Tonneau cover question for 2017 Tacoma Dbl cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eagleguy, Feb 28, 2018.
  1. Feb 28, 2018 at 3:22 PM
    eagleguy
    eagleguy [OP] Well-Known Member
    I just purchased a LUND ELITE cover part number 958186 and have a couple of questions.
    1. How much should the cover overlap the top of the rear tailgate which at the top middle is about 5" deep? When I line everything up and use the front and rear utility rail bracket inserts they supply for the clamp down I seem to get only a .5 overlap at the rear but the front is fine.
    2. At its best the rear utility bracket insert for the OEM utility rail is at the very end of the rail making replacing the OEM plastic cap ends which you need to temporarily remove almost impossible. At that point the hold down clamps are not even perfectly vertical with the cover pushed up as far as it can go before it hits the rear of my cab.
    Seems to me the cover may be a little short or LUND did not position the rear cross member brackets in the right position. I was expecting a cover that was full length but seem to have come up short unless that's the way it was supposed to be.
    I called LUND and they have requested photos but I am wondering if I am missing something.
