Tonneau Cover Suggestions
Discussion in 'Tonneau Covers, Caps and Shells' started by IneedAtruck, Mar 13, 2022.
  1. Mar 15, 2022 at 11:08 AM
    jbb235
    jbb235 Active Member
    Jim
    tneynop and themcnertney like this.
  2. Mar 15, 2022 at 11:13 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    The OEM soft trifold on mine is great. If I hadn't gotten it from day one I would have gone for an aftermarket roll-up cover for all the reasons you mentioned.
  3. Mar 15, 2022 at 11:33 AM
    Westco sc
    Westco sc Active Member
    2019 Trd offroad
    I had the same idea as you - really wanted a retractable as they are slick and I could get bars to put over it and mount bikes on that. I ended up with a trifold because:
    price - really expensive, even more when you add the feet and bars for a bike
    clearance: I really wanted the option of also putting the bikes in the back with a tailgate pad. The retractable ones still take up a deeper portion of the bed. Too much on a 5' bed. The trifold (think it's a backflip) has a shorter profile when up.
    I like it, it's solid so nice to sit on (eating lunch, etc). It is easy and quick. I don't love the total blocking of the window, but when reversing we have a camera and when driving side mirrors, it's never been an issue. And with the money saved I could easily get a really nice hitch rack for bikes, but mostly I just use the tailgate pad which is so fast and easy. I feel it's secure enough, yeah someone could pry it up but out of sight is out of mind. I also added the factory electric tailgate lock (probably my favorite mod- why they don't come this way I'll never know, its only $100 part and a pretty easy install), so when I lock the truck the back is locked, which makes me comfotable leaving random crap in there. The only time I wish I had gone the other route is when I am towing a trailer, it would be nice to have bikes on a rack over the bed, but I have found plenty of work arounds.
  4. Mar 15, 2022 at 11:40 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I am not sure if anyone has suggested the OEM hard tri-fold cover, but you might consider looking for a used one nearby. Many here do not like them, but count me as a fan as they are built rock solid and I bet you could stand on it and not hurt it. Easy enough to completely remove if needed (one security bolt removed is all that is needed to take it off). I will admit that it is a bit heavy and clunky to remove by yourself, but definitely easy enough to do solo.
  5. Mar 15, 2022 at 12:04 PM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    The only issue with going with the OEM cover in an aftermarket situation is the requirement to replace the bedside covers on each side.
    My understanding is guys usually trade bed caps when buying the cover, but I’m not certain I’d want to put used caps on a brand new truck.
    FWIW, this is why I went with the aftermarket option. I didn’t want to drill, cut, or modify my brand new bed in any way.
  6. Mar 15, 2022 at 12:16 PM
    Buck Henry
    All true for the OEM cover, but you are not cutting, drilling or modifying the truck bed, just the rail caps. And most owners are more than happy to swap out the bed rails, they just pop off. As far as them being "used rail caps", come on man!
    Benny blanco likes this.
  7. Mar 15, 2022 at 12:18 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Love my bakflip mx4. I beat the shit out of it and it’s been awesome. It’s also basically theft proof (bar an angle grinder, but at that point nothing stops them) and water tight (if Toyota didn’t just drill holes in the bed floor)
  8. Mar 15, 2022 at 12:26 PM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Following along.
    I have a cheap Gator soft trifold. Keeps the water out when it rains, gets wet inside through car washes though.
    I have a KB Voodoo bed rack that I ran last year with a CVT tent, I didnt notice any strong vibration or flapping from the cover. This year however, I added a prinsu roof rack to the mix, the cover flaps pretty badly on highway roads. I think I need a better cover, hence the follow to see what others like.
  9. Mar 15, 2022 at 1:26 PM
    themcnertney
    Dan
    Akron, OH
    This looks awesome. Would I still be able to use the adapter brackets for bed racks with this cover?
  10. Mar 15, 2022 at 4:51 PM
    TheWeatherman
    TheWeatherman Well-Known Member
    Northern Colorado, CO
    2022 TRD Pro
    I thought about one of these but I didn’t like the outer material compared the the low pro.
  11. Mar 17, 2022 at 11:36 AM
    skuo07
    skuo07 Well-Known Member
    Another vote for the bakflip mx4
  12. Mar 17, 2022 at 5:08 PM
    IneedAtruck
    IneedAtruck [OP] Active Member
    Searching
    About how much was your backflip? Was install pretty easy?
  13. Mar 17, 2022 at 5:11 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I replaced my “new” 2021 tail lights with the much better looking imho 2017 style. Truck doesn’t look any older.
  14. Mar 18, 2022 at 7:06 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    4x4_Steve likes this.
  15. Mar 22, 2022 at 5:46 PM
    #35
    4x4_Steve
    4x4_Steve New Member
    2020 TRD Sport Double Cab
    How has your experience been with the G2 and weather/water, any leaks? I know nothing's going to be watertight but I want something close...
  16. Mar 22, 2022 at 6:02 PM
    #36
    mrchristopher2
    mrchristopher2 Well-Known Member
    2020 TRD Pro 6spd
    I also am very happy with my Bakflip MX4. When I was looking it came down to the Bakflip and the Diamondback. Ultimately the Bakflip was much more useful for my needs (like when my wife find a large piece of furniture unexpectedly while we’re 50 miles away from home).
    Mindgame and 4x4_Steve like this.
  17. Mar 22, 2022 at 6:26 PM
    #37
    4x4_Steve
    I'm looking at the MX4, too. Any issue with leaks?
    mrchristopher2 likes this.
  18. Mar 22, 2022 at 6:31 PM
    #38
    mrchristopher2
    2020 TRD Pro 6spd
    Not really. If I was going to put a figure on it, I’d say it’s 95% effective in keeping water out. When I installed it I tried to address any areas that might be an issue
    4x4_Steve[QUOTED] likes this.
  19. Mar 23, 2022 at 9:38 AM
    #39
    SSMTRDOR
    2020 TRD OR 4X4
    I've been through a couple of rain storms (but no monsoons yet), and there are no major leaks.
    There was just a small amount of water that entered at the back of the bed.
  20. Mar 23, 2022 at 11:05 AM
    #40
    SSMEDT
    SSMEDT Well-Known Member
    Georgia
    2010 DCSB PreRunner
    I have had a Peragon for the last 2 years or so and Love it! love how it is quickly removeable for full access to the bed
    tneynop likes this.
