Tonneau cover MPG gains
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSRSX, Mar 7, 2021.
  1. Mar 8, 2021 at 4:32 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Putting a cap, or tonneau cover on a truck might help fuel mileage slightly, but not 3-4 mpg. Somewhere less than 1 mpg is normal, and in some cases fuel mileage could be worse. It depends on a lot of factors.
    Fuel mileage can vary a lot. I've seen 4 mpg over short distances, and 40 mpg over short distances. Until you've ran 2-3 tanks through the truck and calculated it by hand you're just guessing. And if you never did the same and calculated it by hand before adding the cover you don't have an accurate baseline to compare with.
    Thatbassguy, Vlady and hiPSI like this.
  2. Mar 8, 2021 at 4:48 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I don’t know specifically about the tonneau cover, but the Mythbusters were wrong about a number of other things. They have an episode on whether a can of Coke can explode in a hot car. They couldn’t get it to happy even in the AZ desert heat. I’ve had it happen twice to me and it doesn’t even get that hot here. Most recently I had 3 cans in a 12 pack explode from heat (left them on the front seat while I was working). The result really sucked.
    Shocked and hiPSI like this.
  3. Mar 8, 2021 at 4:49 AM
    jowybyo
    Joe
    Baltimore, MD
    That must be one hell of a hill.
    Malvolio, sbb, jmneill and 1 other person like this.
  4. Mar 8, 2021 at 5:16 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I was on my way back from a snowmobile trip in quebec an had a bunch of soda in cans stored in my enclosed trailer. It was about -20 when the trailer got a flat. H ad to pull off the shoulder of the road and get the spare inside the trailer. Inside was a mess, at least 1/2 dozen cans of soda exploded all over the sleds and gears requiring a good pressure wash to get the sticky mess cleaned up when back home.
    Otherwise this whole mileage thing with the tonneau cover is getting deep. Gotta get my boots.
    Malvolio and hiPSI like this.
  5. Mar 8, 2021 at 6:17 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Tonneau cover will allow the flow of air over the cab to flow with less drag, simple physics.
  6. Mar 8, 2021 at 6:43 AM
    zoo truck
    None
    Thats implying basically thats the same thing as driving with your tailgate down. Thats been proven bs for better fuel economy.
  7. Mar 8, 2021 at 6:52 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    With the cover you will get less drag ..will you significant mpg ...probably not ..mpg depends on gas quality ..driving habit .Its like saying the cold air intake will give you better mpg and 5hp ...lol
  8. Mar 8, 2021 at 7:03 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Cap, cover, shell, or not, I think 27 mpg is awesome, like really awesome. Check back after a couple or 3 tank fulls, then you’ll have a good idea what you gained in mpgs.
    strider98 likes this.
  9. Mar 8, 2021 at 7:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    lol instead of checking your physics book you need to check your fluid mechanics book, especially the chapter on laminar versus turbulent flows.
  10. Mar 8, 2021 at 9:21 AM
    Gearheadesw
    Davenport Fl
    :anonymous:......I laminate my turbulent flows......
    hiPSI and Spare Parts like this.
  11. Mar 8, 2021 at 9:34 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Call up and raise hell, yours must be broken..
  12. Mar 8, 2021 at 9:40 AM
    zoo truck
    None
    The only thing my tonneau cover can do thats notable is make noise when you hit cross winds.
  13. Mar 8, 2021 at 9:42 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Complete sidetrack but whenever I hear the word laminar this is all I can think of.
  14. Mar 8, 2021 at 11:34 AM
    TacoSRSX
    TacoSRSX [OP] Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    My first day commuting 40 miles yielded 24.5 MGP.
    1. Definitely less than the 27mpg it was reading on day 1 but still an impromptu over the 22mpg I was getting previously.
  15. Mar 8, 2021 at 11:39 AM
    #35
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Temps also make a difference. My truck has been breaking back into the 20 MPG range now that it is warming up. 45 mile commute (90 round trip) at 70 MPH.
  16. Mar 8, 2021 at 11:42 AM
    #36
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    was it windy?
    shakerhood likes this.
  17. Mar 8, 2021 at 11:43 AM
    #37
    RedWings44
    Michigan
    Yes and no. Like I said, it depends on a number of factors, such as cab configuration, wind speed, MPH, etc. With the tonneau cover, like with the tailgate down, drag is increased at the rear (depending on the factors I just listed) because of the way the air comes down onto the tailgate or tonneau cover. With no tonneau cover, the air swirls around in the bed and allows the majority of the air to pass over top. Manufacturers have added large lips onto tailgates to assist with the departure of the air as well. In my experience, however, I have found the difference to be negligible. Sometimes my MPG is better and sometimes it is worse. Too many other variables.
    hiPSI likes this.
  18. Mar 8, 2021 at 11:43 AM
    #38
    Spare Parts
    Southern Maine
    From google, so it must be true:
    According to many experts, the best way to improve the truck's fuel economy is to add a tonneau cover. A tonneau cover will help reduce aerodynamic drag and can improve gas mileage by as much as 10%, see below for details.
    shakerhood, hiPSI and DAS Taco like this.
  19. Mar 8, 2021 at 12:28 PM
    #39
    RedWings44
    Michigan
    To be fair, a lot of things come into play with cans exploding from heat or cold. We often have some explode from the cold, but it's rare that the entire pack explodes.
  20. Mar 8, 2021 at 12:37 PM
    #40
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    This.
    My MPG took a HELL of a dive when the high was -20F. Now that we're in the 30's and above, the mileage is coming back up to where it should be.
