Tonneau Cover Suggestions
Discussion in 'Tonneau Covers, Caps and Shells' started by IneedAtruck, Mar 13, 2022.
  1. Mar 13, 2022 at 9:21 PM
    IneedAtruck
    IneedAtruck [OP] Active Member
    Searching
    Looking for suggestion on tonneau covers - Pros/cons and thoughts.
    Truck is a 4 door, 2022 TRD Off Road - 5ft bed.
    I am looking towards a retractable one (retrax), but they are pretty pricey. I am not a big fan of the trifold blocking the whole back window if I have to put it up.
    I rarely will be hauling stuff that will require to use my whole truck bed every day. Occasional furniture pick ups and trips to Home Depot, so I am not too worried to lose some space in the truck bed.
    I am all ears on any suggestions as to why or why not a retractable is a good idea or if I should just go with a tai-fold.
  2. Mar 14, 2022 at 5:17 AM
    Greene368
    Greene368 Well-Known Member
    Metro Atlanta, GA
    2021 Toyota Tacoma TRD Sport 4X4 Predator, Black
    I have a trifold now (Bakflip mx4) and previously had another Bakflip trifold when I had my Tundra. I think most of them on the Tacoma leak- I guess you can look up threads about it and how to seal it.
    I use mine like you said you would use yours. How I figure it, when I would have enough in the bed to cause me to fold it up so the trifold would block my back window, the stuff I'm carrying would most likely already be blocking it anyways. Just something to consider.
    Get what you like. All of them have their pros and cons. I like mine.
    mattrussmill and IneedAtruck[OP] like this.
  3. Mar 14, 2022 at 5:21 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The OEM one won't block your whole view...but that's because the last panel is bolted down.
    Take a look at Peragon truck bed covers. They are exactly what you're looking for and easily removable. And, unlike with Retrax, there isn't a giant box taking up valuable space in your bed.
    IneedAtruck[OP] likes this.
  4. Mar 14, 2022 at 5:29 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    I know you are not a fan of the trifold.
    I bought this last year for mine and it has been great. Its better than the Factory hard cover I had on my 2016. It fits very tight and have had zero water leaking.
    When you unfold it all the way its like the OEM and it doesnt block the rear window.
    https://www.amazon.com/gp/product/B07S99YBCY?ie=UTF8
  5. Mar 14, 2022 at 5:39 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    All I will say is don't cheap out here! Spend some money on a quality cover; the cheap ones are cheap for a reason.
  6. Mar 14, 2022 at 5:44 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I also have the Bakflip MX4, and I also had a Bakflip on my previous truck. I absolutely love them. Great product and extremely versatile. They are expensive but you get what you pay for.
  7. Mar 14, 2022 at 8:15 PM
    TheWeatherman
    TheWeatherman Well-Known Member
    Northern Colorado, CO
    2022 TRD Pro
    My 2010 had a truxedo low pro. I was on the fence about getting a BAK revolver x4s for my 2022. It cost $1100. I ended up with another truxedo low pro because it was $549 and it did a good job on my 2010.
  8. Mar 14, 2022 at 9:18 PM
    ValK83
    ValK83 Well-Known Member
    Andrew
    2021 Tacoma TRD Sport Army Grn
    TRD Wheels in bronze. Falken tires
    I have the Truxedo X15 which is low profile. Have had it on my last couple trucks. I really like it. Flatter on top than other roll ups. Keeps everything dry. Good price compared to others.
  9. Mar 14, 2022 at 11:04 PM
    curated
    curated Well-Known Member
    NY
    2022 TRD OR, 2001 TRD OR
    My truck came with the OEM cover which is ok but the Retrax cover is tempting....
  10. Mar 14, 2022 at 11:23 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    :poking: Damn. No pics? Disappointing,
  11. Mar 15, 2022 at 7:07 AM
    IneedAtruck
    Searching
    How much weight can you put on top of your backflip?
  12. Mar 15, 2022 at 7:08 AM
    IneedAtruck
    Searching
    did you install it yourself? That’s another charge I’m trying to avoid.
  13. Mar 15, 2022 at 7:10 AM
    IneedAtruck
    Searching
    How long did it take to put on? Was it pretty easy?
  14. Mar 15, 2022 at 7:14 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I did not, I had my local shop do it.
  15. Mar 15, 2022 at 7:14 AM
    16TacomaSport
    Jon
    Pittsburgh PA
    it took me about 20min to put on. Yea it was pretty easy. once you get it installed taking on and off after will take less than 5mins if you ever need to remove it completely
  16. Mar 15, 2022 at 7:15 AM
    KCU Beor
    KCU Beor Well-Known Member
    Ala.
    2022 Super White TRD Off Road M/T
    +1
    Also lifetime warranty
  17. Mar 15, 2022 at 7:32 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I have a BakFlip G2. It allows access to the entire bed, but it does fold up against the back window if you want to use the last 1/3 of the bed.
    Maybe you should get a soft roll up cover?
    Here's some pics of my G2. I'm very happy with it.
    Let’s see dem Silver Tacos!!! | Page 298 | Tacoma World
  18. Mar 15, 2022 at 8:35 AM
    JAL
    JAL Well-Known Member
    Mississippi
    96 Tacoma Access Cab (sold) now 2018 Tacoma DCSB 4X4 OR (traded). Current 2022 TRD DCSB OR Celestial Silver
    RCI Sliders and mostly stock.
    Anybody tried the Sawtooth flexible roll up tonneau?
    Been looking at it and the Pro’s and Con’s but wanted to see more user opinions.
    But due to newness to market not much written on it.
  19. Mar 15, 2022 at 9:00 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    I have a Lomax tri-fold cover on mine. I purchased it from a vendor here (Got_Exhaust I believe is his user name) and installed it myself. There is no drilling or permanent modification required to install this cover.
    Previously, on my 2010 Tacoma, I had a soft, roll-up type cover.
    Each option has positives and negatives. The roll up is easy to operate and leaves the majority of the bed available. It is also the least secure (able to be defeated with a razor blade) and cannot be easily removed if you really need every inch of the bed.
    The Lomax uses aluminum sheets so it is very secure. I’m sure a determined thief could get into the bed, but it would take time and tools.
    The negative to the tri-fold is you have that last panel remaining in place in normal operations to open the bed.
    That said, the Lomax design allows for the easy removal of the entire cover assembly with no tools. It is a bit bulky to move around, but it isn’t that heavy. You just need to plan ahead - i.e. “I’ll need the entire bed later today, so I’ll remove the cover this morning.”
    Neither cover was 100% waterproof. I’d say the hard cover is a bit better than soft cover, but both leak a little. The majority of the leaking seems to occur around the tailgate, so I think the lack of seals there is the culprit which makes cover design irrelevant.
    Not_Sure likes this.
  20. Mar 15, 2022 at 9:32 AM
    holvey
    holvey Well-Known Member
    Brian
    Portland, OR
    2020 DCSB TRD OR
    I got the Truxedo Sentry which looks the same but has the aluminum bars like the Bak Revolver I love it. It covers 1/3 to 1/2 of the of the back window when it is rolled up, and only lets in a few drips of water if I take it through a car wash.
    My favorite parts are how little it sticks above the bed rails and the convertible canvas type material looks way cleaner than vinyl.upload_2022-3-15_9-31-37.jpgupload_2022-3-15_9-32-1.jpg
