Tonneau Cover: How water resistant are they and what brand is best
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AuburnTacomaTRD, Feb 2, 2016.
  1. Feb 2, 2016 at 1:03 PM
    AuburnTacomaTRD
    AuburnTacomaTRD [OP] Well-Known Member
    2016 Toyota Tacoma TRD Off Road
    Good afternoon, I have a 2016 TRD Off Road Tacoma and would like to put a tonneau cover on it. However, I cannot decide which brand seems best and which version of the brand would be most cost effective and not let water in to the bed. Because we will use this truck for traveling so I want to protect against moisture entering the bed.
    Please let me know if you have a bed cover and if so which one, or make a recommendation on which tonneau cover to go with in order to resist rain and not break the bank.
    Thanks
  2. Feb 2, 2016 at 1:14 PM
    AuburnTacomaTRD
    Sorry man, I couldnt find a thread that addressed this directly, if there is one, please send a link. All the search results brought up ones for sale @Scooter62
  3. Feb 2, 2016 at 1:16 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  4. Feb 2, 2016 at 1:18 PM
    SouthPoint
    SouthPoint Member
    Outer Banks
    2012 Gray Tacoma 4x4 Double Cab
    Undercover Classic is watertight. One piece design. Never had a leak with mine, even in driving rain. Two drawbacks.....It is one piece which means you can't fold it out of the way to load taller items. You're limited to just below the height of the bedrails. Also...I had corrosion issues (still do) with the mounting hardware as well as the struts. Completely rusted in less than two years even with cleaning and maintenance. They were kind enough to send me new parts. Good cover IF they've addressed the hardware issues.
  5. Feb 2, 2016 at 1:18 PM
    AuburnTacomaTRD
    Do you recommend the Retrax or Revolver in your personal opinion? @Scooter62
  6. Feb 2, 2016 at 1:20 PM
    AuburnTacomaTRD
    @Scooter62 all of these are over $2,000 I was looking at the ones that were much less than this in price. More of the sub $500 range
  7. Feb 2, 2016 at 1:21 PM
    AuburnTacomaTRD
    @SouthPoint Thanks man, I will look into this brand as well.
  8. Feb 2, 2016 at 1:23 PM
    Krezz
    Krezz Well-Known Member
    Kevin
    Ontario, Canada
    '18 Tundra Platinum Crewmax
    All mod's listed on website - regarexpeditions.com
    I've had great luck thus far with my Extang 2.0 Solid Fold - minor water has been leaked into the bed and that was during an all day rain we had, which included having to get out and drive on the highways for a few hours during the storm.
    CaptAmerica likes this.
  9. Feb 2, 2016 at 1:23 PM
    countryttcuzzin
    countryttcuzzin Member
    Darrell
    Exlax City, centeral Kansas
    2007 Tacoma TRO Sport crew cab V6 auto
    Westtin Running boards+ bull bar and Lights,Bilstein Shocks front raised 1 1/2 inchs,Kelly Safari TSR tl 265/70R17 tires, Spyderauto compression headlights and LED tail lights.K+N CAI,Flowmaster CAT/B exhaust, Wood Grain Dash and doors trim,ATC Tonneau cover
    I have a ATC. Platinum series it is a hard cover. Has been on my 2007 Tacoma since it was new. I have had no moisture in the bed at all.
    CusterFan likes this.
  10. Feb 2, 2016 at 1:24 PM
    AuburnTacomaTRD
  11. Feb 2, 2016 at 1:25 PM
    CusterFan
  12. Feb 2, 2016 at 1:27 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    If you don't want the additional weight and security of a hard tonneau or tri fold (some allow only the use of 2/3 of the bed unless you remove it)
    Try the Truxedo Lo Pro. Great adjustable cover. The rails can be used. Lifetime warranty, My tailgate is sealed. I don't get any water in the bed
    themajewski likes this.
  13. Feb 2, 2016 at 1:30 PM
    Championsumo
    Championsumo Well-Known Member
    Tulsa, OK
    2015 DCSB 4X4 TRD Sport
  14. Feb 2, 2016 at 1:31 PM
    CusterFan
    1st I have heard of this. Now you have me not wanting to buy the Undercover Elite. I really don't need a tonneau cover I don't guess.
  15. Feb 2, 2016 at 1:34 PM
    AuburnTacomaTRD
    @TacoBella Now that is more like what im looking for, im going to bookmark both of these. Thank you for this recommendation, the other ones were rather steep in price.
    @Championsumo have you had any issues from it, and is it as easy as the video shows it to install, and to remove for other applications?
  16. Feb 2, 2016 at 1:36 PM
    Championsumo
    Tulsa, OK
    Takes about 2 minutes to remove once the hardware is installed. It took me about 15 minutes to mount the hardware. I have had it on for over 6 months, no wear issues what so ever.
  17. Feb 2, 2016 at 1:39 PM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    I may have to readjust mine. I get little bit of drips in the corners. Not bad but still a little annoying. What did you use to seal the corners especially the front?
  18. Feb 2, 2016 at 1:39 PM
    TacoBella
    Tom
    If you want to save more, I had this one on my last Tacoma.http://www.autoanything.com/tonneau-covers/60A2044A0A0.aspx
    The Lo Pro is a lot better
  19. Feb 2, 2016 at 1:39 PM
    Championsumo
    Tulsa, OK
    I just tucked in the factory seals into the corners a little better with my fingers. Perhaps your giant grill is causing some undue turbulence and making water go in there ;)
    TacoBella likes this.
  20. Feb 2, 2016 at 1:39 PM
    TacoBella
    Tom
    Weather seal. I used the Truxedo Seal for the gate
