Tonneau cover recommendations!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kurtblends, Apr 18, 2021.
  1. Apr 18, 2021 at 9:59 AM
    Kurtblends
    Kurtblends [OP] Active Member
    Honolulu, HAWAII
    2021 TRD OFF ROAD 4x4
    What’s up guys I just got my new 2021 off road 4x4 Tacoma 2 days ago and I really need help on which brand tonneau cover would be best ? Realistically I need to put my daughters stroller back there’s that’s why.. I was more so aiming for the folding type but if any one has other recommendations that would be awesome!!
  2. Apr 18, 2021 at 12:05 PM
    coachmac24
    coachmac24 Member
    2021 TRD Sport 4x4 DCSB
    7B269A7A-5E12-4747-BA0A-E3AC338BA670.jpg A7162E44-E58B-41F5-930B-7D0284965332.jpg Nice truck. I have a 2021 TRD Sport in same color. I went with an Extang Xceed hard folding cover. It lays pretty flush when closed down and can be folded up from the bed when you need the entire space. I liked that it’s held up by struts in that position and not on the truck. Still allows me to use the factory tie down rails too. Easy installation and very heavy duty.
    Kurtblends[OP] likes this.
  3. Apr 18, 2021 at 12:08 PM
    tclavell
    Troy
    Phoenix, AZ
    G70
    Bakflip MX4 :thumbsup:
    Jkline101, Doc62 and ChalkieSugarman like this.
  4. Apr 18, 2021 at 12:10 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    How much do you want to spend?
  5. Apr 18, 2021 at 12:44 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    Diamondback....end thread.
  6. Apr 18, 2021 at 12:47 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    OEM be my choice
    shady 74 and zoo truck like this.
  7. Apr 18, 2021 at 12:48 PM
    Harmon
    Harmon Well-Known Member
    Jacksonville
    2020 Tacoma SR V6 4X4
    265/75/16 BFG KO2's Front ARB Air Locker
    I bought the Bak Bakflip Mk4 just last week.
    It was $948 plus tax and $125 to install. They even put the drain plugs in with the hoses to help with weather proofing.
    It sits flush, folds up all the way, it looks really good.
    It's not 100% water proof (I don't think T Covers are 100%) but it does a good job keeping out most of the water.
    I paired it with a OEM Tacoma bed matt and all my stuff in the back stays really dry.
  8. Apr 18, 2021 at 12:52 PM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    There's no way I'd run anything other than a diamondback, so that's my recommendation
  9. Apr 18, 2021 at 1:10 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    IMG_20200817_183354.jpg The LoMax hard tri-fold tonneau cover is what I got. It aluminum and not too heavy. Mine was under $700 see @GotExhaust about it.
  10. Apr 18, 2021 at 1:30 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    I really like my Peragon. Doesn't create any wind resistance when folded. And it comes off easily if I want my entire bed. I regularly haul stuff that's too tall wit the cover closed. I just open it and secure it in place. If I do need to remove it, it takes just a couple of minutes. A big thing for this old phart is that it's weight is easily manage.
    https://www.peragon.com/
  11. Apr 18, 2021 at 1:42 PM
    Tacog70
    Tacog70 Member
    Northern Ontario
    2021 Tacoma TRD OR SB
    OEM Running boards, Truxedo Pro X15 tonneau cover...
    I ordered the TruXedo Pro X15. Looks good, sits flush, rolls up or you can remove it totally using a latch at the front.
    BumfukKansas, FTFRS and jc63 like this.
  12. Apr 18, 2021 at 1:59 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
  13. Apr 18, 2021 at 2:01 PM
    Banggerr
    Banggerr Well-Known Member
    This is what I did too
  14. Apr 18, 2021 at 3:14 PM
    Kurtblends
    Honolulu, HAWAII
    1000$ at the most
  15. Apr 18, 2021 at 3:18 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    DB gets my vote.
  16. Apr 18, 2021 at 3:35 PM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I did cheap, I only needed it for a few months and it worked great, total cost about $100, 2 pieces of plywood, 1-2x2 board, some nuts & bolts, some eye bolts, old tie down straps, hinges and paint sitting at the house. This went through a rain storm for 2 days and didn't leak
    New set up, but I kept the cover just encase
  17. Apr 18, 2021 at 3:49 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    You might want to check out this TW forum section:
    https://www.tacomaworld.com/forums/tonneau-covers-caps-and-shells.198/
    MGMDesertTaco likes this.
  18. Apr 18, 2021 at 3:51 PM
    MGMDesertTaco
    Soft rollup I'd pick truxedo truxport for about $300.
    Mid to high price hard tri-fold I'd pick the Lomax mentioned above for around 600-700 or the bakflip mx4 for about 1,000.
    The mx4 can be secured or latched partly open unlike the rollups that are either completely open or closed.
    These are the ones I'm looking at for under a $1000. Definitely search the forums for dealers offering discounts. You can PM them for a quote. I'm leaning towards the mx4 because of it's low profile and it looks like it belongs on the truck. I like the Lomax, but the lines don't match the shape the bed of the truck and that bugs my ocd a little.
    If you have the budget I'd recommend a hard cover for the added security. An oem locking tailgate harness is a plus too. It locks and unlocks your tailgate with your key fob.
    auskip07 likes this.
  19. Apr 18, 2021 at 4:07 PM
    ChalkieSugarman
    ChalkieSugarman Well-Known Member
    Charley
    2021 Army Green TRD OR DCLB
    I also have the Bakflip MX4. Bought it new on Craigslist for $850. Installed in about an hour. Looks fantastic, very tactical. And they claim it can hold 400 pounds on top. Like Harmon said, it isn't absolutely water tight, though I think it can be close to it if you add some sealant on the bed rails. Don't store your tax documents in the bed... Know that it does cause the OEM bed rails to drop about an inch, so some components that are designed for the height of the OEM rail will not fit. That said, I'm very happy with it.
  20. Apr 18, 2021 at 4:24 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    I got my MX4 for $750 new during a black Friday sale back in November. Must have sealed it right when I installed it. No leaks that I have found so far.
