no issues at all :)
    sendtoharvey and Jukeboxx13 like this.
  2. Jan 31, 2016 at 10:47 AM
    awhitfield4
    awhitfield4 Well-Known Member
    Knoxville, TN
    I've been thinking about that! Thanks! Any pictures with the bikes on?
  3. Jan 31, 2016 at 10:51 AM
    DOSS
    Scott
    Utah
    I can get one for you tomorrow :)
    I originally had it set up without the aluminium bar on the underside.. it held up fine but was just a bit more wiggly that I wanted so I figured for a couple bucks why not make it a bit more secure :)
  4. Jan 31, 2016 at 11:00 AM
    awhitfield4
    Knoxville, TN
    Absolutely. It would be so nice to throw the bikes up there and then be able to keep all my other stuff under!
  5. Feb 2, 2016 at 5:24 AM
    DOSS
    Scott
    Utah
    Sorry for the delay in pics.. got a foot of snow yesterday so riding the bike wasn't gonna happen... I will see if I get unlazy today and stick it on there and get a pic in the garage :)
  6. Feb 9, 2016 at 5:17 PM
    DOSS
    Scott
    Utah
    Update.. Drove from Salt Lake to Vegas and back with no issues and two bikes on the rack.. I still suck at getting a picture with bikes on it though :)
  7. Feb 16, 2016 at 4:27 PM
    DOSS
    Scott
    Utah
    And now I have finally taken a picture with my bike on the truck :)2016-02-16 17.17.47.jpg 2016-02-16 17.17.40.jpg 2016-02-16 17.17.32.jpg
    Jukeboxx13, econwatch and awhitfield4 like this.
  8. Feb 16, 2016 at 5:46 PM
    awhitfield4
    Knoxville, TN
    Boom! Looks great! Thanks for the pictures!
    DOSS [OP] likes this.
  9. Jun 16, 2016 at 10:44 AM
    DOSS
    Scott
    Utah
    Just an Update.. 4000 miles with bikes on this and it is still working like a charm
    shakerhood and 2016TacomaTRD like this.
  10. Jun 16, 2016 at 1:20 PM
    2016TacomaTRD
    2016TacomaTRD Part time Ninja
    2016 Tacoma TRD Sport
    any problems with it moving around or swaying side to side when traveling on the freeway? or is your bike route just close to home? I actually haven't thought of this. thanks for sharing the pics!
  11. Jun 18, 2016 at 7:12 AM
    DOSS
    Scott
    Utah
    No problems at all.. I have end up on the freeway almost every time I take my bike out and have very little movement (less than most roof mounted racks). Just drove 400 miles with it on there last weekend with no worries at all including some high speed canyons :) .
  12. Jun 19, 2016 at 8:00 AM
    2016TacomaTRD
    whoa! an even more genius idea!.. I was going to do it this weekend.. Now I'll have to order a bed rail.. Being able to move the fork mounts can be helpful. Thanks!
  13. Mar 5, 2017 at 10:09 AM
    kluge9
    kluge9 Well-Known Member
    Andy
    17 DCSB OR MT
    Don't mean to bring this back from the dead, but can you still latch the tonneau open with this rail? I guess it depends on what mounts you use, but I'll probably be jumping on the Rocky Mounts like you've got.
  14. Mar 8, 2017 at 2:01 PM
    kluge9
    Andy
    17 DCSB OR MT
    @DOSS @JR SoCal Tacoma @2016TacomaTRD Have any of you guys successfully mounted 3 bikes this way? Thinking 2 roadies on the outside and the wife's hybrid in the middle or 3x roadies when with friends. Thanks!
  15. Mar 8, 2017 at 6:21 PM
    DOSS
    Scott
    Utah
    I haven't but if you put the outer 2 as far out as you could and centered the third I don't see why it wouldn't fit.. Honestly I would just flip the 3 bikes upside down on top of the bed to check the widths of your handlebars to double check but I don't see why it wouldn't work.
  16. Mar 8, 2017 at 7:14 PM
    kluge9
    Andy
    17 DCSB OR MT
    This makes sense and I think it's another reason to go with a bed rail. Maybe tonneau-wide to allow a multitude of mounting options. Thanks!!
  17. May 18, 2017 at 7:35 PM
    kluge9
    Andy
    17 DCSB OR MT
    Whew. Took me long enough but I got it. 3 bikes even. Went with eyelets in the back with bunjees. [​IMG]
    shakerhood and DOSS [OP] like this.
  18. Sep 28, 2017 at 3:06 PM
    jeffserbin6
    jeffserbin6 Member
    Jeff
    2017 Toyota Tacoma TRD Off Road 4x4
    I see you have a 4x4. Have you tried this setup off roading? I am looking for the most effective way to haul my mountain bike on my adventures. I don't really want to have to get a hitch rack and most of them say to never use off roading. I am curious how something like this would hold up when it isn't on paved roads.
    Also, can you post a picture of how well the cover folds up with these attached?
  19. Sep 28, 2017 at 4:03 PM
    YDCtaco
    YDCtaco Go Deacs!
    Brad
    Charlotte/Winston-Salem
    2016 DCSB TRD OR 4x4-Auto
    Check out kbvoodoo.com
  20. Sep 28, 2017 at 7:00 PM
    kluge9
    Andy
    17 DCSB OR MT
    I'll see if I can snap a picture in the morning. I have the Rocky Mounts TA on the drivers side and it sits higher than the RM 9mm QR (the middle and pass. side mounts). With the 9mm QR mount, I can still buckle the tonneau open. I just buckle one side when I'm running around town like that.
    As for off road, I have not taken it beyond some unmaintained fire roads. If you trust your bike on any sort of fork mount, this set up will be no different. It's 4' of aluminum tubing underneath the tonneau to spread the force across. I've taken it through the WV mountains at 75-80 with nary a hint of movement. I only ride road, so I doubt I'll do much hardcore off-roading with the setup in the future.
