Tonneau Cover compatible with Kayak Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hikeril, Oct 20, 2019.
  1. Oct 20, 2019 at 9:12 AM
    hikeril
    hikeril [OP] Member
    I'm looking for a kayak rack that is compatible with a Tonneau cover. I'm looking for a rack that will fit in the back of the truck or on the rails or a Tonneau cover that is easy to remove and be replaced with a Kayak Rack. I've have spent hours looking at threads, pictures, etc. I found the Retrax Pro XR that one of the members is using with the top rail system but the cover is about $1500 plus the rack system from Thule/Yakima.
  2. Oct 20, 2019 at 9:16 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i plan on buying KB Voodoo system. They make brackets that sit proud of the cover and allow it to be functional
  3. Oct 20, 2019 at 9:27 AM
    skifishbum
    skifishbum Well-Known Member
    Reno, NV
    17 DCSB -> 22 DCLB
    I had a kB voodoo rack that worked well with the oem cover. Biggest issue is you can’t unfold it with rack attached.
  4. Oct 20, 2019 at 9:30 AM
    hikeril
    hikeril [OP] Member
    Skifishbum, Is it easy to remove the rack when your done using it?
  5. Oct 20, 2019 at 9:34 AM
    skifishbum
    Reno, NV
    17 DCSB -> 22 DCLB
    This was primarily my camping set up so I usually took both the rack and tonneau off at the same time.
    I think in order to remove the entire rack you’ll have to slide the tonneau cover off first. Unless you want to just remove the cross bars, those detach the the rail mounts.
