Tonneau cover help
Discussion in 'Tonneau Covers, Caps and Shells' started by gen2tegboi, Feb 24, 2014.
  1. Feb 25, 2014 at 10:32 AM
    doughboy
    doughboy Well-Known Member
    norcal
    2010 Tacoma TRD 4x4
    hid head lights, hid fog lights, always on fog lights, bed lights
    access low rollup for me. been using it for 4 years, still fits nicely, and I have not adjusted the tension since I installed it. I've not seen any rollup that fits as nice. you'll be thankful you got a rollup.
  2. Feb 25, 2014 at 10:35 AM
    gen2tegboi
    gen2tegboi [OP] Well-Known Member
    Juan
    Florida
    98 Tacoma Ext Cab SR5 2.4L
    does the access roll up use clamps or attaches behind CMS rail like the literider?
  3. Feb 25, 2014 at 10:39 AM
    gen2tegboi
    Juan
    Florida
    considering the prices on truck alterations I'm undecided between the truxedo lo pro, the access roll up or the access literider.
  4. Feb 25, 2014 at 10:45 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I had the Access on an 2008 Tundra that still looks like the day I installed it. Full use of the bed and secures in the front when rolled. That way you don't have to worry about a folding panel rubbing on your cab. Tight as a drum, literally, you could tap on it and hear it go boom. On the Tacoma (with the Original Access, at least) you remove the rails and put the frame work of the cover between the rail and the bedside. That way you can still utilize the tie down straps. I don't know about the low profile one though.
  5. Feb 25, 2014 at 11:20 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Also the LiteRider does leave very minimal gap between top of the tailgate and the cover itself which was not the case with the Truxedo LoPro Qt for me.
    Access LiteRider:
    f32956e2-17b8-4ec7-9276-f7811771314d_zps_0fb65d99e7120a3cdeb92341b4c66592a665e44c.jpg
    Truxedo LoPro Qt:
    d8b21248-ab1f-457e-bcde-50bd8e650d0e_zps_7b653b391d7ce589bde979ade1580e31f7576f24.jpg
  6. Feb 25, 2014 at 11:22 AM
    MJR
    MJR Well-Known Member
    Mickey
    Salado, TX & Santa Rosa Beach, FL
    ‘23 LIMITED 4wd NIGHTSHADE & ‘23 T4R TRD ORP
    Removed factory bed cover and installed UnderCover Elite. Added LOCKERDOWN console safe.
    Our customers don't seem to be having any leak problem with this. Undercover Lux
  7. Feb 25, 2014 at 11:29 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I really like the undercover product line but they are expensive (to me) new. I am holding out for a used one.
  8. Feb 25, 2014 at 11:32 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
  9. Feb 25, 2014 at 11:45 AM
    jessandjamie
    Arizona
    I wonder if that gap is unique to early versions or just the Lite-Rider. My original Access cover has no gap at all above the tailgate. In fact its tight enough theres some resistance when opening and closing because it rubs on the cover.
  10. Feb 25, 2014 at 11:51 AM
    kryten
    Canada
    There is very minimal gap with the Access LiteRider I got in early 2012. That picture is quite dark to see clearly, but the actual gap is very small. The cover however does not touch the tailgate. On the other hand, there was a huge gap with the Truxedo I got in 2009.
  11. Feb 25, 2014 at 12:46 PM
    doughboy
    norcal
    2010 Tacoma TRD 4x4
    I just checked my order receipt. I got it in 1/2010 for $385 (I got the limited). The price now is $389, and I did not get any LED light, retriever or cleaner.
    I am sure I had to remove the rails and install the metal piece behind the rails (this is where the velcro on the canvas attaches to). I suggest you call them to make sure.
    Order date: Jan 25, 2010 2:51 PM PST
    Google order number: xxxxxx
    Shipping Status Qty Item Price
    Not yet shipped
    1 80766E - 05+ Tacoma 5' Access Limited $385.00
    1 3176BA - Pop N Lock Manual Tailgate Lock 09+ Tacoma w/wo Camera $47.00
    1 Message - 2010 Toyota Tacoma Double Cab Short Bed $0.00
    Tax (CA) : $0.00
    Total: $432.00
    BTW, to OP, you might consider increasing your budget a little to add the tailgate lock since your are covering the bed with a tonneau.
  12. Feb 25, 2014 at 2:33 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I got the same when I bought new. I never had to adjust the tesion and the velcro seems to go right in place without pulling it tight. It's the Access Limited.
    I personally would have no use for a tri-fold. If you fold it all the way open, the rear window is blocked.
  13. Feb 25, 2014 at 2:49 PM
    matt1381
    matt1381 Well-Known Member
    Independence, KY
    05 4x4 SR5 TRD
    OME 885 Front Coils All Pro 3 inch Leaf Springs 285 75 16 Pro Comp All-Terrains
    I have the Truxedo low pro. Best customer service you can get. I got a small rip in my original and contacted them. All they asked was what size and sent me a new cover for free. Service like that is always worth it to me.
  14. Feb 25, 2014 at 3:46 PM
    gen2tegboi
    Juan
    Florida
    So how does the literider do with water? Does it leak at all or minimal?
    Thanks for all your input so far.
  15. Feb 25, 2014 at 3:51 PM
    #35
    gen2tegboi
    Juan
    Florida
    I dont think I need a lock since I will not be leaving anything in the bed. The only stuff we do put in the is the baby's stroller but that goes everywhere with us. I mainly want the tonneau to keep dirt and the leave from the neighbors oak tree of the bed so i can throw in the baby's stroller.
  16. Feb 25, 2014 at 4:38 PM
    #36
    kryten
    Canada
    When going through carwash or really heavy downpour, there may be small leaks inside. Was the same with truxedo. It all depends on how much of weatherstriping you put on and how good of a job you do installing it. The more expensive access limited cover comes with more weatherstripping.
  17. Feb 25, 2014 at 4:51 PM
    #37
    doc1187
    doc1187 Well-Known Member
    new york
    sr5 4x4
    Extang solid fold easy and quick to remove. I added a pop & lock . keeps my tools, golf clubs, and suit cases safe and dry.
  18. Feb 25, 2014 at 5:23 PM
    #38
    peto48
    peto48 Well-Known Member
    Central NY
    2020 Tacoma DCSB TRD Off Road Cement 4x4
    Salex Center console organizer, glove box organizer, Husky Xact contour front and rear digital floor liners, OEM black running boards, TRD PRO Sema 4runner wheels black, Blackout badge kit, Bakflip MX4 hard folding tonneau.
    For your purposes I would just snag a tonnopro soft fold. Very inexpensive but quality trifold cover. Good warranty. Had one on my truck until I went with a bak fibermax. Tonnopro works with the rails and can be fully removed in 5 minutes.
  19. Feb 28, 2014 at 11:32 AM
    #39
    gen2tegboi
    Juan
    Florida
    I ended up going with the literider and the trailseal tailgate kit from truckalterations.com.
    Thanks for all your input. now in hoping installation goes through smoothly. got any tips? while I anxiously wait for it to get here.
