Tonneau cover letting water in!
Discussion in 'Tonneau Covers, Caps and Shells' started by SURFTACO, Jan 17, 2010.
  1. Jan 17, 2010 at 11:30 AM
    SURFTACO
    SURFTACO [OP] Well-Known Member
    New Jersey
    09 TRD SPORT
    3'' Lift: Bilstein 5100’s, SPC UCAs, All Pro 3” leaf packs, Bilstein 5125’s, Kenda 33X10.5R17 Tires Flat Black Stock Rims Seat Belt Chime off Fog Lights On anytime Jet pilot interior All weather floor Mats Tonneau Cover Cali Raised Ditch Lights Snorkel
    Open my tailgate up this morning and noticed a pretty good amount of water in the forward part of the truck bed. The one i have is the roll up Velcro type. The only thing i can come up with is to get a hose and spray the cover, and find where its leaking in from. Has anyone had the same problem? if so, whats the best way to fix? thanks
  2. Jan 17, 2010 at 11:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Weather strip along the head liner (might take two layers). Black silicone along the seams between the tonneau rails and the bed rails will seal those up pretty good.
    Corners are the hardest to seal...but it can be done.
  3. Jan 17, 2010 at 11:36 AM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    Mine lets water in through the front. Haven't found a way (or cared enough) to fix it. My Tonneau is just used to keep things from the immediate elements. It doesn't let in enough water to drown anything but it does let in a little. My suggestion if you want something water proof, get a camper or something more sealed.
  4. Jan 17, 2010 at 11:38 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Another idea- Get a bed mat and then the water will run under the bed mat and keep your stuff drier.
  5. Jan 17, 2010 at 12:14 PM
    MotoXFreeStyle61
    San Antonio TX
    Yeah, most of the time what little water gets in runs down the troughs, so my stuff hardly gets wet.
  6. Jan 17, 2010 at 12:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    you could also drill a drain hole or 2 up towards the front of the box to let water out
  7. Jan 17, 2010 at 12:30 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
  8. Jan 17, 2010 at 1:15 PM
    SURFTACO
    New Jersey
    09 TRD SPORT
    I've had this type of cover on my old truck and didn't have any issues with leaks. Im in florida at the moment and this morning, it really came down!
  9. Jan 17, 2010 at 3:00 PM
    MotoXFreeStyle61
    San Antonio TX
    Mine has 2 small holes in front of the bed on either corner. Im guessing that is what they are for. Most of the time though I have to clear em out because they get clogged with any type of debris.
  10. Jan 17, 2010 at 3:14 PM
    SURFTACO
    New Jersey
    09 TRD SPORT
    thanks for the advice guys.
