Tonneau Cover Reviews
Discussion in '3rd Gen. Tacomas (2016-2023)' started by M3D1K, Nov 19, 2015.
  1. Nov 30, 2015 at 3:04 PM
    #61
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    just had the Access Rollup Cover installed. fits better than the 2012 we had, but one issue is, the tail gate hits the rear of the cover when closing the tailgate. pics after installed ...
  2. Nov 30, 2015 at 3:43 PM
    #62
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    Shouldn't matter. Bed is basically the same and that website you referenced also shows the Gen2 with cleats not working but, apparently this guy is doing it
  3. Nov 30, 2015 at 3:49 PM
    #63
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Go for it. Just posted what I read. No hard feelings on my end. Have a good evening. :)
    I'm going to have to wait for a seller on Amazon to list a TruXedo Lo Pro QT for sale so I can buy it with my store card interest free. Only way I can afford one.
  4. Nov 30, 2015 at 3:59 PM
    #64
    swimmer
    Tucson
    2016 TRDORAC4WD
    What I meant was there is conflicting info. Seems like a '16 owner should have possession soon so we can get confirmation on cleat use.
  5. Nov 30, 2015 at 4:17 PM
    #65
    radchris88
    radchris88 Well-Known Member
    Christian
    NY
    2016 Tacoma TRD Off-Road MGM DCLB
    Love the way it looks and the security. Not totally waterproof. Talking to extang to see if it's warranty worthy. Otherwise I will be modifying it to stop the minor seepage. Will post more pictures if you guys want.
  6. Nov 30, 2015 at 4:32 PM
    #66
    CusterFan
  7. Nov 30, 2015 at 4:46 PM
    #67
    radchris88
    Christian
    NY
    I thought about it but didn't like how it looked overhanging. It seems like it isn't enough coverage on the rails but I have gotten zero leakage from the rails, only from the hinges, which I am going to modify a little.
  8. Nov 30, 2015 at 4:50 PM
    #68
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    bdunna likes this.
  9. Nov 30, 2015 at 4:53 PM
    #69
    radchris88
    Christian
    NY
    This one doesn't do that. I will take more pictures demonstrating. I would just take it off because it takes less than 5 minutes.
  10. Nov 30, 2015 at 4:56 PM
    #70
    CusterFan
    The hard cover I mentioned and the Extang Solid Fold 2.0 both come off by releasing the 2 front and rear handles. No rails. The cover just sits on the bed rails.
  11. Nov 30, 2015 at 4:56 PM
    #71
    radchris88
    Christian
    NY
    My main requirement was hard and something that could be taken off easily so I could put a cap on for camping. All the solid fiberglass were too expensive and not really removable. I really don't like the leather ones, but that is just a preference thing for me.
  12. Nov 30, 2015 at 4:58 PM
    #72
    radchris88
    Christian
    NY
    Mine is the extang solid fold 2.0.
  13. Nov 30, 2015 at 5:32 PM
    #73
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I hear you but that only works to me if you plan ahead of leaving that you are going to remove the cover. I can't tell you how many times we went out and picked up or moved something and all I have to do is roll mine up. To each there own I always say. That is why they make all the different types of covers
  14. Dec 1, 2015 at 11:31 AM
    #74
    swimmer
    Tucson
    2016 TRDORAC4WD
    So by hitting the tail gate means you need to lift the cover a bit when closing the tail gate? It seems there is no restriction to the bed cleats correct?
    Thanks for post BTW.
  15. Dec 1, 2015 at 11:37 AM
    #75
    NoDak
    JR
    Minot, ND
    tailgate hitting the cover, due to the cover being about 1/4" too long. cant really lift the end to close the gate due to the way its installed.
    slight reduction on travel on the oem sliding cleats, but you can see you can move them to the very end. the mounts are static since the holes in the mounting rails are pre-drilled. I imagine if you wanted to drill a new hole closer to the end of the oem channel for the cleats you would get more travel.
  16. Dec 1, 2015 at 11:46 AM
    #76
    swimmer
    Tucson
    2016 TRDORAC4WD
    Thanks. What about with regards to my question about the tail gate?
    FWIW, these are $401 incl. shipping bought from the manufacturer right now.
  17. Dec 1, 2015 at 11:51 AM
    #77
    NoDak
    JR
    Minot, ND
    from what I can tell the rear lip is about 1/4" too long, but that might be due to mis alignment on install (btw I had the dealer install it). its not a deal breaker since I can still close the gate but it does hit the lip of the cover when closing.
    the amount of times I actually open the gate during the year, its a minor point (maybe 7-9 times a year)
  18. Dec 1, 2015 at 11:55 AM
    #78
    swimmer
    Tucson
    2016 TRDORAC4WD
    Thanks. I was leaning towards the Lo Pro but, the lower cost and greater access/use of the bed cleats has changed my mind and I will get the Access cover. Quality seems similar with the only advantage of the Lo Pro being their sliding Velcro/auto tension which is nice.
  19. Dec 1, 2015 at 12:00 PM
    #79
    NoDak
    JR
    Minot, ND
    if you need more pics let me know, I can take some this weekend when there is better light. I don't get home until low light/dark during the week.
  20. Dec 1, 2015 at 12:11 PM
    #80
    CusterFan
    http://www.truxedo.com/lopro/land.php
    Just got off the phone with TruXedo and they told me you can use the sliding cleats with the Lo Pro QT on the 2016 Tacoma's. You can order from online vendors and the covers will be sent straight from the factory next week.
    Not to mention every part on the TruXedo Lo Pro QT is guaranteed for LIFE. And made in South Dakota.
